Charging Inlet Cap
Discussion in 'Prime Plug-in Charging' started by ukr2, Jan 29, 2017.
  1. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    What is the purpose of the Charging Inlet Cap?
    It keeps stuff out of the Charging Inlet? Sure.
    However, the Charging Port Lid can close and protect it.
    The Cap is a waste.
    You're suppose to move it from the Port to the right and not let it dangle against the car.
    After charging, you have to move it back over the Port or you can't close the Lid.
    The old Prius has a protective ring on the lid, that encircles the port when the lid is closed.
    I, instead, wish the lid opened vertically to keep snow and rain out of the port
    bisco and thatoneraccoon like this.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Not from water.
    That wouldn't do it if the precipitation were wind-driven, as it often is.
    thatoneraccoon likes this.
  3. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    I do miss that on the volt, it had the protection on the lid so when the lid closed it sealed the port. Where my prime does not have that, but im getting use to it already and not a big deal. and as a plus, ive noticed the prime has a light, a button to lock the charger and the light lights up when you walk up too it with out touching anything! my volt had none of that, lol.
  4. bisco
    51,851
    you can see how people who never owned a pip make incorrect assumptions. no idea why they added the cap. maybe because they added the chademo charge port in japan and we didn't get it.
  5. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Do some countries have 2 Charging Ports? What do they do for Port Caps?
    So instead of designing a Single Port, they added the Port Cap to use the space?
  6. thatoneraccoon
    201
    146
    Ohio
    man, could ya imagine how fast the prime would charge with a fast dc connector, that be awesome
    and I wonder if the port caps would just hang down? I wonder if can find pictures of the japan version somewhere
  7. bisco
    51,851
    i can't remember, but it was described in the run up to the release in one of the overviews. japan has mostly 100v at home i think, and dc commercial chargers or something.
    they also get the output house power as well, i believe.
