Reservoir tank spitting out coolant
Discussion in 'Gen 2 Prius Main Forum' started by franken1313, Feb 1, 2017.
  1. dolj
    dolj Senior Member
    8,401
    4,279
    Wellington, New Zealand
    That's what I'm thinking, too
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    I think he NEEDS to have a shop look at this to be sure what is going on, since he definitely doesn't seem to have much mechanical knowledge.
    While the "sky is probably not falling", it could be something really serious........and continued driving might be a disaster.
    edthefox5 and jdcollins5 like this.
  3. franken1313
    franken1313 Member
    216
    26
    US
    Which is the gasoline water pump? Can you send me a pic or a link???
  4. dolj
    dolj Senior Member
    8,401
    4,279
    Take a look at the first post in this thread: Belt change how-to with photos
    Although it about changing the serpentine belt, it shows quite clearly where the ICE coolant pump is located.
    The photos are taken from beside the right fender looking towards and down to the engine block.
    hope this helps.
    m.wynn likes this.
