2010 II keeps dying even with new 12V battery - "park on level ground"
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Atom30, Jan 27, 2017.
  1. Atom30
    Atom30 New Member
    Phoenix, AZ
    I've been the only owner of this car... it's at about 80k miles right now and on the original hybrid battery.
    About 6 months ago my girlfriend was driving it and got stuck at a gas station with the "park on level ground" message when turning it on, which we found was a symptom of a dying 12V battery. I was able to jump the car from another car and I replaced the battery and things were OK for a few months.
    Last month, she got stranded again with the same "park on level ground" warning, and was out in the middle of nowhere. After 10-15 minutes the car decided that it really was on level ground and started up without anything being done.
    Yesterday it happened again, except this time the car seemed totally dead. Key fob wouldn't unlock the doors so she had to use the key to get in, and then more of the same "park on level ground" business for 10 minutes before the car started up.
    What's going on? I don't think these cars have alternators and that would have been something I would look at if the 12V battery isn't getting recharged.
    Princer likes this.
    52,286
    welcome!
    two possibilities: the battery was not charged when installed, and has not been driven enough to charge it, or, you don't drive often enough to keep it charged.
    3) something is draining it.
    the 12v battery is charged by the hybrid battery, by way of the inverter/converter.
    tankyuong and Mendel Leisk like this.
  3. Atom30
    Atom30 New Member
    Phoenix, AZ
    OK, it's not option 1. I charged it completely when it was installed with a battery tender, and it is driven daily at least 50 miles.
    I used to have a bluetooth ODBII scanner plugged in but I removed that over a year ago. What else could be draining it fast enough that it would be showing these symptoms only 1-2 hours after being driven?
  4. bisco
    52,286
    nothing normal. you would have to put some type of meter on it to see what the draw is with power off and on, and get the spec from the service manual.
    any aftermarket electrical/electronics? alarm, remote starter, stereo/amp, etc.?
  5. Atom30
    Atom30 New Member
    Phoenix, AZ
    The dealership put on an alarm when I bought the car but I told them I hadn't requested it so they "disabled" it but it is still present. Wonder if that could be causing it... nothing else is aftermarket.
  6. Mendel Leisk
    41,826
    If you have a digital multimeter with milliamperes scale, you can patch it into the circuit in series, with the car completely shut down and quiet, see how much load there is. Doing this I found 15-20 milliamperes with occasional spikes to 40.
    You disconnect neg battery cable, connect to meter, and meter to battery. Start on amps setting, then switch to milliamperes if no reaction, just to play it safe.
    The clamp-on style ammeters are simpler I think: no need to splice in meter.
  7. Patrick Wong
    18,210
    6,511
    1. Check the battery cable tightness at the battery.
    2. Check the negative battery cable tightness where it is bolted to the body.
    3. Measure the voltage across the battery first thing in the morning, before the car has been driven, and report your findings.
    Raytheeagle likes this.
  8. ChapmanF
    18,458
    The most common clamp-on pickups, though, are only good for AC (which can induce its own voltage in a surrounding coil). To measure DC takes the less common, powered, Hall-effect style of clamp. I've got one, but it's kind of an industrial gadget sized for large currents. Anything smaller than about 4 amps tends to be hard to measure with any certainty, though sometimes I get a little closer by clamping it both ways and averaging the readings.
    So for the kind of small currents you're looking for in parasitic drains, it really works best to insert the meter in the circuit.
    One handy tool I found for that is the "Fuse Buddy", and I picked one up recently:
    Disappointingly, I found its wide shoulders (just above the mini-fuse-sized snoot) won't let me get it into the fuse slot I needed, because of a bracket Toyota stuck right next to the fuse box. But I took the Fuse Buddy apart and it looks like there's enough room to trim those shoulders some (then cover with Plasti Dip for insulation) and see if I can make it fit.
    -Chap
  9. heyjack70
    heyjack70 Junior Member
    25
    Look up a youtube video for how to check parasitic draws/drains. Also, take the battery by an autopart shop to have it tested. Sometimes new batteries fail, that's why there are warranties.
    Princer and bisco like this.
  10. bisco
    52,286
    good point. might as well make sure the battery is healthy first. a simple fix, compared to trying to find a parasitic drain.
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Also, while you're checking for tight connections, make sure there isn't any corrosion, especially where negatives connect to body or other steel parts such as the negative wire off the battery to the body.
    Princer likes this.
  12. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Also measure it after the car has been started.
    If the second reading is not considerably more than the first.......at least a volt higher.....then your 12 V converter has failed.
  13. Atom30
    Atom30 New Member
    Phoenix, AZ
    OK, thanks all. I'm guessing it is loose connections that probably happened the first time and definitely loose connections after the battery replacement. The metal bracket that holds down the battery was very loose, as were both the connections. Is that a normal consequence of driving on non-pristine roads?
    I also don't know how loose connections would show up as not working, then after 10 minutes working.
  14. jerrymildred
    11,517
    14,157
    Tampa, FL
    Actually, that's a good indication of a loose connection. And rough roads can loosen a connection if it wasn't tight enough to begin with. In fact, they'll do far worse than that. Nine years of driving in Honduras taught me all about that! :cool:
    Princer and rebenson like this.
  15. Atom30
    Atom30 New Member
    Phoenix, AZ
    Alright, I guess we do take our Prius off pavement quite a bit more than it's probably designed for. Thanks for the help!
    Princer likes this.
  16. Sam Spade
    2,036
    1,023
    2017 Prius c
    Look up the definition of "intermittent". :)
    It's quite common with electrical things.
    But you still need a meter to check the voltage, partly because the intermittent connection could be INSIDE the battery itself.
    jerrymildred likes this.
  17. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    Thanks for the thread. I had a similar issue with my 2010 Prius (purchased May 2010)
    I had an issue where it was basically dead at a parking garage and gave a tone error for long period and was un responsive. Gave error about being parked on un-even surface .... I tried jumping the car to no avail and was going to have it towed home. Guy came and jumped it (I had to show him how to do it since never jumped a Prius before) and it started up very quickly for him.
    We drove all the way home with no issue except some of the console wout not read out properly.
    Put it on a cheap charger that night and worked great.
    Yesterday morning same deal, but no time to fool with it so took backup car and dealt with it last night. Battery was dead so I charged it and it finally got charged late last night enough but now getting the message to use park and message won't go out.
    Hopefully will get the thing so I can get it to a dealer and don't have to have it towed.
    Jim Bob Khooter likes this.
