Burning smell when driving Prime in Charge mode
Discussion in 'Prime Main Forum (2017-2022)' started by Caleb302105, Jan 11, 2017.
  1. Caleb302105
    Caleb302105 Junior Member
    29
    Bend, OR
    Hello everyone, we just purchased a Prius Prime Advanced yesterday and I've been testing out the different driving mode buttons. Anyway, when I put the car in recharge mode (by holding down on the HV/EV button) this ghastly plastic burning smell starts pumping through the HVAC system. I can also smell it quite distinctly from outside the car. When I've been running these tests of the charge mode it has been either when moving on neighborhood streets under 35 mph or while stationary. Does anyone have any idea what this could be? Thanks.
  2. Mister MMT
    Mister MMT Active Member
    285
    142
    Germany
    Charging produces a high current, and therefore heat. On a new car, this may produce some smell which may fade away with time. I would contact the dealership or Toyota and ask whether it is normal.
    Few people so far have reported how hte car behaves when charging, and what the net incidence on mileage is.
    I would be interesting to have all information in one thread.
    Jan
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I did charge mode both times I test drove. No smell at all, inside or outside.
    Take it back.
  4. bisco
    52,224
    sounds like a trip to the dealer, and don't use charge mode until it is diagnosed and repaired. i wouldn't fool around with anything in a car where burning is mentioned.
    Prodigyplace likes this.
  5. Caleb302105
    29
    Bend, OR
    Alright, thanks everyone for your replies. I'll call the dealer today.
  6. Caleb302105
    29
    Bend, OR
    Alright, after many phone calls (non of which were with the service department because they were claimed to have been too busy) I am going to take the vehicle in tomorrow morning but they are saying that I'll have to leave it all day in hope that they are able to find some time to inspect it. The Sales rep I spoke with claimed that it was likely oil that they applied to the outside of the engine (to protect against corrosion while shipping) just burning off. I'm not so sure. :-(
  7. Lee Jay
    5,850
    4,036
    Does it do it in Hv mode as well?
    Caleb302105 likes this.
  8. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    They apply wax to the engine and other things underhood. But yes, it does make a smell when heated well. Smells to me like cross country skiing (hot wax time!!). ;)
  9. Lee Jay
    5,850
    4,036
    It isn't wax, it's Cosmoline.
  10. Caleb302105
    29
    Bend, OR
    I'm starting to realize that we basically never ran the engine except perhaps a few minutes each day. We've been "EVing it" all over the place. I suppose it follows then that engine hasn't been getting properly broken in. Therefore, I've just started running the car in HV mode and will continue to do so (at least) for the first 200 miles. Also, before I posted into this thread (most recently) I ran the car again in charge mode for 15 minutes and eventually the smell went away for the most part. I'm hoping the wax idea is what it is. Thanks everyone for the responses. :)
  11. bisco
    52,224
    i hope that's it. i've never smelt anything burning on a new car before.
    priuscatprimeguy likes this.
  12. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    Didn't people complain about a burning smell in gen. 3 Prius while going up steep hills ?
  13. bisco
    52,224
    yep, what was the outcome, don't go up hills?
  14. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    It's that new car smell.
    We should send you a service bill for the excellent advice given out. LOL
    priuscatprimeguy and Caleb302105 like this.
  15. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    bwilson4web likes this.
  16. OMAR SAYEED
    OMAR SAYEED Junior Member
    Alexandria, Virginia
    Sounds like (or smells like) your new car is breaking in. every vehicle has funny smells while things are getting broken in. Catalytic converters, new exhausts, etc... I just discovered the CHG mode myself and noticed this smell prior to reading this post. It goes away after some time. I really need to read about all the cool new features of my new prime!!! :)
  17. bisco
    52,224
    and change your info, congrats!(y)
  18. OMAR SAYEED
    oh dang! thanks!
  19. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    That's really sad that you bought a brand new car from them and they don't have the time to look at it. I would be very unpleasant to the person that told me that to be honest.
  20. Caleb302105
    29
    Bend, OR
    Okay, I drove the car to the dealership this morning in EV mode and then got a technition to go with me on a test drive (with CHRG Mode enabled). The car didn't make any burning smells but I'm still having them check it out today. I also asked if they could check into changing the reverse beep to a single beep. Hoping for the best. Again, thank you everyone for your replies.
    Neohippy and bisco like this.
