2006 Prius Base Stock Radio - How to add aux or bluetooth?
Discussion in 'Gen 2 Prius Audio and Electronics' started by zlajac, Jan 22, 2017.
  1. zlajac
    zlajac Junior Member
    FL
    I just got a 2006 Prius and realized it has the most basic stock radio without AUX or BT.
    What is the easiest/cheapest way to add either aux or bt function?
    Aftermarket radio? Upgrade stock radio? Or just add some adapter?
    Thank you and I apologize if this has been answered before. I've been searching for days and couldn't find anything conclusive.
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    there is a grom adapter, if you don't mind the crummy base stereo.
  3. zlajac
    FL
    It looks like those adapters plug into the cd changer port, but my radio doesn't have a button for cd changer. It's the most basic one.
    It's like this:
  4. 69shovlhed
    2,170
    752
    Delaware
    I think there is an extra connector on the back of your headunit for an optional cd changer which mounted just below the headunit. that's where you'd plug in. really your better off replacing the whole headunit, cause that unit sucks anyway. but it will cost alot more than the grom.
  5. Ajourney101
    Ajourney101 Member
    127
    88
    Seattle
    With this unit, you can bluetooth your music from your phone to your car speakers through text radio station 87.9
  6. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
