When to replace water pump
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Doc Willie, Jan 30, 2017.
Tags:
  1. Doc Willie
    1,717
    144
    Out there, somewhere
    My 2007 all of a sudden had no cabin heat, and the temp indicator was behaving erratically. I took it to the shop and they said there was a loose radiator cap and air had gotten into the system. They bled the system and it is working fine.
    The shop said it needed a new water pump, but did to tell me how they made this determination. So is it time to replace it anyhow (170,000 miles)? I am going on a long trip in a few weeks.
    Replace or wait?
  2. b100
    b100 Member
    145
    75
    Netherlands
    If it ain't broke don't fix it.
    It was a loose radiator cap. Keep an eye on your coolant level and possible leakage underneath and your ears on noises.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I wouldn't be surprised. Mine was leaking at 149k. If you look underneath, you'll see a pink crust where any leaks have dried. You'll probably have to flex some of the plastic away to see up there. I don't know for a fact, but have heard that that crust can partly close off a leak until the leak gets bad enough and then let go and suddenly become a much bigger leak. Then again, you might be ok for lots more miles. It's a bit of a crap shoot, I think.
    valde3 likes this.
  4. ETC(SS)
    7,309
    Replacing items before they need to be replaced isn't.........efficient, so MY answer to the question is, "when it fails."
    Water pumps usually do not fail catastrophically.
    There will usually be some leakage (tattletale leak) or a whirring sound from the pump before it goes Tango-Uniform, so you can look and listen for that.
    Cars are going beltless these days, so the above statement might not apply.
    Since the soulless nebbishes at Toyota do not think that you need a temperature gauge, I would strongly recommend that you immediately drop out of warp if you have indications that things down in the engine room are getting warm.
    Warp coils aren't cheap.
    How did your radiator cap get "loose?"
    Fern1461 likes this.
  5. Gnarly
    Gnarly Member
    142
    44
    FYI, coolant is important to an engine.
    Water pump is important. You don't want your car to overheat all the time.
    You could end up with a cracked head after a 100 miles.
    We got ours replaced on the 05 and it cost us $350 parts and labor.
    Or $4,000 for a new engine without labor.
    Good luck.
  6. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Doc,
    If the waterpump had been the cause (impellers broken/worn/loose) it would not have heat NOW, because they did not replace it.
    Now, it is possible that the WP seal is leaking/weeping and the coolant loss caused the circulation system to become inefficient and/or have air trapped in it. If there is evidence of coolant on the WP seal area, replace it NOW.
    Barring any of the above, where did the coolant go that allowed air into the system and who took the cap loose????? These cars have a "degas bottle" between the rad and engine, THAT is the ONLY place one needs to check/add coolant to the vehicle unless the system is breached.
  7. knettle3
    knettle3 Junior Member
    zachary
    I replaced the ICE water pump at 190,000 miles in my 2008 Prius pre-emptively because I had an upcoming trip approaching and that amount of mileage is an accomplishment, in my experiences with water pumps previously. With me, this critical engine part has failed me at the worst possible times- without much notice. If you change it, make sure it's a genuine Toyota water pump-- not some Chinese knock-off. I kept the old one as a spare. The OEM part was $62.00 plus tax and the Toyota pink antifreeze concentrate was $23 a gallon. The ICE water pump is a "wear" item, as far as I'm concerned, and they do not last forever. Maybe a few Prius owners here on PC can prove me wrong on this assumption:). My car was due for a coolant change and a new belt for the pump, so was a perfect time to do the job on my terms-- not because of a breakdown with possible engine damage. Once an aluminum engine is severely overheated, it is never the same.
  8. 05PreeUs
    1,097
    565
    MSP
    Ditto. Found low coolant one day and the belt was getting questionable, so did them both. Turned out the pump was leaking, v e r y s l o w l y though.
  9. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    Factory part costs $75 full retail ($55 discounted). It takes about 30 minutes to replace. Dealer price is about $50 for the factory pump so they basically charged $300 for 30 minutes work.
