Is OEM the best ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Jan 16, 2017.
  1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    Hello All
    I may have to replace a wheel bearing on a 2010 prius after 57,000 miles
    The OEM part did not last long so I wonder what are some good quality after market brand names for Prius parts? The OEM wheel bearing assembly is about 300 dollars at the dealer
    Thanks
    51,794
    i don't think there have been any objective studies done of various bearing manufacturers. anecdotal evidence sometimes points to oem, and sometimes not. i would go with a reasonably priced, well respected source.
  3. Taxi/Limo
    524
    107
    I talked to Arts Automotive in Berkeley and they recommended Koyo parts he said they make toyota"s parts
    Nexus 6 ?
    Raytheeagle and bisco like this.
  4. bisco
    51,794
    art knows bearings.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Does this mean the tire rotation test drive produced the noise still in the drivers rear of the car?
  6. Mendel Leisk
    41,236
    I've heard there's one third party manufacturer's bearing that are in fact the OEM bearing,, ie: you can buy them with Toyota name (presumably for more) or through the actual manufacturer. I've no more experience/knowledge though: maybe someone will be along who knows specifics. The bearings were identical in appearance, had same numbers stamped. Could be Koyo as you've been told, do not know.
  7. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Now that there's two threads on this....I'm going to ask, has the worn bearing been confirmed? Does it to be replaced right now?
    Ie; is it effecting mpg or is the sound driving you crazy?
    You could also have a dragging brake.
    #7 Jimi1976, Jan 17, 2017
  8. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
    For what it is worth to you, all OEM parts and labor by a Dealer have a 12 month unlimited mileage warranty. Says so right here on my receipt for the wheel bearing install my local Dealer just performed. :)
  9. Mendel Leisk
    41,236
    Yeah, that's never good, frustrating for responders.
  10. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    You may be referring to my observations regarding the Timkens, Mendel. I found them to apparently be exact OE with regard to Gen 2 fronts, Koyo stamped bearing and all. I have not had a failure with my Gen 3 yet, but when I do I will go the Timken route unless someone here verifies they are something other than apparent OE. Both Rock Auto and Amazon sell them at a price comparable to any replacement. I prefer OE for the Japanese spec (although who knows where they are actually manufactured) bearing and after reading unconfirmed reports that some of the big name aftermarket brands use China-made bearings. I've also seen opinion/conjecture that Toyota models prone to wheel bearing failure are such because of camber/toe specs which stress the bearings. This leads me to believe that lesser quality bearings will only fail sooner if used on a failure prone model. I also feel it's critical to torque the axle nut to spec and not just blast it on at 300 ft. lbs. with the air impact. That's my opinion/conjecture, YMMV!
    #10 m.wynn, Jan 17, 2017
  11. Mendel Leisk
    41,236
    Thanks, I had only vague memory. (y)
    (Saved your comment and this address in my (.txt format) notes!)
    #11 Mendel Leisk, Jan 17, 2017
    Raytheeagle and m.wynn like this.
  12. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    But probably better than what I am accused of from time to time which is selective memory :rolleyes:
    m.wynn likes this.
  13. m.wynn
    684
    1,229
    Queensbury, NY
    Wife and 2 daughters here. Tell me about it...
    Raytheeagle likes this.
  14. Taxi/Limo
    524
    107
    Sorry for starting another thread and creating some cofusion. I thought it best to start a general discussion on OEM I did not know how active the members are here
    Nexus 6 ?
  15. Mendel Leisk
    41,236
    I can pretty much "carpet" forget. My wife otoh, can "remember" watching downloaded first-run movies, where there's no chance she's seen it before. Sort of a deja vue thing I guess. So between the two of us, it balances out, lol.
  16. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    They do have minds like steel traps. Mine used to be better, but that was B.C. (before children). Now I'm lucky to remember the important things like our anniversary and her birthday;).
    I usually buy the cards a couple of months in advance to ensure I have them on the right day and not have to run out midday to buy a card. Nothing is worse than that.....
