1. Uberfast
    Uberfast Junior Member
    76
    Oakland , ca
    2014 Prius v wagon
    Hi folks.
    I'm locked out. Battery dead. I have the key fob key. When I place the small key into the door. The door will not unlock. In the driver side door I turned the key both ways.
    No luck the door will not open. Where is my mistake.
    Please and thank you.
  2. JC91006
    JC91006 Senior Member
    16,815
    8,596
    Try to wiggle it loose or use a little wd40. Did you buy the car used? Hopefully it's the right key.
  3. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    Ok. Will get the grease out. Yes I tried to wriggle it. Ill try again. Car is new from dealer. Thank you
  4. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    So I tried the wiggle and grease. No luck.
  5. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    I locked all the doors manually.
  6. Prodigyplace
    12,629
    11,808
    Central Virginia
    Try your other fob and/or the key from your other fob. New cars have 2 fobs, but a new 2014 Prius v is very unusual now.
  7. mhagadorn
    mhagadorn Junior Member
    28
    Western Pennsylvania
    Is the little key cut with a pattern in the sides of it? Sounds like you don't have the correct emergency key (either blank, or for a different car). Ditto on trying another key fob and key.
  8. bisco
    52,286
    try a pair of pliers on the key. not too hard.
  9. Air_Boss
    Air_Boss Senior Member
    4,218
    1,188
    New Yawk
    Invite dealership comment on duff battery and lack of working manual key?
  10. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Then this conversation is over. The dealer needs to have it towed in and solve this for you. And while you're arguing with them, they owe you a brand new 12v battery too.
    Air_Boss and Prodigyplace like this.
