Hard wiring a dash cam
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Frederickdawg, Jun 8, 2016.
  1. christiandflores
    christiandflores Junior Member
    26
    San Diego
    Anyone know of a good source for constant and switched power? Mine is a 2016 three with ATP. I'm looking to do a hardwire that also works when parked.
    kc5dlo, Wraiththe and cptncrnch like this.
  2. Dorkytom
    Dorkytom New Member
    Orange county, ca
    I have 2016 Three with ATP.
    I did the hardwire to the fuse box for a119 dash cam. Super easy. Took me about 15 minutes to do the whole thing using a fuse tap, and converter for 5V usb output. Routed wires down A pillar.
    If i recall correctly i used the P/Outlet NO. 1 for switched power.
    With a fuse tap you can just keep plugging it into different fuses until you find one with constant power if your looking for that.
    #22 Dorkytom, Jan 17, 2017
    christiandflores and Harters like this.
  3. Nobby
    Nobby Junior Member
    Conwy UK
    I have a Lukas Duo which I had in my Auris Ts Hybrid and am now transferring to my Gen 4. I hard wired it with fuse taps and have spent a couple of hours planning the installation. Add a circuit fuse taps are the same pitch so normal mini fuses fit in low prophile, but you won't get the cover back on. On the Gen4 there are 5 spares. The spare in the middle between P/out 1 and Washer (both 15A) is IGNITION. The one opposite P/OUT 1 is 12V live. The only difficult bit will be getting the cable into the tailgate though the boot for the rear camera. For those of us with the steering wheel on the correct side the front camera is not so easy to position as on the Auris, it's not so well hidden behind the mirror. I will write up the installation when I finish.
    christiandflores likes this.
  4. christiandflores
    26
    San Diego
    Thanks that's helpful. I was looking techinfo.toyota, the radio fuse seems like it can provide constant power. What did you use for grounding?
  5. christiandflores
    26
    San Diego
    still having trouble with that? I have a pdf that shows how to remove the headliner trim and tailgate trim
    Rpowers47 likes this.
  6. Melton
    Melton Junior Member
    Can you PM me that PDF?
    Thanks.
  7. Prime213
    Prime213 New Member
    Washington
  8. Prime213
    Prime213 New Member
    Washington
    How do you remove the map light? And hwo are you converting 12v to 5v? Do you mind posting the photos? Thanks a lot!
  9. bobthejedi
    bobthejedi Active Member
    137
    153
    SF Bay Area
    I would recommend using plastic pry tools, I can PM you instructions, here is a video though
    Moonroof model is the similar
    evpv, Rpowers47 and RCO like this.
  10. bobthejedi
    137
    153
    SF Bay Area
    I also want to add some experiences of hard wiring, I have a BlackVue 2 camera setup like some other members, I just wired it properly with this hardwire kit from amazon
    VicoVation Vico-Power PLUS Battery Discharge Prevention (BDP) Device for Parking Mode
    Its very customizable where you set cut off voltage, timer, temp cutoff.
    I chose the P outlet for switched (ACC power) and the slot directly next it for Constant 12v with add a tap fuses 15amp on each, its a little crowded, but seems okay. I mounted the controller under the shifter
    RCO likes this.
  11. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    Lol found it thanks anyways nice one
  12. Envirogator
    Envirogator Junior Member
    Fl
    2018 Prius
    Can I also have a copy please. I am planing to do the same.
  13. Rmachin
    Rmachin New Member
    Seattle
    2021 Prius
    Thanks! Just did this in my 2021 xle and it works great - white/black and dark blue are the ground and switched positive. Everything fit inside the mirror housing, no need to remove the map lights.
  14. Wraiththe
    Wraiththe Member
    258
    49
    Charlotte NC
    Four years later.... Can I get a copy of that PDF?
  15. Irp
    Irp New Member
    Yorks, UK
    Business Ed. Plus
    Does anyone know where/if there’s an interior fuse box on a _UK_ RHD Prius (2016) Prius.
    Where is it, & what does it look like?
    I’m hoping to hard wire a dashcam in to it with a fuse lead, to voltage dropper (12V to 5V), to cam.
    I know where the Box is on US models, but can see nothing on the U.K. one in the similar or equivalent place.
  16. Harters
    Harters Active Member
    335
    424
    UK
    Excel
    Its up behind the glove box, so on the near side. Its a small rectangular box with a detachable lid. I keep saying I am going to hard wire mine in. I bought the kit years ago, but I'm still plugged in via the centre console :whistle:
