50MPG from Chevy Cruze Diesel
Discussion in 'Diesels' started by Troy Heagy, Feb 6, 2017.
  1. bisco
    52,252
    but you don't have that $2,500. hybrid battery replacement after 10 years. and surely, nothing major will go wrong with a chevy in that time.
  2. hill
    8,893
    I sure hope they do !!
    ... just as soon as they remove the cheat software, add proper smog/NOX/particulate controls, make the pee filter last longer, and then watch out USA ... progressive Europe, the birth place of cheat software will roll right over you.
    :rolleyes:
    Yea . . . speaking of fundamentally flawed .... and " i ignore" . . . thanks for the great advice, as I smell the underside of a bridge nearby anyway.
    Sell that 2013 Prius - quick !! and enjoy the new ride. I'm sure it'll be ok
    #42 hill, Feb 15, 2017
  3. wxman
    wxman Active Member
    636
    231
    Tennessee
  4. ETC(SS)
    7,295
    Bla
    Bla...
    If what you were saying were true.....there would be a lot more small diesel passenger cars in the US.
    If HOW YOU WERE SAYING it weren't so caustic, then you wouldn't have to skulk around under a new forum name every few years.
    Diesels make sense for many things.
    Trains, trucks, ships and submarines don't make much sense without them.
    Passenger cars in the US don't make much sense WITH them.
    One of my work responsibilities is the care and feeding of 4-1/2 diesel backup generators.
    I say four and a half because one of them is always deadlined for maintenance.
    The MOTORS work great. (Cummins and John Deere make good stuff)
    The sensors and electronics are crap!!!!
    That's ONE REASON there aren't that many small diesel sedans in the US
    Another reason is that we have different definitions of "clean" in the US than they do across the pond.
    OK....so everybody's eyes always glaze over when eco-geeks compare and contrast CO, NOx, SO2, Ozone, etc....
    So....I'll leave that component of the argument to them, but most people generally agree that if you spend enough money on pollution devices, and sacrifice enough in performance and reliability, then a diesel car can be "just about" as clean as gas burners already are.
    I like the fact that Chevy is building a diesel Cruze, because............we export them to places with different emissions standards and fuel subsidies.
    You have to remember however, that the Cruze is an asterisk (*) car.
    It gets 52 MPG on the highway (*) if you get one with a manual transmission.
    It's the highest highway MPG rated car in America (*) except cars with an electric drive motor.
    They can be cheaper to operate than (********).....well.....there isn't time for all of the asterisks.
    If there's a 'hybrid penalty' to be paid for driving a Prius, then driving a small diesel car amounts to more of a prison sentence.
    Remember......some places in the US actually test emissions on cars before they let you drive them on the road.
    I'm thinking that all of that money that diesel devotees didn't save by overpaying for the car and then again for the fuel,will be re-spent in keeping a diesel car with 150,000 miles on it in emissions compliance.
    And...finally!!!!
    They're clean (*).
    The 2017 Chevy Cruze Diesel gets great mileage, but is it clean? - NY Daily News
    Chevy Cruze Diesel lawsuit to move into discovery phase
    Another emissions scandal? Mercedes-Benz parent Daimler opens probe
    ....until they're not.
    And these are NEW Diesels with NEW rings and NEW emissions components!!!!
    What is a diesel car with 100,000 miles going to be like??? :eek:
    #44 ETC(SS), Feb 16, 2017
    Prius Pete and telmo744 like this.
  5. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,691
    Somewhere in Wisconsin
    2013 Chevy Volt
    All slush autos excluding the Prius sun gear type have a fluid frictional loss.
    On a gas car this can be overcome in the test because the bsfc island isn't great on Otto cars.
    A Diesel engine has a wide flat bsfc island and fewer losses at low load so the hydraulic losses in the auto overcome the slight bsfc gain from overgearing .
    My experience on all cars that came with both MT and Auto is that regardless of the EPA test numbers my economy was always better with the manual, even on cars where they sport geared the manual, effectively crippling it.
    Maybe some day that will change but at the moment normal automatics stay rather lossy, especially in cold weather.
    wxman likes this.
