Wierd sound coming from underneath rear after parked in garage for six hours
Discussion in 'Gen 4 Prius Main Forum' started by jtg61, Feb 5, 2017.
  1. jtg61
    jtg61 Member
    46
    43
    Ocala FL
    I went into my garage about six hours after I parked my Prius and I head a weird humming sound coming from the rear of the vehicle where the Lithium Ion batteries are. It sounded like maybe a fan was running, I'm not sure. It just seemed really weird that anything would be running under the rear of the vehicle six hours after I parked it in the garage. Why would something be running on my Prius after it was parked for so long? Any ideas? Is it something I should be concerned about?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    No idea really - did you have your smart key in your pocket? And was the car locked?
    If I have the key in my pocket and walk past the car - if it's at night, I can see the interior light turn on. My hearing isn't real good - so I'm not sure about noise - but it sure knows I am there.
    Data Daedalus and RCO like this.
  3. jtg61
    jtg61 Member
    46
    43
    Ocala FL
    No smart key in my pocket. I was in my garage getting beer out of the fridge when I hear the buzzing sound coming from underneath the rear of the car, like an inverter or fan was running hours after it was parked. Never heard this sound before.
  4. bisco
    52,390
    it's an evap check for pollution control. weirded me out the first time i heard it. can you say 'christine'?:sneaky:
    RRxing, kithmo and jtg61 like this.
  5. jtg61
    jtg61 Member
    46
    43
    Ocala FL
    It runs this check hours after you've parked your vehicle? Very weird, but good to know it's normal. Thanks!
    RCO likes this.
  6. alanclarkeau
    7,045
    7,593
    how long did it go for? Your fuel tank is different from ours here. Ours doesn't have the pressure lock or whatever it's called.
    RCO likes this.
  7. bisco
    52,390
    right? not sure what the delay is for, maybe it's some kind of leak down test.
    RCO likes this.
  8. jtg61
    jtg61 Member
    46
    43
    Ocala FL
    It ran for about 5 minutes and then stopped. I've gone out to the garage periodically and haven't heard it since.
    RCO and alanclarkeau like this.
  9. bisco
    52,390
    same here, you have to time it right. i've only heard it a few times in almost 5 years.
    RCO and jtg61 like this.
  10. Colin Jones
    Colin Jones Member
    99
    174
    Aberdeen/UK
    Business Edition
  11. ETP
    2,803
    1,170
    Auburdale FL
    It needs beer.
    MIkeDr and Sooner Al like this.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    It was humming because it had forgotten the words :LOL:
  13. sorka
    sorka Active Member
    1,030
    199
    Merced, CA
    2019 Prius
    Mine 2019 does this nearly daily. It's doing it now and has been going for hours. Worried that it's going to drain the 12v battery....unless it runs on the main traction battery?
  14. ChapmanF
    18,545
    I'm sorry I don't have the 2019 Repair Manual handy. This is the timing chart of the evap self test from Gen 3. Adding up the times along the bottom shows the whole test is done in 23 minutes 10 seconds tops, with the leak detection pump running most of that time (all but the first minute). It's a small pump and runs on the 12 volt system and Prii have been doing it for years without issues.
    Again, I'm looking in a Gen 3 manual, so it's possible they changed something for Gen 4, but "hours" definitely doesn't sound right.
  15. Colin Jones
    Colin Jones Member
    99
    174
    Aberdeen/UK
    Business Edition
    The manual also states this though:
    "Approximately five hours after the hybrid system is turned off, you may hear sound coming from under the vehicle for several minutes."
    pilotgrrl, krmcg and Mendel Leisk like this.
  16. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    I suspect if your Prius detects your smart key when you walk close by, and reacts accordingly by turning the interior lights on, it will automatically begin to prime the vehicle “for lift off” so to speak.
    Even my old 2008 Gen 2 without the smart key (UK) will initiate a pre-startup sequence (charging the brake master cylinder I think), as soon as I open the drivers door.
    I think this is perfectly normal and every version of Prius does something like this.
    Whenever I’ve got home from my commute, parked, got my stuff out of the trunk and I’m walking to the house, my Gen 2 proceeds to make a series of distinctly peculiar noises somewhat akin to the Millennium Falcon venting plasma after it has landed, and the crew are walking away.
    I look back half expecting it to be venting gasses like that fictional YT-1300 Freighter. The noises never fail to mildly amuse me though .
    Your Prius is perfectly fine, and doing exactly what it’s been programmed to do…..
    Source: iPhone 12 Pro Max 512GB ? Pro
  17. BellevilleMXZ
    BellevilleMXZ Member
    72
    61
    Ontario,Canada
    2024 Prius
    Limited AWD-e
    Evap. system(charcoal canister and related parts that capture fumes from fuel tank) doing a test. I noticed its even mentioned in my manual
