I need a technical help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by maabreh15, Jan 14, 2017.
  1. maabreh15
    maabreh15 New Member
    Jordan
    hello, I made a services for my prius 2009, the maintenance I have done are 1. engine oil change and oil filter change 2. gear box oil change 3. fuel injectors ckeaning 4. spark plugs change. then I am getting rough engine running, engine check light, warning light to stop the car and the car switched off by itself while driving in addition to loss of power and strange engine noise! what is the problem? may anyone help if experienced that or have a knowledge of the problem please?
  2. JC91006
    JC91006 Senior Member
    16,761
    8,562
    How did you clean the injectors? What spark plugs did you use? Did you overfill oil?
  3. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    Sounds like the spark plug wires are on the wrong plugs to me.
    krmcg likes this.
  4. bisco
    51,840
    welcome!
    how many miles on her?
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    I changed plugs at 145k on my Gen 2 and I don't think the plug wires can reach the wrong plugs. But one might not be connected securely or some other discontinuity in the plug wires/caps/coils. As always, you need to read the codes if you don't want to spend weeks and money guessing.
    Mendel Leisk and kithmo like this.
  6. fuzzy1
    10,405
    This means there are diagnostic codes available. Please find out what those codes are and report them back to us.
    Mendel Leisk and RCO like this.
  7. maabreh15
    Jordan
    the mileages are 149k, I will check the codes and back to you. thanks everybody.
    Mendel Leisk and jerrymildred like this.
  8. Tideland Prius
    16,547
    Is your 2009 a 3rd generation body?
    If so, I will move the thread to the appropriate forum.
    RCO likes this.
  9. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Was it running ok before you serviced it ?
  10. Prodigyplace
    12,527
    11,747
    Central Virginia
    A 2009 4th Gen would need to have been from "Back to the Future"?? :D
    Jaajaa10 and Tideland Prius like this.
  11. Tideland Prius
    16,547
    I'm asking because other countries don't use model years so a 2009 could be a Gen 2 or a Gen 3 depending on when it was bought during the year. I need to know where to move this thread to.
    Prodigyplace likes this.
  12. Mendel Leisk
    41,303
    What fluid was used, do you know? Should be TOTOTA ATF WS. Toyota warns to use this, nothing else. There are a few brave/foolish owners that have used alternative fluids, with no apparent problems in the short term. I don't think wrong fluid would cause your symptoms, at least if it was refilled properly.
    Your items 3 and 4 seem most likely culprits. Maybe they neglected to properly reconnect one of the spark plug wires? That'd be my first guess. I doubt the wires would be mixed up: no way they could stretch to another plug, and it would be very obvious.
    RCO and jerrymildred like this.
  13. bbald123
    386
    275
    Harrisburg, PA
    Hard to switch on the plug side. Not so hard on the other end.
  14. Mendel Leisk
    41,303
    Screen-grab from @NutzAboutBolts video on spark plug change. The "other end"??
    #14 Mendel Leisk, Jan 16, 2017
  15. Prodigyplace
    12,527
    11,747
    Central Virginia
    I assume they mean at the distributor? The other ends of the spark plug wires.
  16. Mendel Leisk
    41,303
    Yeah that's what I assume @bbald123 is thinking of too. Distributor cable connection was notoriously easy to screw up. Except there isn't one, lol.
  17. Prodigyplace
    12,527
    11,747
    Central Virginia
    The cables go somewhere ...
  18. Mendel Leisk
    41,303
    True, but how can this be a factor in op's problem? There is no way to disconnect, mix up or even access the other end of those wires. Are we done, lol?
  19. bbald123
    386
    275
    Harrisburg, PA
    Whether there is a cable switch or a loose cable or some other problem, the op's description of the problem sounds very much like an ignition firing order problem. Now we're done.
  20. JC91006
    16,761
    8,562
    Are you a mechanic? What's the difference between a loose cable or a plug that's not torqued right? Or a wrong spark plug?
    How did you get to the loose cable or distributor that the car doesn't have?
    Many things can cause a misfire, and everything the op recently did has to be looked at
    #20 JC91006, Jan 16, 2017
