Contract ID
Discussion in 'Prime Main Forum (2017-2022)' started by thm8d, Jan 18, 2017.
  1. thm8d
    thm8d New Member
    Garden Grove, CA
    Anyone else having issues with their contact ID? I've contacted Entunes and Toyota but they're giving me the run around
  2. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
  3. Pizza Driver
    Pizza Driver Active Member
    158
    156
    United States
    I had no issues getting a contract ID number. Just press your SOS button to register the car. Getting Entune to accept the ID number, however, took a while. Their IT people had to mess around for about a week to associate my contract ID with my car before I could get the Prime Apps to work.
  4. ruby
    ruby Member
    130
    78
    I couldn't get my contract id to be accepted from the entune phone app. I logged into myentune.com from my computer, entered the contract id there, and then it all worked fine after that.
    Edited to add: this took a couple of days of trying different things with the phone app before finally trying from the computer.
    #4 ruby, Jan 19, 2017
    BlueMagnet likes this.
  5. dalcon95
    512
    653
    The problem I had was the Entune app to except my Safety Connect Contract ID. As I said before, it took a month for the IT department to fix it.
  6. thm8d
    thm8d New Member
    Garden Grove, CA
    I've spoken to 3 different reps and they all gave me the run around to "enroll" into the service. I already have my contract ID. It just doesn't work for some reason. It's been almost a week and it still doesn't work. Maybe I should use the SOS button and have them figure it out?
  7. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    Check back with Safety Connect people and make sure you VIN is correct. They typo'ed my VIN in the system and ended up registering a different car for the service. Once I had the VIN corrected in the Safety Connect system it allowed me to put in my contract ID right away. The VIN for the registered car in Entune MUST match the VIN that Safety Connect registers, if there is any mismatch you will get an error. Their system is very poorly designed, so do not be surprised if one is in uppercase and the other is in lowercase and that this causes a mismatch.
  8. BlueMagnet
    BlueMagnet Member
    51
    27
    San Bruno, California
    2023 Prius Prime
    SE
    I was also having trouble with entune phone app accepting my contract ID for days and days. I did what "ruby" suggested and logged onto
    myentune website via computer and entered contract ID and it was accepted immediately and I was able to select my preferences on notifications. I mainly wanted to be able to check on charging completion via phone rather than to go to the garage and check for the blue lights or open the door to see how fully charged it is.
    ruby likes this.
  9. Db17
    Db17 Member
    188
    92
    Visalia, CA
    I had a similar problem. Kept getting a message that it wouldn't accept my safety connect number. I called Toyota. They couldn't fix it in the phone and told me someone would get back to me within 5 days. Mysteriously it started working all by itself 2 days later. A Toyota product specialist called me a couple of days later to go over everything. He pretty much told me they were having lots of problems but they were working on it.
    It's mostly working but buggy. Most times I have to sign in twice.
  10. aznkorboi
    aznkorboi Junior Member
    51
    22
    california
    So I am guessing the key is to press the SOS button, let them set it up and make sure your vin number is correct. Do they provide you with the contract id?
  11. BlueMagnet
    BlueMagnet Member
    51
    27
    2023 Prius Prime
    SE
    My dealer press the SOS button while I was in the car and obtained contract ID during set up. Be sure to have
    paper and pen available. Few hours later, I received email from Toyota with the same contract ID #.
    aznkorboi likes this.
  12. Jayne K
    Jayne K Member
    27
    Utah
    Where can I find the Safety Connect Contract ID so I can set up Entune?
  13. CharlesH
    2,798
    1,166
    Roseville, CA
    The easiest way is to press the SOS button in your Prime Advanced (there is a little cover you have to flip down before you can actually press the button). When the operator comes on, explain that this is not an emergency; it is a registration request. And then explain again, until they get the message and go into the registration dialog.They will already have the car info; they will ask for personal info like an e-mail address. And be sure to ask them for the contract ID, which can then be entered at https://www.myentune.com.
    Jayne K likes this.
  14. Jayne K
    Jayne K Member
    27
    Utah
    Since I have a Hawaii area code cell number I kept getting referred to ServCo Pacific. I finally got the number to Customer Experience 1-866-836-3003 and they were able to get me the contact ID which was totally different from what I was given by the dealer. In any case, problem solved. I can now use the Entune app to set the temp before I go out in the cold!
