Swapped all 4 tires, found a slightly bent rim
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by minibox, Jan 11, 2017.
  1. minibox
    minibox New Member
    Long Island, NY
    Recently picked up a Prius and noticed that one of the tires sounded like it had a flat spot on it. Was noticeable at higher speeds. Replaced the tires yesterday and on the balancing machine the technician showed me that one wheel was not spinning perfectly straight. It had a very slight wobble to it.
    Where would be a good place to find a replacement wheel? Not trying to spend much on it. Figure a second hand one would be good as long as its straight. Any ideas?
    Thanks!
    51,873
    ebay, salvage yard, tire rack, etc.?
    minibox and Raytheeagle like this.
  3. mrbigh
    3,686
    699
    Long Island, NY
    if it had hit a pot hole, can it be strengthened?
    minibox likes this.
  4. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    I see you live in NY. Here in So Cal, there are places one can take a bent or warped rim and have it fixed. I did this alot, to the point of not wanting specialty rims anymore. I would look under "Rim Repair" in your area.
    minibox likes this.
  5. minibox
    minibox New Member
    Long Island, NY
    Thanks for the input. Not sure if it hit a pot hole before my ownership. But I am sure it takes a good amount of force to bend a rim. Should probably check my suspension and alignment as well.
    Tried ebay and tire rack, they were looking for 130 or so per wheel. Salvage yard in NJ wants 65 and comes with the hubcap. Seems like a much better price. I will definitely also check into rim repair as well. If its the same price as the salvage yard, ill just try to fix my original wheel.
    Man, this is my second post here and you guys answered so quickly. Really appreciate it! You guys rock!!
    Raytheeagle, bisco and Montgomery like this.
  6. Montgomery
    2,254
    2,241
    Orange County, CA
    I have found the peeps here at PruisChat to be straight shooters. You will find the answer to anything you want to fix or do to your car. In the search bar, if you type in what your issue is, you should find alot of people with responses. Two of my favorites are "The Electric Me" and "Bill the Engineer" for both fun and informative reading. This sight is my favorite pastime between TV and sports. Check out all the interior things that people in here have done!
  7. Montgomery
    2,254
    2,241
    Orange County, CA
    Oh, and NY' krs rock!! Love the east coast!!
  8. mrbigh
    3,686
    699
    Long Island, NY
    We do have an small company doing rim repairs in Long Island and they had a shop on wheels also, a truck very well equipt for too.
    I had use them a few years back for the repair of an expensive cracked aluminum rim
    minibox likes this.
  9. minibox
    minibox New Member
    Long Island, NY
    Yeah definitely an awesome forum!
    I got lucky! Stopped by a friend's shop real quick to check the tires and wheels out. The mechanic came out shaking his head and laughing.
    Turns out the shop that installed the tires didn't balance the wheels correctly nor did they even remove the old weights when swapping the tires. One of the wheels even had a tire mounted on incorrectly! Don't even know how that's possible!
    Getting them rebalanced correctly now. Glad I didn't have to pick up a new rim for the car.
    Thanks again for everyone's help!!
  10. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Just not enough to live out there;)!!
  11. minibox
    minibox New Member
    Long Island, NY
    Ah it's called tire run-out. Lesson learned. Get the tires balanced by a place that knows what it's doing. :)
  12. Mendel Leisk
    41,377
    Those are good prices. New through the dealership they're something like $350. If you buy from the salvage yard there's the advantage you can look it over carefully (hopefully not also bent), and a lot cheaper too.
  13. Montgomery
    2,254
    2,241
    Orange County, CA
    Is marijuana legal in New York?............LoL
