Traction battery service?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kenster65, Jan 26, 2017.
  1. Kenster65
    Kenster65 Junior Member
    NYC
    I brought my 2010 in for the airbag recall and the dealer says I have a dirty cooling filter for the traction battery. He'll gladly correct this and perform battery "service" for my favorite customer price of $249. I know I could remove the back seat and do any service myself. Is there any "service" I really need to do?
  2. Mendel Leisk
    38,733
    You don't need to pull up the seat to access the hybrid battery fan (there is no internal filter btw). If you push open the gap between rear seat bottom and back, adjacent to fan inlet grill, look through the gap with a good light: there's a bolt holding the grill portion of seatback, 12 mm socket size I believe. Just use a ratchet wrench extension and you can back it out. Reach your hand in too, to hold the bolt when it comes loose: you don't want to drop it. Then you may well have to remove seat bottom to recover it.
    Then, in the hatch, pop up the rear portion of the floor over the battery. There's a number of tenacious fasteners, use pry tools gently, take your time. Most of them can be left off when putting things back together, the floor is still well secured with a few tabs.
    You need to flip down the seatbacks, peel carpetting off velcro strips, and I believe there's an additional bolt needs removing. Basically just follow your nose, pull off and clean the ductwork, and eventually you'll be down to the fan. It can be cleaned without removal from the car, not that hard.
    That's pretty much it, takes an hour at most.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  4. Mendel Leisk
    38,733
    Is that at inlet grill? 2010 Prius is a little different I think, no filter holder in the inlet grill. Maybe you'd need to swap grill too. Good idea though. I just put in a piece of window screen material on the inside, comparable in coarseness to Toyota's filter I think. I put it so it's bowing away, then put a couple of loops of thread through the screen and grill, to pull them together.
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    My error, I knew it was for gen 3, but no seller lists which years.
  6. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    Other than checking/cleaning the fan (which could be worth $250) I see no need.
    Put it this way, I have not done anything.
  7. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,222
    Madison, Wisconsin
    $249!!!!!
    Wow!
    I guess I've got to up my prices!
    Raytheeagle and bisco like this.
  8. mrbigh
    3,686
    699
    Long Island, NY
    the $249.00 You can call it an "Alternated Fact " for service
  9. Mendel Leisk
    38,733
    $30~40 would be reasonable.
  10. bisco
    49,504
    how many miles on her?
    can you tell if it's dirty without opening it up?
  11. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    Make sure they also replace the muffler bearings while they're in there. (y)
  12. Kenster65
    NYC
    Alternated fact. What a world we live in. I appreciate all the help. I'll take my time and do what you suggest. I am pretty sure I can find something else to do with the $249!
  13. Kenster65
    NYC
    But that's why they are called stealers. Oops, of course I meant dealers.
  14. Kenster65
    NYC
    75K and we're still on our honeymoon.
