Are my windshield nozzles frozen?
Discussion in 'Prius c Technical Discussion' started by chavu, Jan 30, 2017.
  1. chavu
    chavu New Member
    Midwest
    Hello,
    I just purchased a 2013 Prius C One a few days ago, and unfortunately the windshield nozzles aren't spraying (although I do hear the pump buzzing away). I do live in the midwest, and it's been bellow 25 deg for the past few days. How would I go about "unfreezing" them? Also, would it be a good idea to empty the reservoir to replace the current stuff that's in there? If so, what would be the best way to empty it?
    Thanks!
    51,502
    congrats and welcome!
    hard to say what is wrong without testing. certainly, they could be frozen if someone put plain water in the reservoir.
    start there, if the fluid in the reservoir isn't frozen, than that probably isn't the problem.
    you'll have to pull the tube off the reservoir at the discharge end, and see if the pump is working.
    if it is, then there is a clog or frozen line. unlikely that both nozzles would clog. you'll have to bring the car somewhere warm to melt the lines, or maybe a hair dryer at the nozzles.
  3. chavu
    chavu New Member
    Midwest
    The car was previously titled in Southern California, so I have a suspicion that the fluid in there was only rated for 32 degrees and above. I'll have to take a closer look at the reservoir when I change the oil later today. Thank you for the suggestions!
  4. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    And consider home brew windshield solutions.....what some people do to save money
  5. Mendel Leisk
    40,940
    That'd be my guess. Maybe siphon out as much as you can and fill to the top with freeze protected. If you can get it in somewhere warm for the oil change that'd help too.
  6. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Look in the reservoir. If it is not frozen, you don't have to worry about that right away.
    The nozzles will sometimes freeze even when you are using the right stuff.
    Only safe way to fix the problem is to get the whole car inside so it warms up.......and then run the washers several times.
  7. Mendel Leisk
    40,940
    If you're at the dealership getting stuff for the oil change, Toyota makes a decent windshield washer fluid, says good to -40F I believe.
    (You have to take the claims with a grain of salt, though.)
  8. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    The water in the nozzles will freeze before the water in the reservoir, so if the car hasn't been in the cold too long then the fact that the reservoir hasn't frozen doesn't rule out the possibility that the nozzles have.
  9. bisco
    51,502
    i've never had trouble with cheapo depot ww fluid, down to zero f.
  10. chavu
    chavu New Member
    Midwest
    nozzles and/or lines were definitely frozen. Sprayed perfectly after sitting in my friends garage for a few hours. Went ahead and used the remaining fluid and topped it off with the better stuff. Thanks again guys!
  11. Kenny94945
    Kenny94945 Active Member
    844
    421
    Sausalito
    2016 Prius v wagon
    Heat gun to the nozzles and lines.
    Add some hot water/ cleaner to the reservoir.
    Yes, Toyota fluid instead of aftermarket next time.
    (GM Optikleen concentrate is also a great product.)
    Some times aftermarket product formulas have a soap that will clog a system.
    Last resort....insert a needle to the nozzle.
    Good luck.
  12. Mendel Leisk
    40,940
    Inserting needle is how you aim some Honda nozzles; it's the only way to get a purchase on them. The nozzle's a little recessed ball in socket: you insert a needle and then use it as a lever, to nudge the ball to a new position.
  13. Sean Nelson
    421
    182
    That's been pretty common in many of the different makes of cars that I've driven.
  14. Mendel Leisk
    40,940
    Good to put miniscule bead of silicon spray (or WD40, what have you) on the ball joint first too, they can get a little glued.
    Sean Nelson likes this.
  15. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    When we lived in the Pocono's I would just add a little rubbing alcohol to the washer fluid. Just shake it up good so it mixes. Don't go crazy though you don't want to ruin the paint.
  16. Mendel Leisk
    40,940
    Even straight isopropyl is fine; that's what I use before touch up painting. But for washer fluid: I just get the right stuff.
