Cell Phone Mount
Discussion in 'Prius v Accessories and Modifications' started by beachgeek, Jan 29, 2017.
  1. beachgeek
    beachgeek Member
    102
    24
    2013 Prius v wagon
    I've already searched the forum but haven't found anything useful. I am looking for a cell phone mount for my 2013 v that does NOT require me to take my eyes from the road and does NOT block the windshield or dash info. I have been using a vent mounted holder but it doesn't like my S7 much, wants to flip onto the floor (from weight I believe). I saw an old windshield mount with a 3.5" arm that seems do minimal blocking but I haven't found it for sale. Any ideas?
  2. Air_Boss
    Air_Boss Senior Member
    4,217
    1,188
    New Yawk
  3. Prodigyplace
    12,617
    11,804
    Central Virginia
    What about a friction mount? My son uses that with his Garmin in his Prius v. You can get cell phone brackets to fit the Garmin ball mount.
    I hate PCs broken amazon links. :( Search for B000LRMS66 on Amazon.
    beachgeek likes this.
  4. mikefocke
    4,030
    1,826
    Sanford, NC
    How would an a-pillar mount play with the side deploying air bags?
  5. Air_Boss
    4,217
    1,188
    New Yawk
    No factor. The mount is low on the A-pillar below the side airbag parting line.
  6. beachgeek
    beachgeek Member
    102
    24
    2013 Prius v wagon
    I looked at that. I have concerns about getting used to viewing on the left. But I rarely actually look at the phone so maybe it doesn't matter.
    I have a friction pad. The great thing is you can put them where you want. I'll investigate that. Thanks!
    I saw a photo of attaching it to the little side window. Does anyone have that? Seems like it would be out of the way.
  7. Air_Boss
    4,217
    1,188
    New Yawk
    That's the A-pillar mount. Impedes "view" (such as it is) through the little triangular window.
  8. rolan787
    rolan787 Junior Member
    33
    Puerto Rico
    Nimbus mount, I have it on my '12 v and love it...
  9. beachgeek
    beachgeek Member
    102
    24
    2013 Prius v wagon
    My Prius doesn't have a shift level like that.
    I bought an iOttie mount with an articulating arm (just in case). Right now it is sitting on a friction pad. I have tried in front of the left side window and on the right side of the ledge in the center (so it doesn't block the view of the digital info). I forgot one thing. It is so hot in the windshield my phone sets off warnings and shuts down after awhile . I didn't have that problem in prior vehicles. So I'm still trying things.
    #9 beachgeek, Feb 18, 2017
  10. Air_Boss
    4,217
    1,188
    New Yawk
    Pro Tip: on an A-pillar mount, the forced vent air stream induces air flow that cools the phone...
    MVPLRJohnson likes this.
  11. TomInRockville
    TomInRockville Junior Member
    Maryland
    2014 Prius v wagon
    This was the first thing I bought for my new (well, used 2014) Prius v. This had good reviews on Wirecutter, came quickly from Amazon, and seems to be just about perfect:
    Kenu Airframe+ | Car Mount for Smartphones and Phablets | Black Kenu
    It is a surprisingly small device for $30. The box is insultingly small. But it is beautifully made, and absolutely does the job. It appears to be rock solid attached to my vent.
  12. beachgeek
    beachgeek Member
    102
    24
    2013 Prius v wagon
    My S7 apparently weighs too much. Yesterday the holder with phone fell off the weighed pad while driving the interstate ramps. Fortunately I don't normally drive them.
  13. TinyTim
    TinyTim Active Member
    386
    236
    Seattle
    I have a suction cup mount with the 3.5" arm. I have it on the left side of the front windshield and it doesn't block my view of the road.
  14. beachgeek
    beachgeek Member
    102
    24
    2013 Prius v wagon
    I agree the left side doesn't block the view. My brain can't seem to adjust to left side viewing. After it fell off the dash yesterday I tossed it to the passenger seat. It still talked to me. I think I only need it for those rare times I'm negotiating an unknown place so if it works from the passenger seat that's fine.
  15. vdub Beet
    vdub Beet Junior Member
    Ohio
    This is way out of my price range but I know a few people who have and love them. Just search Navdy
  16. Midesaka
    Midesaka Junior Member
    Southern MS
    I was using the ProClip A-pillar mount with an iBolt xProDock, but the long, thin support arm caused the phone to hit a resonance and vibrate at my preferred highway cruising speed, strong enough that "shake to activate" features were turning on.
    I bought another ProClip mount, ground off the molded arm with my Dremel, and bolted on a RAM base with a 1" ball, then attached a RAM short arm and X-Grip phone holder. The larger balls and thicker arm on the RAM products (1" = 25.4mm, vs. the 17mm ball on the iBolt) make the setup rock solid, with absolutely no vibration at any speed. The only downside is that two hands are required to insert or remove the phone.
  17. mrswylie
    mrswylie Junior Member
    Western Michigan
    2013 Prius v wagon
    I've used Nato Mounts for awhile now - both in a Prius V and a CRV. They advertise holding phones and tablets up to 2 lbs.
    As a newbie, I can't post the link, but use natomounts in your url
    Plugingeek likes this.
  18. beachgeek
    beachgeek Member
    102
    24
    2013 Prius v wagon
    Where on your dash did you place it? I don't seem to have a flat surface. Does it work through a case?
  19. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    As an Uber driver, I struggled with a lot of the issues that the OP mentions. I came up with mod 4 years ago, that allowed me to mount a standard mount where I wanted it. I finally documented it today in the following thread, because I bought a second Prius V:
    Phone Mount @ the Front of Console (Good for Ubering).
    It involves drilling, two small holes. If I had not been taking pictures, this mod would have taken me 20 minutes. It puts the phone in a comfortable place low on my right side. It is easy to press buttons on the phone while your eyes are still on the road.
    The mod gives you a stable flat surface to put your favorite phone mount, in a place that makes sense. I love the SCOSCHE MagicMount series, as it holds the phone firmly, and yet I can grab it and run quickly.