  6. Trollbait
    12,650
    So do I, but plug ins aren't going to work for everybody. Renewable diesel is more likely than renewable gasoline at this time. Ethanol in levels to truly replace gasoline require engines designed for it. Modified gasoline ones suffer efficiency losses.
    To paraphrase John, "other alt fuel vehicles aren't the real competition."
    Take off the Prius tinted glasses and look at what the majority are buying instead of hybrids. More choice is always better if we want people to move to more efficiency.
    I believe the current automatic in the Cruze is the one from the previous generation's Eco trim; so better gear ratios for fuel efficiency than the manual. I suspect one or two of the 9 nine speed's overdrives didn't even get used during the EPA test cycles. The tests have an anti-diesel bias. The EPA knows this in addition to the diesel fanboys. I bet this Cruze's real world highway will be much better. The city might also be better.
    Wasn't the same about sacrificing performance and reliability said about gasoline cars in the late '70s and early '80s because of the new emission regulations? Eventually, we will want our commercial trucks, trains, ships, and even generators as clean as our cars. Building diesel cars helps move towards that goal.
    Those markets have been getting multiple diesels for the Cruze since the model's introduction. The first US diesel Cruze used an engine designed for those markets. This 1.6L diesel is the first small block designed with the US market in mind.
    Likely polluting as much as a gasoline car with the same miles, but there might be smoke visible to the naked eye for everybody to get their panties in a bunch over.
    Modern step automatics have gotten much more aggressive with DFCO and lock up to help overcome those losses. Double clutch transmissions are really just automated manuals.
    Agree about the cold weather. Automatics hold a lot more fluid than a manual, that also passes through the radiator. Warming them up to their efficient point could take some time.
    wxman likes this.
  7. Troy Heagy
    Troy Heagy Member
    1,218
    I read your entire post, but all I kept thinking was, "I wasted $5000 buying new batteries for my Civic and Insight hybrids, and will soon waste $2500 on my Prius battery as it gets old & fails." You keep talking about diesels getting dirty as they age (requiring expensive repairs)...... well so too do hybrids. Hybrids are not some magical thing that stays clean forever. The battery fails and they no longer pass smog inspection.
    Maybe you're right.
    I shouldn't buy a diesel.
    But it sure as heck won't be a hybrid (your preferred solution). There's a third option: Gasoline Direct Injection like the 1 liter Fords and Mirages that get 44mpg and 43mpg highway. Unfortunately I suspect you hate those cars too. If the customer doesn't buy an EV or hybrid, then you think the customer is a fool. (I'm guessing but probably a good guess.)
    I'm actually more interested in CARB's blessing. They banned diesels from 2006 to 2009, and then allowed them back in the state from 2010 onwards. What did the liberal, diesel-hating CARB see that made them change their mind? Progress. The engines became as clean as gasoline (they had to... it was mandated by California law). As for living in the year 2000 that's okay but you miss a LOT of new developments:
    - Release of the Prius
    - Rebirth of the EV with the Leaf, Tesla, etc
    - Birth of the first plugin hybrid (or if you prefer: unlimited range EV): The Chevy Volt
    - And no-sulfur diesel fuel and SULEV-rated engines
  8. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Using exaggeration & generalizations to come up with that conclusion confirms the writing on the wall. Traditional tech won't be able to compete.
  9. ETC(SS)
    7,295
    Buying new batteries isn't "wasting money" if you use the right batteries.
    This is what seperates people who properly assess and buy the right cars for their use, from fanboys who spend all of their time swapping useless baseball-like statistics.
    I've owned just about every car make sold in America except Honda.
    They're good cars for some people.
    I'm just not one of them.
    Concur, but the batteries aren't the problem with hybrids passing emissions as they age.
    ALL internal combustion engines wear and pollute more as they age.
    The difference with diesels is that they're dirtier to start with, and thus they rely more on emissions devices than ICE powered cars including hybrids. The difference is,,,,,,without the batteries that you keep harping about a hybrid is just another ICE powered car......which tend to be cheaper to work on than corresponding diesels, and have a different pollution curve to deal with.
    That's not "me being right."
    That's YOU buying the vehicle that fits your need.
    The next time you get kicked off of the forum, you should "lurk" and read more of my posts.
    I do not own a hybrid, and never have.
