... medicine man say don't close-um door on Gen II front pad voodoo rain dance ~
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by asjoseph, Jan 30, 2017.
  1. asjoseph
    asjoseph Samuel, '04 Ruthiemobile
    97
    34
    117
    lancaster, california
    ... goodness, gracious! Have a look-see, if and when you find time:
    Toyota Prius Front Brake Pads Replacement Guide - Gen III 2010-2015 Model Years - Picture Illustrated Automotive Maintenance DIY Instructions
    As per the author's instructions, actuation of the driver's door pressurizes its hydraulics? Implication being, we don't close the driver's door until (1) we've disconnected the negative terminal, or (2) we leave the driver's door opened, the entire duration of the brake job?
    I'm not exactly clear on when it's okay to close the door?
    My other question with regard to installing fresh brake pads: is it in the next room? dig a whole and bury it in the backyard? perhaps somewhere across town? Exactly how far away does my effing key FOB have to be, from the vehicle? Couldn't I just hit the button below the steering column, deactivate smart-key, until I've reconnected the negative cable?
    Holy mother Mary of Christ behold thy unworthy servant, about to zap himself with 24 thousand volts because I lacketh structure - Samuel, '04 Ruthiemobile.
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I do not know about the Gen III, but with my 2009 Gen II, I find it best to close (and lock) all the doors just before I start driving, particularly if I'm in a bad part of town! ;)
  3. asjoseph
    97
    34
    117
    Boiling this down to a nutshell, what I've gathered, over and above what's prerequisite to a conventional brake pad replacement, germane to Gen II Prius brake pad replacement:
    1). Turn vehicle off; open hood; open driver's door -
    - whatever you do, don't close the door?
    2). vehicle must be turned off a full two minutes -
    - to depressurize hydraulics; takes 2 minutes? exactly?
    3). Don't close the driver's door -
    - closing the door automatically pressurizes the vehicle's hydraulics? (e.g., no specific given with regard to whether the driver's door stays opened the duration of brake service; left to assume door stays opened until the negative cable's disconnected)
    4). key FOB can’t be anywhere near the vehicle -
    - presence of the key FOB automatically pressurizes hydraulics? (e.g., no indication whether deactivating smart-key will suffice).
    5). negative terminal on the battery must be removed -
    - careful not to close the trunk-lid, with the negative cable disconnedted!
    6). Both ABS fuses in the fuse box must be removed -
    - unclear what benefit removal of fuse is to be derived, with the negative cable detached?
    Forgetting to do any one of the aforementioned blows the brake actuator; a cool US$1,600.00; error codes will light up the idiot lights on my dash array like a gay parade?
    Okay, then. Guess I'm ready to go. Should be done in an hour - Samuel, '04 Ruthiemobile
    #3 asjoseph, Jan 30, 2017
  4. Mendel Leisk
    41,255
    What happens when you open the driver's door on your second gen? Do you hear a whirring sound? That's what you want to avoid. If the caliper is off when that happens, it could well pop a piston.
    So I'd say keep the driver's door closed. That said, on third gen, I've had the calipers off a couple times, and yeah: just disconnect the negative cable at the battery works.
    Also, no offense, but maybe edit your thread title? o_O
  5. asjoseph
    97
    34
    117
    ... done!
    I disabled smart-key, then powered down, tossed the key FOB inside by the coffee pot, waited the prescribed 2 minutes, closed the driver's door after disconnecting the negative cable, then performed a conventional pad swap like I would, any other vehicle. Not a compelling argument, pulling the ABS fuses, I didn't bother.
    Everything cinched up, 68 foot pounds on the lugs, torquing up to 78 ft.lbs once my trusty Ruthiemobile was back down off the jackstands, powered back up, no drama, everything's just fine.
    Man-oh-man, that's as close as I've ever cut it wearing those old pads. Going gingerly, being a slow poke, coasting off everywhere these last few months really paid off. I knew those pads were getting down there. When I pulled them off, they were down to nearly nothing.
