Forward recognition camera as dashcam?
Discussion in 'Gen 4 Prius Technical Discussion' started by Elektroingenieur, Jan 8, 2017.
  1. Elektroingenieur
    2,515
    3,283
    Three Touring
    Has anyone found a way to extract a usable video signal from the Forward Recognition Camera, the windshield-mounted camera found on vehicles with Toyota Safety Sense-P?
    The camera occupies the ideal spot for a dashcam, but I have no idea if would be suitable for this purpose. In particular, I’d be interested to know the camera’s resolution and frame rate, and whether it is monochrome or color; the published information from Toyota describes the camera only as “CMOS,” with no other details.
    The Repair Manual and Electrical Wiring Diagram disclose only heater, power, ground, and CAN bus connections on the connector (O7) for the camera ECU:
    O7-1 (HTR)
    O7-7 (IGB)
    O7-10 (GND)
    O7-5 (CA1P)
    O7-11 (CA1N)
    O7-6 (CANH)
    O7-12 (CANL)​
    Considering the limited bitrates for CAN and the system description in the Repair Manual, it seems clear that the machine vision algorithms are run inside the camera ECU, with only the results, not full-motion video, being sent across the CAN bus.
    It is tantalizing to have a twelve-position connector with five unknown pins, though—but not quite enough to spend $800 on a spare camera to investigate on the bench.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I read somewhere on here last year that the video would not be high enough definition to pick out number plates, etc.
  3. Kablooie
    Kablooie Member
    273
    La Canada
    Here is a little more technical info on the camera.
    It's not enough to figure this out but it looks like it might have a fairly decent image.
    An additional module can be added to recognize street signs but since it's developed in Germany it looks like it may only work with European signs.
    Continental Industrial Sensors -MFC 2 Multi Function Camera
    Mambo Dave likes this.
  4. Elektroingenieur
    2,515
    3,283
    Three Touring
    Thanks for the link to the information about Continental’s camera system. I’m not sure that is the one, however—the 2016 Prius liftback with TSS-P, at least, seems to use a camera ECU made by DENSO.
    For my car, the parts catalog says the Forward Recognition Camera is Toyota part number 8646C-47010. I found a junkyard selling one, and in their photos, the part is marked with that number, “DENSO,” “036500-7372,” and “MADE IN JAPAN.” They also wanted $700 for it, which is still too much to spend just for a component teardown.
    You are correct about European signs: in Europe, the Prius has a Road Sign Assist feature, which the owner’s manual describes as being able to detect speed limit and no overtaking signs. Considering the diversity of American traffic signs, even for speed limits, I’m not surprised this feature is omitted from the U.S. vehicles.
    Mambo Dave, pilotgrrl and RCO like this.
  5. Elektroingenieur
    2,515
    3,283
    Three Touring
    I found a press release announcing that DENSO would be using a Toshiba image recognition processor in an active safety system for vehicles on the market in Fall 2015.
    Toshiba’s overview datasheet and catalog page says more about the TMPV7506XBG processor and its applications; the Video Input Interface section of the datasheet includes this information:
    I have no idea, however, if this is the chip used in the Prius.
    RCO likes this.
  6. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
  7. Elektroingenieur
    2,515
    3,283
    Three Touring
    To update this thread, here’s a link to the slides from a presentation on “Accessing Toyota Vehicle Control History and Collision Avoidance Data,” given at a seminar earlier this year sponsored by the Institute of Police Technology and Management:
    https://iptm.unf.edu/uploadedFiles/symposium/handouts/Ruth-AccessingToyotaVehicleControlHistoryandCollisionAvoidanceData.pdf
    The presentation includes some sample images from Toyota Safety Sense forward cameras, and it describes how to use a Toyota Techstream diagnostic system to extract and view the stored images and data. The required PCS Data Viewer application seems to be included only with versions of Techstream from techinfo.toyota.com, not with versions from toyota-tech.eu.
    I tried the procedure and didn’t find any stored images, but as slide 87 (PDF page 45) mentions, “For Images to be recorded and linked the VEHICLE must brake,” and I don’t think that’s ever happened on my car.
    alanclarkeau likes this.
  8. PixelRogue
    488
    86
    US
    Links go bad after a while....would be cool to attach images or pdf document.
    Out of curiosity, would law enforcement or insurance need permission to access this information?
  9. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    On a 3 year old thread, chances are not high you'll get a response from anyone that posted links in this thread.
    So if you don't get what you're looking for by clicking you'll need to dig deeper to find what you want.
    Here is a link that gets you closer to @Elektroingenieur s' link in his OP
    Continental Automotive | Homepage
    and this one for the 360 camera
    Continental Automotive | Surround View Camera Family SVC300
    Don't ya love how much they tell us about security and what is legally accessible.
  10. PixelRogue
    488
    86
    US
    Very kind, thank you. I am wrapping up the final details of these mods now...then take a brake before the next set. Yes, like it when photos and PDFs are included so they stay in place for the slower adopters like myself.... who was perfectly happy w/the Gen3 and only went Gen4 when insurance called it totaled.
  11. vvillovv
    4,321
    1,510
    NY
    Since you are interested in what the footage is like from the cars camera and if it can be accessed by whomever, at 1.3 Mpixels resolution I'm pretty sure it's not even going to be able to show a license plate on the car in front of you. But things are marching on and it wouldn't be too long before they'll be showing the wiskers on the driver 3 car in front and the nose hairs of the driver 4 cars behind and everything in-between. :coffee:
    Vision processing unit - Wikipedia
