How to Remove the Front License Plate Bracket?
Discussion in 'Prime Accessories and Modifications' started by geguia, Jan 12, 2017.
  1. geguia
    geguia Active Member
    210
    108
    los angeles
    So i removed the two galvanized bolts/screwed from the license plate bracket and the bracket is still not coming off.
    So it looks like there are clips holding it in place.
    Any suggestions?
    Yes i know i will have (2) holes in the bumper :)
    and yes i know the laws (CA)
    and yes i know it will look better with no plate ;)
  2. Will_Prius16
    Will_Prius16 Member
    127
    64
    Now in West Covina, CA
  3. geguia
    210
    108
    los angeles
    Thanks. i just looked clipped in. I will put and hopefully not break anything.
    BTW you don't happen to have a red prime? I drive through West Covina from LA and i've seen a Red Prime roll through the 10 a few times.
  4. Will_Prius16
    Will_Prius16 Member
    127
    64
    Pearl white, haven't seen a prime since I've purchased mine
  5. huskers
    huskers Senior Member
    2,546
    2,487
    Nebraska
    Primes in the wild. You should take a pic.
  6. Db17
    Db17 Member
    188
    92
    Visalia, CA
    We'll bring you cigarettes on Tuesdays.
    geguia likes this.
  7. geguia
    210
    108
    los angeles
    done :) looks clean
    Will_Prius16 likes this.
  8. Will_Prius16
    Will_Prius16 Member
    127
    64
    The two screw holes don't bother you?
  9. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Some idiot somewhere, tightens the hell on these sheet metal screws, I think it's the dealers. I got one off and then went to the dealer on the other one.
  10. geguia
    210
    108
    los angeles
    minor imperfections. i'll get some caps (y)
  11. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    So are you now going to reshoot your avatar photo, or just Photoshop out the front license plate frame? :)
  12. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    I got the only RED Prime here near SF/Daly City/San Mateo area that I have seen. I have only seen 1 other PRIME in White at a charging station twice.
