Check Hybrid System Stop The Vehicle In a Safe Place 2013 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cblanco, Feb 12, 2017.
  1. cblanco
    cblanco Junior Member
    Hello everyone! I have a question about my 2013 Prius Persona. It has 66k miles and has been serviced religiously every 5k. After replacing the cabin filter today I went to take my Prius for a drive and all of the sudden I received the "Check Hybrid System Stop The Vehicle In a Safe Place" come up along with my yellow warning triangle, loss of power steering and check engine light. I made sure all of the plugs were still connecting underneath the hood and everything seemed to be in order. When I would pump the gas the car would move and then stop and I could never get it in ready mode. Now the engine is unresponsive. All cabin lights and accessories seem to be working fine. I just had it towed to my Toyota dealership. Any ideas as to what occurred? I'm going to the dealership tomorrow to find out so I will keep you posted. Thanks for any input!
  2. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Sounds like the power transistors in the IPM in the inverter is toast. It'll be a warranty repair, but you'll be without your car for at least a few days, possibly longer. Hopefully, they'll provide you with a loaner.
    #2 xliderider, Feb 12, 2017
  3. cblanco
    Thanks for your help! I just looked into the inverter and it seems they extended the warranty on that part due to trouble. Fortunately, I can walk to work and my wife has a honda civic we can drive. I wouldn't mind having a loaner though. We'll see what happens.
  4. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    Glad you caught the problem early!
  5. Mendel Leisk
    41,295
    Did you get a recall notice for the inverter, have it done? Maybe 2013 already had that fix? (n)
    Yeah should be warranty covered.
    #5 Mendel Leisk, Feb 12, 2017
  6. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    E0E was announced Feb. 2014. So any earlier Gen 3 that has or hasn't had the re-flash has really had plenty of time to accumulate fatigue in those capacitor leads. Still, nice to see Toyota own it and push that warranty out to 15 years.
  7. CndNiN
    CndNiN Junior Member
    Bay Area
  8. Erik Owens
    Erik Owens Member
    162
    59
    More than likely the IPM or the temp harness in the inverter are failing. Ive already changed like 7 of those guys out where we are when the warranty enhancement went through.
  9. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Smart wife, good bye Toyotas (y)
