PVC replacement troubles help
Discussion in 'Gen 2 Prius Technical Discussion' started by gregheadman, Jan 8, 2017.
  1. gregheadman
    gregheadman Junior Member
    26
    Las Vegas, NV
    Removing PVC valve and cracked the engine block in about 0.01 inch indent. No luck uploading the pic help
  2. gregheadman
    26
    Las Vegas, NV
  3. gregheadman
    26
    Las Vegas, NV
  4. Mendel Leisk
    41,898
    Professional assessment and maybe some welding? Or maybe something like JB Weld will be deemed sufficient?
    How'd it happen? You were levering hose off?
    #4 Mendel Leisk, Jan 8, 2017
  5. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Luckily the broken part is just valve cover. Also called cylinder head cover. To remove it all you need to do is remove the cowl (which should be removed just to replace pcv-valve), ignition coils, and couple of bolts.
    Then you can either get used one from another Prius, or weld or solder the cover back together. When putting it back together use new gasket.
    Even on quick search I could find used valve cover on 50 dollars in US so probably that’s the way to go. You can also get the new gasket at the same time.
    #5 valde3, Jan 8, 2017
  6. gregheadman
    26
    Las Vegas, NV
    That was my impression as well but I appreciate the reaffirming words. Just a fat open-end wrench trying to loosen PVC valve for replacement.
  7. Mendel Leisk
    41,898
    I couldn't picture where it was, and the term "engine block" sounded ominous. At valve cover. I think you could roughen and clean thoroughly (even without removal), then apply a 2 part epoxy, JB weld or similar, liberally past the crack zone.
  8. gregheadman
    26
    Las Vegas, NV
    Yes I was thinking along those lines as well appreciate your input.
