2016 prius rear wiper issue
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by thewraith, Jan 13, 2017.
  1. thewraith
    thewraith Junior Member
    67
    DC Metro
    The rear wiper on my Prius will not even hit the back window when it swings over- so it will not wipe my rear window. It is adjusted properly as far as the pull thing with the clip that you can move to clean the rear window. It just doesn't touch. Anyone else seen this issue? I'm trying to avoid a trip and hours at the dealership.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Have you lifted it off the screen to check there isn't something jammed in the hinge joint - that's all I can think.
    thewraith likes this.
  3. thewraith
    67
    DC Metro
    I have not- I will do this weekend. i'll remove it altogether and see.
    Thank you for the reply!
    #3 thewraith, Jan 13, 2017
  4. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    I Have the same issue with the rear wiper. :confused:
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Mine doesn't fully clear on the down stroke but it's perfect on the back stroke. I can live with that.
  6. thewraith
    67
    DC Metro
    Exact same issue on mine, I tried adjusting it and even replaced the blade. The wiper is useless.
  7. bbunge
    bbunge Member
    35
    33
    Southampton
    There was an issue with the rear wiper on early 2016 Prius. Seems some car washes would catch the blade and rip it off. Was supposed to be fixed by mid year 2016. Suggest you check with your dealer for a fix.
    P01M ?
    tucatz likes this.
  8. Christov Tenn
    Christov Tenn Junior Member
    Stepford, Tennessee
    Any solutions to this one? I've got an early 2016 Prius Three with this problem. Replaced the blade but no joy.
  9. Ostneb
    Ostneb Junior Member
    Boston
    2001 Prius
    I
    Has anyone ever found a solution to this problem? I’m wracking my brain and can’t find a fix, new wiper blade didn’t help. Thanks!
  10. ShuttlePod
    ShuttlePod Junior Member
    Colorado
    2020 Prius
    It's pretty useless for snow even when working properly, because it clears such a small area & piles it up right in the middle of the window.
  11. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    Mine has the same issue, after a car wash ripped it off. At a toyota dealer! The maintenance guys reattached it and tried adjusting the sweep, but it’s never been the same. The blade doesn’t wipe the rear window. I’m thinking of just taking it off.
  12. Ostneb
    Boston
    2001 Prius
    I
    Doesnt instill confidence if even the dealership is unable to fix this :(
  13. dbat23
    dbat23 Member
    53
    37
    WI
    2020 Prius Prime
    Must have been poorly designed, as I had same issue on my 2016 - it NEVER cleared the window properly. Took pics when snow-covered, then took it into dealership- they replaced the blade (LOL). Then i returned and ultimately they replaced the complete motor assembly (only time my extended warranty was used and covered it) and it STILL did not clean/clear the window of water or snow. I gave up. Told them they wasted two days of my life on a "no solution" deal. Eventually sold the 2016 and bought a 2020 Prime - problem solved as IT HAS NO REAR WIPER.
    tucatz and krmcg like this.
  14. tucatz
    501
    417
    Manzanita, Oregon
    Four Touring
    Thanks, I’m going to remove my rear wiper. Maybe gain a 0.0015 percent increase in aerodynamic efficiency!?
    dbat23 and krmcg like this.
  15. Tande
    Tande Active Member
    541
    322
    Mich.
    My 2017-1/2 works as advertised .......something has changed! ......:confused:
