Do you use parking brake?
Discussion in 'Prime Main Forum (2017-2022)' started by Michael Nielsen, Feb 11, 2017.
  1. TinyTim
    TinyTim Active Member
    380
    234
    Seattle
    I do not use the parking brake in cold weather and rarely use it unless on a steep incline.
  2. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    I've used the parking brake on my ford mustang convertible when I got stuck in the snow.
    I would apply it very gently until the spinning tire quit spinning, and then was usually free from there.
    But on the prius prime it has all that traction stuff, it don't think that that would work anymore.
  3. Trollbait
    12,507
    The 2005 Prius had a wider range of give than any automatic transmission I've had before it, so I got in the habit of using the parking brake all the time with it, and continue to do so.
  4. Mendel Leisk
    41,336
    For me parking brake use is analogous to seatbelt use: I just apply it all the time.
  5. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    Use mine (well, Pearl S's) all the time. It has never "frozen" or corroded enough to be a problem. If it does corrode in place it just takes a tiny bit of throttle to loosen. The FJ Cruiser, on the other hand, does corrode in place when very wet (overnight), and takes a scary amount of throttle to break loose, and does so with a loud "bang". So I don't use it in the garage. But I do use it everywhere else, just like the Prius.
    It's called "proper driving". ;)
    cghelton likes this.
  6. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Some cars now have electric parking brake. Using a foot pedal is starting to seem a bit old fashioned. And with electric it could be programed to set the parking brake automatically whenever you put it in park. With a way to override if for some reason you don't want to set the parking brake.
  7. RJ Primw
    RJ Primw Member
    65
    87
    South Jersey
    My first car was a 1970 Toyota Corona. Little square thing made of tin. It was an automatic, that had a habit of slipping out of Park and into Reverse and rolling down the street. After the second time a neighbor came knocking on the door to inform me that the car was rolling down the street in reverse, I learned to use the parking break. That was circa 1979....I have used the parking brake religiously on every car ever since.
  8. Michael Nielsen
    67
    88
    Dover, DE
    That is how it feels to me, too. Like too much slop. I worry that something in the system would be getting worn out by that little heave when I take my foot off the brake. I guess I will start using it. (Now, can I remember to release it??)
  9. David Beale
    5,963
    1,988
    Edmonton Alberta
    Oh, remembering to release the parking brake is easy. It complains loudly with beeps if you don't. Gee, I wonder how I know that? ;)
  10. ETC(SS)
    7,136
    I work for a self-insured company, and policy requires that we always use the parking brake.
    If anybody in my beloved company ever reads this, I always use my parking brake.
    Every time.
    All the time.
    OK.....
    SO.....
    If I were to drive a Prius in the real world, I would only use the parking brake when parking on an incline or a hill.
    Since the fake glaciers during the fake ice-age made some parts of the nation about as topographically diverse as a soccer pitch, sometimes I would go for weeks without using the parking brake-----IF I weren't compelled by company policy to always use my parking brake.
    Every time.
    All the time.
  11. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    The pawl is stronger than any other piece of the drive train.
  12. Mendel Leisk
    41,336
    Does it? It's been a while, but I can't recall a beep. Good idea though.
  13. ETC(SS)
    7,136
    Somebody "told me" it was a series of beeps, that will continue until the brake is released.
    There might be a red flashing brake symbol as well..............
    ..................I wouldn't know for sure. ;)
  14. bwilson4web
    16,197
    Followed by the 'smoke signals.'
    Bob WIlson
    Bluegrassman likes this.
  15. Mendel Leisk
    41,336
    You'll get the red symbol, that goes on whenever the parking brake is applied. But I don't recall beeps. Maybe confused with reverse beeps? (n)
  16. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    If
    If I don't release it, the car won't move!
  17. David Beale
    5,963
    1,988
    Edmonton Alberta
    Anytime I do it with a passenger, I explain I'm "cleaning off the brake disks". Rear only, of course.
  18. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    I never use it when parked on flat ground.
    iPhone ? Pro
  19. Moving Right Along
    Moving Right Along Senior Member
    720
    576
    I never use parking brakes. And on the Prius, I even have an excuse not to: the manual says to avoid using the parking brake when the temperature is below freezing.
  20. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Accuse me of gross oversimplification.
    But when a vehicle manufacturer provides something called a "Parking Brake".
    I use it when parking.
    Why Not?
    I really can't remember a post or thread where someone bemoaned the tragic decision to routinely use their parking brake.
    I'm sure SOMEBODY can come up with a story about how it's usage led to premature sterility, the loss of a beloved pet, or being forced into the front row of a Celine Dion concert. But despite these "risks"...I'm just going to use it.
