2012 Prius Spark Plugs Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HaiImBrian, Feb 14, 2017.
  1. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Damn! That's all my car is worth? I just changed out the spark plugs last weekend on my 2012. I used the NGK as that was the usual recommendation. In and out in a little over an hour total but I had help.
    HaiImBrian and Raytheeagle like this.
  2. HaiImBrian
    HaiImBrian Junior Member
    45
    Los Angeles
    Great info! looks like I'll have to do it the old fashion way.
  3. HaiImBrian
    45
    Los Angeles
    Can anyone else also vouch for these plugs? I just searched the forum for them and nothing came up besides what was mentioned in this thread.
    Denso (4711) IXEH20TT Iridium TT Spark Plug for Prius 2012
  4. Mendel Leisk
    41,245
    Here's my info on the plug spec'd in owners manual:
    spark plug: denso SC20HR11 (toyota p/n: 90919-01253) (requires 9/16" socket)
    ngk equivalent: NGK ILKAR7B11
    I did a quick search on Amazon (US) and see lots of hits. First search result, plus more across top of page:
  5. NavyLCDR
    NavyLCDR Active Member
    201
    126
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    The actual socket size is 14mm which is .2875mm smaller than 9/16". I recommend a magnetic spark plug socket because there is less chance of the socket coming off the extension after you install the spark plug.
    StarCaller and Mendel Leisk like this.
  6. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    Not sure if the gen3's have the same kinda mass air flow sensor as the gen2, but if it does id recommend cleaning that also and its pretty easy with the mass air flow cleaner. I did it on my old gen2 and on my gf's gen 2 not that long ago.
  7. Fred_H
    Fred_H Misoversimplifier
    558
    482
    28
    Germany
    I installed Denso Iridium TT (Twin Tip) Spark Plugs in my Prius 30,000 km ago. I have a Gen 2 Prius, so I have a different size, but the same type.
    You can check the correct part number for your car directly at the Denso site here:
    DENSO IRIDIUM TT (at the very bottom)
    For your 2012 Prius it confirms part number: IXEH20TT
    They come pre-gapped, but because of the thinner electrodes, the gap is purposely set about 0.1 mm smaller than the original Toyota specifications. Mine were pre-gapped between 0.93 and 0.97 mm, and I left them so.
  8. HaiImBrian
    45
    Los Angeles
    Was doing my tranaxle fluid change and stupidly stripped the bolt for the refill plug. The angle was tight and I thought I could remove it without an extender. Luckly.... I was still able to get it out but would like to replace to prevent future problems. Does anyone know the specific part number from Toyota for this plug?!
    Heres's a photo for reference. Thank y
  9. Mendel Leisk
    41,245
    Dealership parts department would know.
  10. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    BTW - if you're changing the plugs, here's my story. I have a 2009 Gen II and the plugs were due to be changed at 110,000 so I had the dealer change them during a regular service, and was surprised to get a call from dealer offering to change the PCV (diagnostics said it was needed) for just the price of the valve (~$11), since they were changing the plugs anyway. It is my understanding that it's a rather fiddly job, and requires dissassembly! (FWIW) BTW Welcome to PriusChat! - hope this helps - Wil
  11. HaiImBrian
    45
    Los Angeles
    Thank you! Will give them a call.
    That is a good tip! Since I'm doing a complete maintenance overhaul on the car, I wouldn't mind also changing the PCV while I'm at it. I'm loving the prius so far and I'm so glad to have joined Prius Chat!!
    iamvietdang and Raytheeagle like this.
  12. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    Also why is SC20HR11 still being recommended? It has been replaced and now the recommended plugs for Gen3 Prius is SC16HR11 (Part #90919-01275).
  13. Mendel Leisk
    41,245
    Agree. To be fair, my mention of SC20HR11 was in Feb 2017. Same socket size anyway.
    I had a bear of a time even finding 9/16" locally. 5/8' was usually the smallest most automotive places had. Ended up getting a 4 size made-in-China set through Princess Auto for around $20 CDN. A check now on Amazon I see it's no problem finding 14 mm though.
    And yeah, 9/16" is 14.2875 mm.
  14. iskoos
    415
    254
    Orlando, FL
    Ouch!.. I didn't realized this was an old thread. Yes the Toyota made the change sometime in 2017 as I recall.
    So Mendel, you were right recommended the 20HR11 at that time. I didn't pay attention to the posting date. Now it is SC16HR11. But both will work for sure:)
  15. johnHRP
    johnHRP Active Member
    643
    185
    KA, DE
    Excel
    I am also wondering about this new Iridium TT sparkplugs. What I found that some of the newest Toyota with dual injectors D4S are using Iridium TT as the OEM/Genuine original Toyota Parts. There is indeed some improvement on Iridium TT over older Iridium. Both has the same ground electrodes made out of Platinum, not Iridium. Only the main tip is Iridium.
  16. ChapmanF
    18,013
    If I remember right, the main difference is that the stock plug has a 0.7 mm iridium needle pointed at a platinum ground pad, and the TT has a finer 0.4 mm iridium needle pointed at a 0.7 mm platinum ground needle.
    The thicker needle on the stock plug will last longer. The thinner needle on the TT will require a lower secondary voltage to form a spark, which could be advantageous if your engine condition and driving conditions are such that the stock plug is borderline at doing its job.
    The ECM has some pretty sensitive measurements to show you how your current plugs are doing. For starters, there are the misfire counts, accessible by viewing the misfire monitor. If those are staying at 0 for all cylinders, your current plugs are getting the job done. But beyond that, there is a metric called the misfire margin (at least starting in Gen 3; I don't know if Gen 2 tracked this). This number can be negative (misfires are happening) or positive (if less than 30, at risk for misfiring; higher than 30, not really at risk, higher is better). Last time I checked mine it was something like 134.
    If you have looked at your misfire margin and it is some very comfortably high number like that, the odds are pretty much nil that any change to any kind of better plug is going to change anything. The plugs only do one thing and a sky-high misfire margin shows they're already doing it way better than they need to. (That doesn't mean, given that we're human, you couldn't change to fancy plugs and convince yourself you feel wonderful things happening.)
    If your current misfire margin is lower, getting down near 30 or worse, then it is possible a change of plugs could improve something. But it would also be worth investigating whether anything else is going on with the engine that could be contributing to the low margin.
    Fred_H likes this.
  17. ChapmanF
    18,013
    It turns out I spread some misinformation here about the misfire margin. It is a number the ECM is constantly recomputing while the engine is running, and its normal range tops out at 100. Whenever the engine is not running, this PID sits pegged at 127 (which is normally not a valid value for it). So it's no use to just go ask "what's my misfire margin?" and get a single number, which'll just be 127 if you're asking when the engine is stopped. It doesn't somehow summarize the whole drive you just made.
    It is more useful to datalog and graph the misfire margin, over a short drive that takes in various driving conditions. If you're using Techstream, you can graph several things at once, like coolant temperature, RPM, engine load, EGR %, and misfire margin, and look for where the margin gets lowest, and what the other engine conditions were at that time.
    For what it's worth, misfire margin wasn't new for Gen 3; I checked in the Gen 2 repair manual and it's in the Gen 2 data list also.
