What Did You Do To Your Gen II Today?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by romad, Oct 26, 2014.
  1. Abdulaziz_Barham
    Abdulaziz_Barham Junior Member
    68
    Jordan-Amman
    Three Touring
    Do you have Totachi oil in USA ?? it is Full synthetic and perfict for Prius gen. 2
  2. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
  3. Don Shouse
    Don Shouse Junior Member
    Tacoma Washington
    Nice! Welcome to the club!
  4. BaccaPME
    BaccaPME New Member
    US
    Replaced melted rear handle and switched case on broken key fob
  5. Cat_Prius
    Cat_Prius New Member
    Lafayette, Indiana
    Drove to the store for some survival snacks before the snow hit. I was hoping for more snow though. :(
  6. b100
    b100 Member
    145
    75
    Netherlands
    Tested the top speed im germany (no speed limit) for the 6st time... still 180km on the speedometer....not a singel km faster... limiter
  7. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    I started on my spare set of taillights so I can start painting them like my headlights. Took the lens apart with a Hot Soldering knife. NHW20_Prius_Custom_Tailights.jpg
  8. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    I did that the other day in maintenance mode - the speed limiter is not removed in this mode either. Top out at 107mph..
  9. Enzo Batkhuu
    Enzo Batkhuu Member
    31
    254
    Ulanbator Mongolia
    Four Touring
    happy new year :)
    Emblem changed :)
    Property of Umbrella Corp
    NOLA_Akita, Valentin84, ZFL and 5 others like this.
  10. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    I replaced both of my cracked fog lights and installed blue bulbs in them. aside from looking cool, I can see better than with the old, cloudy, cracked lights. I think I need to spring for some LED bulbs next.
    Spaysship24 likes this.
  11. offib
    offib Member
    162
    95
    Dublin
    Four Touring
    In the last 24 hours...
    Got 56.1 imperial mpg on just over 3/4 of a tank, whi h Google tells me is 67.3 mpg in the states... Good?... It also just crossed over 146,000 miles.
    Parked beside a Gen IV Prius in the same colour, 'cause for the craic :p. Though, I've never seen one in person. It looks really normal, like most new Hyundais or Asian cars on sale. I'd honestly prefer the Gen II given the more windows and visibility it has behind the passenger door.
    But, there's something that's been bugging me and other Irish drivers here who brought their car to the NCT (vehicle road worthiness test, like the MOT). There are no emissions guidlines given by Toyota. Mainly because, emissions testing requires a low and a high idle. We know that's not doable without a tachometer, and due to the PSD it's physically not possible to do a high-idle test of 2000 rpm. The engine rpm peaks somewhere aroud 1700 rpm at rest.
    Regen braking also skipps over the whole brake and brake balance tests.
    It passed flawlessly and she's now road legal for another 2 years, but it doesn't feel right, you know. It's not telling me how the engine is really performing when it comes to its emissions. It's old after all. I would only know until I get a CEL regarding the emission system.
    There's so many damn Zeros on this sheet!
    #171 offib, Feb 6, 2017
  12. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Last Saturday I did some upgrades. One of my headlights had some serious condensation issues so I decided to replace both and use LED bulbs. I had to modify the boot/dust cover to make the fans fit. I also installed after market fog lights and used LED bulbs for those as well. There was some issues about getting the wires through the firewall so I finally decided to go through the air conditioning evaporator exit hose and than up behind the back of the center panel. The best part was since the bumper was off I put on trumpet hella horns. I've included some pictures as well 20170211_085111.jpg 20170211_085146_001.jpg
  13. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Also I did do a small interior modification, this past October to the center console arm rest. The original was stained and coming up on the edges. As I was trying to glue it back down I had an idea. I cut out a piece of my old seat cover and I glued that on. Now it matches my interior pretty good and it has a little bit of cushion
    Spaysship24 and Justdidit like this.
  14. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Now it just seem like I like to see myself post, but I finally finished off my project. The original switch from the fog light kit seemed way to big so my electrical engineer friend helped me install a different kind of switch which we later found out was faulty. The LED indicator on the switch itself was blowing out the fuse for the foglights. So I looked on the Internet for a switch to fit a Prius. I purchased an advertised OEM toyota fog light switch and a scion aftermarket with the same dimensions that is listed to fit a prius with "slight shaving" So I hacked apart the hole and barely fit the Toyota one in, looks like leftovers from 90s toyota but all things considered a decent fit after some work 20170213_153403.jpg 20170215_135533.jpg 20170220_231019.jpg 20170220_232401.jpg
    Justdidit likes this.
  15. Spaysship24
    Spaysship24 New Member
    US
    Nice job with that! I had a really grungy console cover and it was peeling off too. The replacement part is $50 so you saved good dough!
  16. Tomek310
    Tomek310 Junior Member
    89
    Riverside
    Never heard of it.
  17. Tomek310
    89
    Riverside
    Installed Rexing S500 dash cam yesterday. Put the rear camera under the rear window. I'm now able to see whose behind me more clearly.
  18. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    Installed Progressive rear sway bar today. Took about 10min.
    Last week I replaced 1 bad battery module took about 3.5hrs
    offib likes this.
  19. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    This thread needs more pictures...
    ZFL and offib like this.
  20. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