    Best thing I ever bought, my universal's worth its weight in gold. I've seen professional mechanics depressing those pistons back into the calipers, no clamps or tools, whatsoever. I just don't have the hand strength. So far to go, retracting those caliper pistons, no way I could done it, without my universal.
    Thanks to you guys, that was pretty easy! I'm good to go! - Samuel, '04 Ruthiemobile.
    #5 asjoseph, Jan 30, 2017
  6. dolj
    dolj Senior Member
    8,408
    4,281
    Wellington, New Zealand
    Actually fortuitous this thread coming up, because I had the same sort of questions as I prepare for doing a brake service.
    From what I understand, and please correct me if I'm wrong—because I don't know, and I want to know—but is only necessary to do one of these, not both, correct?
    Even though asjoseph elected to pull the neg off the battery, I'd rather not.
    Also, I'm not convinced one needs to do 1, 3, 5 and 6, but I could be a victim of my own ignorance. If it is necessary to remove the negative, why is it also necessary to then remove the 2 ABS relays; and is there another fuse or relay to disable the accumulator pump, if this is not disabled with the removal of the 2 ABS relays?
    So, can some of the wise sages here answer this conundrum? Much appreciated.
    PS, I don't have SKS, so I don't need to worry about the key fob. But I would have thought turning it to the off position on the steering wheel switch would suffice for that one.
  7. asjoseph
    97
    34
    117
    ... sure. Be my guest! Go right ahead! I double dog dare you, just dive in. Wing it. Don't disconnect anything. Just leave that-thar negative terminal, connected.
    See what happens.
    Blighted courtship rituals, never having known life without a computer, their very existence hinged upon their handhelds, clinging to connectivity, they grew up solving every problem in life, pushing a button. Prescribed doctrine they flush, right down the toilet; averse to anything sequential, they have no reverence for the constraint of following instruction.
    Case in point, as of this writing, this poor Gen-Y chump's still working on his first 100 thousand you-tube hits, from having hopelessly effed-up his once proud Gen II asunder:
    None too proud, confidence shattered, here's hoping he hasn't regressed to bed-wetting - Samuel, '04 Ruthiemobile.
    #7 asjoseph, Jan 31, 2017
  8. Melchior
    Melchior Junior Member
    74
    Netherlands
    asjoseph - I like your artistic writing style :)
    Are we saying, as conclusion, that the only thing you really need to do is disconnect the 12v battery? If that's done, we don't have to worry about the keyless key being in the next county, the door being opened or closed before or during the procedure, disconnecting relays, fuses etc.? Logic certainly tells me that if the 12v is disconnected, we need not worry about any 12 systems doing anything at all. Because, how can they? Right - they can't. Can they?
    Might this be a good moment to ask about the rear pads? Is the procedure the same?
  9. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    The Prius has a capacitor storage system at the aux battery for 12V braking power. Traditional power brakes have a vacuum storage system for a couple of brake applications if the engine dies, this serves the same purpose for the all-electric Prius system.
    In the US, we have rear drum brakes.
  10. Melchior
    74
    Netherlands
    How long does the capacitor hold charge? Is there a way to manually discharge it?
    I thought it was only the earlier Gen 2's which had drums in the US. Do they all? If so, is there a special procedure regarding disconnecting 12v, relays etc., when working on the drums/shoes? I would assume the same procedure would apply to rear disk equipped Prii.
  11. andrewclaus
    993
    326
    Golden, CO
    Don't know, but I guess that's why it's recommended to disconnect the negative battery cable for brake work. I haven't had to do that yet, so I haven't paid it much attention, but I think that should address all concerns and it's very simple.
    My '07 has rear drums. I don't know if later US Gen 2 models have rear disks. I hadn't heard that.
    With the regen braking and my driving profile, my friction brakes see hardly any duty, so brake work is not on my radar. I have replaced the brake fluid a couple of times, and that's a little complicated since you need to run the actuator pump.