    I've driven a company provided Prius for the last 120,000 miles, and I live in a part of the country that thinks that a VET is an expensive way to scare the crap out of your pet.....so this is a non-issue for me.
    Direct ignition is still a napkin drawing, but it's not magic either.
    Wake me when they''re a player in the eco-chic world.
    My next car will probably be a PHEV, because right now that's the best fit for me, but anybody who knows me knows that "my next car" has changed several times over the last 8 years as my needs have changed.......so who knows?
    A used hybrid might work for me.
    The thing about hybrid batteries is that they're connectorized.
    ...easy to swap out. :)
    telmo744 likes this.
  10. john1701a
    12,818
    5,303
    58
    Diesel cheating proved that didn't actually happen.
    As clean as gasoline is setting the bar extremely low anyway. Competing with a plug-in hybrid is far more difficult.
    It's dead, period.
    Prius Pete and bwilson4web like this.
  11. bwilson4web
    16,317
    Or maybe you should buy a diesel.
    It really comes down to a question of your requirements which typically come in two flavors:
    • Mandatory - pass/fail
    • Optional - can be weighted
  12. bisco
    52,252
    renewable diesel sounds like renewable hydrogen, cow poo.
  13. wxman
    wxman Active Member
    636
    231
    Tennessee
    Renewable diesel is actually second-generation biodiesel, but unlike traditional biodiesel (an ester), renewable diesel is straight hydrocarbon, and thus capable of being used in diesel engines up to 100%.
    It's mostly made from used cooking oils and waste fats.
  14. mikefocke
    4,038
    1,830
    Sanford, NC
    Acronyms: DFCO and BSFC ??
  15. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    With today's tooling and cost of making high pressure pumps for common rail injection....they will not work and will make emission devices work harder than they are intended.....
    Example are states like Illinois where all Diesel are blended with biodiesel..and there is highest percentage of problems with common rail injection and emission systems......
    And not to mention loss of MPG...
  16. ETC(SS)
    7,295
    Dijon Football Côte d'Or is a French association football club based in Dijon. The club was founded in 1998 as a result of a merger between two local clubs in the city, and competed in Ligue 2 after ... Wikipedia
    and.....
    Birkenhead Sixth Form College, Wirral
    Birkenhead Sixth Form College is a centre of academic excellence, specialising in A Level & BTEC education and is rated as 'Outstanding' by Ofsted.
    Happy to help! ;)
  17. wxman
    wxman Active Member
    636
    231
    Tennessee
    And that's the difference with renewable diesel, as I stated. It's 100% diesel-range hydrocarbons, so indistinguishable from petroleum diesel fuel from that perspective. It has much higher cetane rating than petro-diesel, along with no sulfur or aromatics. It's essentially a very high-quality diesel fuel.
    About Diesel HPR | Propel Diesel HPR
    Trollbait likes this.
  18. bisco
    52,252
    like driving behind a fryolator.
  19. Trollbait
    12,650
    For VWs. The BMW tested alongside the cheating VW cars was running clean like BMW claimed. Their current diesel models received EPA certification under the higher scrutiny
    Hybrid and diesel aren't mutually exclusive technologies; Volvo had an extremely popular diesel PHEV not too long ago.
    DFCO is deceleration fuel cut off; it's turning off the engine fuel injectors while coasting in gear. Manual transmission cars made use of it for years, perhaps decades, now. Its use was hit or miss in older automatic cars, but increasing fuel economy targets mean newer cars make more use of it.
    BSFC is Brake specific fuel consumption - Wikipedia
    Simply put, it a measure of the engines efficient 'sweet spot'. Useful to a hypermiler if a chart can be found for their car.
    Except a chain of stations is already selling the renewable diesel in California.
    Neste's NEXBTL renewable diesel retail availability expands into Southern California | Neste
    Syn-crude can be made from water, CO2, and electricity in the reverse of the hydrogen reformation process. Audi calls it blue crude, and it's renewable if the electric used was. Other syn-crudes are made through pyrolysis amd thermal conversion from nearly any organic material. Diesel tends to be the lower cost to make fuel from these syn-crudes, though gasoline is possible.
    wxman likes this.
  20. bisco
    52,252
    i'll have to see all the details before i'm in. not much on their website. interesting, but could just be cow poo.
