2017 Cruise Control
Discussion in 'Gen 4 Prius Technical Discussion' started by Ferrarilover, Feb 19, 2017.
  1. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    Same here
  2. alanclarkeau
    7,041
    7,580
    If you're doing 45km/hr or more, you can set it like a normal Cruise Control - if a car comes in front, it becomes DRCC - right down to 1km/hr.
    If you're below 40 or 45 (not sure now) and the car in front disappears, it will display "NO LEAD VEHICLE" or something like that, and you're without Cruise Control. But if you're over 45km/hr, it just reverts to being a normal Cruise Control.
    RCO and Tideland Prius like this.
  3. Tideland Prius
    16,066
    I gotta check again cause it wasn't the case with our Gen 4.
    alanclarkeau likes this.
  4. Tideland Prius
    16,066
    Yup you're right. It worked without a car in front. Why didn't it work the last time remains a mystery. Is this what getting older means? :oops:
    Prodigyplace and RCO like this.
  5. alanclarkeau
    7,041
    7,580
    Probably - happens to me all the time.
    Though - Samantha has a mind of her own at times. She and I had been on the Motorway for 15 mins on Sunday, full battery, 30 degC. Pulled up at same traffic light I stop at 3 or 4 times a week. And because I only drive another block after that before parking, I ALWAYS press EV Button, and she obediently obeys. Not on Sunday night, in a sulk for some reason, she said EV MODE UNAVAILABLE. I'm sure she yelled it at me. And - guess what? She wouldn't tell me why!!
    But as we pulled up a block away, I tried again as I drove in the driveway, she went into EV mode. She forgets why she was annoyed quickly.
    Back to CRUISE - she has a couple of times told me that there was no vehicle in front, even though there was one. Last time it was in light, not heavy rain. She'd been following the same car for a couple of kilometres at maybe 40-50 km/hr in HEAVY RAIN, when the rain eased, traffic sped up to 80-90, she decided the SAME car in front wasn't there any more. I can only assume that the spray from the road might have increased with speed, even though the rain was lighter.
  6. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    Mine almost works like that but without the NO LEAD VEHICLE message.
    EDIT: I misread on the borked website. I am never without Cruise control and have not seen it revert to normal cruise.
    #26 Prodigyplace, Feb 21, 2017
  7. Prodigyplace
    11,696
    11,317
    Central Virginia
    You were probably driving too slow in the wife's Gen 4. You really need to drive it more or get your own! :D
    Tideland Prius, alanclarkeau and RCO like this.
  8. Prodigyplace
    11,696
    11,317
    Central Virginia
    I can verify you are not going crazy (yet). :D
    It appears you are using the MID to determine whether DRCC is enabled instead of regular cruise. Apparently, sometimes DRCC is enabled but no blue bars appear when no car is in front.
    The best way to determine whether DRCC or cruise is on is to use the "old-fashioned" indicator lights to the right (or left, for our non-standard International users) of the MID. DRCC & cruise have totally different indicator lights.
    #28 Prodigyplace, Feb 22, 2017
  9. alanclarkeau
    7,041
    7,580
    I've never used CRUISE - only ever DRCC. I must have a look a the different indicator light - never bothered to check it was even there.
  10. Prodigyplace
    11,696
    11,317
    Central Virginia
    I believe you hold the Cruise on button for 3 seconds.Otherwise there is a menu preference somewhere. My wife & son prefer just cruise because DRCC is so sluggish in ECO Mode. I am running in Normal now.
    RCO likes this.
  11. alanclarkeau
    7,041
    7,580
    Yep, I knew it was there - I just couldn't see the point when I had DRCC - I'm retired now, why do the work if the gadget will do it for me - HeHeHe
    RCO likes this.
  12. Tideland Prius
    16,066
    DRCC's light has an additional picture of a car within the CC light.
    DRCC light
    regular cruise
    RCO and alanclarkeau like this.
  13. alanclarkeau
    7,041
    7,580
    Yep - checked it out this afternoon. I didn't really find any use for it, turned it off and went back to DRCC - which has a fancier ICON :D.
    Tideland Prius likes this.
  14. Zardoz
    Zardoz Member
    86
    51
    Show Low, AZ
    I have no problem setting my cruise control speed in DRCC mode with no one in front on my 2017 Prius Two.
    RCO likes this.