  12. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    Oh PLEASE tell me (us) you did not push that old nasty brake fluid backwards into the HCU!
    One should NEVER EVER push caliper pistons into their bores without the bleeder screw being opened to allow that old and stagnant fluid OUT of the system. This is especially true on vehicles with ABS and an order of magnitude more important on those with HCUs like a Prius.
    Unless you have Techstream and can VERIFY the brake accumulator pressures are ZERO, it would be most wise to assume that the caliper piston(s) can eject themselves with GREAT FORCE and velocity at any time. Yea, I know that with the 12v disconnected it is theoretically impossible.... yet Bees do fly.
  13. Mendel Leisk
    41,255
    With 3rd gen you can put the car in "invalid mode" for bleeding, circumvent the need to for Techstream.
    I've pushed pistons back without opening bleed screw being opened, for donkey's years. Not saying it's good, just worked out ok, so far. I do keep on top of brake fluid changes: every 3 years.
  14. dolj
    dolj Senior Member
    8,408
    4,281
    You may have a point, but if the brake fluid is "old and stagnant", would you not just do a brake flush after you've reassembled the brakes?
    Do you care to elaborate with some detail for those of us who don't really know what you mean? Like the ins & outs and whys & wherefores.
    Thanks.
  15. bisco
    51,811
    all u.s. gen 2 have rear drums. 2004-2009. the only thing gen 3 rear discs introduced were problems.
  16. 05PreeUs
    1,097
    564
    MSP
    Sure.
    Q: Why open bleeders when changing pads?
    A: Part 1 - Everyone knows about gravity and settling of dirt in liquid, it will go to the LOWEST point - the brake caliper or wheel cylinder. Also, while fluid flows INTO these parts, it does not recirculate, so the fluid and any contamination in it stays in these parts. Brake fluid is Hygroscopic - it readily absorbs moisture from the atmosphere which lowers the fluid's boiling point from 400*+ to something close to 250*F. Brake temperatures of 250* are a lot easier to obtain than one might think, making this a dangerous proposition.
    Part 2 - Because brake fluids absorb moisture and some components are made of ferrous metals (steel, iron etc), as the moisture content in the fluid increases, RUST becomes a potential problem. On almost every road-going vehicle, the calipers are made of cast iron, when combined with a moisture rich fluid, you get rust formation on the walls of the caliper bore. This rust is very slight and typically does not cause pitting, but when you push the pistons back into their bores, this rust coating is wiped off and forced backwards into the rest of the brake system (ABS unit, HCU and Master Cylinder). None of this is a good thing and unless you like very expensive repairs and so is something to be avoided at all costs.
    Q: Why ensure the HCU pressure is "0" prior to brake system work?
    A: Pressures in the HCU can be 2000 psi an more. These systems are designed to apply brakes ELECTRICALLY during NORMAL operation and based on brake rod stroke, not on the actual pressure applied to the brake pedal - the PRESSURE generated is not by your foot, but by an electric motor. The brake fluid is pressurized by a pump and retained in an accumulator at nominal system pressure AT ALL TIMES. This means that full, unregulated brake system pressure is available at the speed of electrons, WITHOUT moving the brake pedal. There are safeties built into the system to: Provide braking should the HCU system fail, minimize the risk to service persons, and provide alerts in the event of a malfunction. Not a single one of those safeties are "fool proof", therefore it is *possible* for an unintended application of FULL SYSTEM PRESSURE to be made while a caliper is removed for pad replacement. This would result in in caliper piston(s) being ejected at high velocity and under extreme pressure; a VERY dangerous situation that could easily KILL.
    Now, if you add pushing old stagnant brake fluid backwards into the HCU, where the potential for minute rust particles to jam parts of the HCU's valving to having full system pressure stored in the accumulator, you have the potential for a VERY DANGEROUS situation.
  17. dolj
    dolj Senior Member
    8,408
    4,281
    Thanks John, appreciate the time and effort you have taken in relying.
    Cheers.
