What to check w/ used 2013 Prius
Discussion in 'Gen 3 Prius Main Forum' started by ZeroTX, Jan 21, 2017.
  1. ZeroTX
    ZeroTX Junior Member
    64
    Houston, TEXAS
    Hi guys,
    We added a second Prius to our family. My brother just bought a 2013 Prius Persona with 44k miles on the clock. Paint color is white with the dark gray vinyl interior, etc. This is in addition to my wife's 2014 Prius Five with now about 28k on it. On my wife's, we were still in Toyota bumper to bumper warranty, so we got some freebies, such as a new 12v battery (it was low), and they did the recall on the hybrid computer. I'm guessing this 2013 needs the recall done. Not sure, other than oil changes, if anything else should be checked. Car drives great and other than a scratched up front bumper, looks great (dealer is going to repaint front bumper).
    My Toyota dealer service guy says the Prius basically doesn't need much maintenance other than 10k oil changes (full synth) and periodically check the usual maintenance items. He says other maintenance items like brakes and tires, last longer on a Prius than on a Corolla or Camry. Less maintenance in general.
    I want to help my bro do a once-over on this one before he starts racking up miles. I expect he'll be keeping this car for a minimum of 6 years.Thanks for your input!
    -Z
  2. ZeroTX
    64
    Houston, TEXAS
    Ok, I'll add a couple of pictures of the car.... dealer pics, so of course idealized and you cannot see the very obvious scratches in the front bumper!
    jerrymildred and bisco like this.
  3. bisco
    52,337
    gorgeous, congrats! check/clean/replace air and cabin filters. all the best.(y)
    CNYhybrid likes this.
  4. ZeroTX
    64
    Houston, TEXAS
    Thanks! Anything else?? My brother is TERRIBLE with automobile maintenance, so I want to head off any issues at the pass.
  5. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Go by the owner's manual. Also suggest a transaxle drain and refill which you probably already know about. Best of luck to you.
    Raytheeagle likes this.
  6. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    I just bought a '13 Prius3 a few months ago from dealer. Certified, 20K miles, leased car.
    One thing I didn't check is the recalls. I assume that was done as part of certification.
    How long does the 12v battery last? Is it mileage or years?
    Mpg has dropped from 55 late summer to about 50 now in mixed driving.
    Eve Barbanell likes this.
  7. Mendel Leisk
    41,850
    Toyota USA says to do a brake service every 36 months or 30K miles. In the the Warranty and Maintenance Booklet. Maybe that was missed? Toyota Canada says to change the brake fluid every 36 months or 48,000 km's (30K miles as well).
    Strangely to me: it seems a lot of owners, and a lot of Toyota dealerships, seem to equate brake service with pad replacement. But in my opinion, and Toyota's as well, this is a periodic service that should be done, regardless of pad thickness remaining.
  8. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Yes the recalls will have to be done before the dealer sells the car, certified or not. And don't forget about the side curtain airbag recall, G0U
    iPhone ?
  9. ZeroTX
    64
    Houston, TEXAS
    I don't think that's true. We bought our used 2014 with recalls pending. It was not a Toyota dealership. Also, the "brake service" is really just an inspection unless they find something problematic (e.g. pad thickness or rotor issues). My Toyota dealer service told me that transaxle service should not be done until 100k miles....
  10. Mendel Leisk
    41,850
    Yeah there you go. ;)
  11. macman408
    1,179
    368
    I'd agree with OP's dealer that maintenance is pretty minimal. I've been doing my own; mostly just oil, air filters, and tire rotation once a year (or slightly more often, now that I'm going over 10k annually). Replaced the wiper blades after 6 years, and the tires at about 6.5/60k. One of the rubber covers over the shocks is cracked now, but it's my understanding that it's not cost effective to replace them. I think I topped off the coolant once, too.
    Probably at least 4 years, likely several more. Time takes a toll, mileage doesn't really - regular driving probably helps keep it charged, actually. Heat and cold do cause it to age though, as does draining it. I'm at 7 years on mine, and until 6 years, the voltage on it was the same as when it was brand new. I also live where it is rarely hot or cold, so I would expect to get more time out of it than most.
  12. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Well if a problem had been identified but Toyota had no solution available, then that's fine. But otherwise, in the OE dealer world, they must be done first
    iPhone ?
