I bought a 2009 Prius with 230,000 Miles.
Discussion in 'Gen 2 Prius Main Forum' started by Simbaboy, Jan 4, 2017.
  1. Moving Right Along
    Moving Right Along Senior Member
    732
    588
    Ok. From my perspective, it does complicate the process if you want a precise measurement of the exact charge of the battery alone. However, for the purpose of determining a general impression on the battery's health, applying a predictable current that would be consistent across vehicles in order to view the display readout would generate a useful, if not completely precise, number that can be determined easily and without additional tools.
  2. Simbaboy
    Simbaboy Active Member
    134
    112
    Mid-Michigan
    Just ordered the yellow top Optima 'specific' for Prius (pencil posts) from Amazon. With tax it was $170.
    My voltage this AM was just above
    11V with minor radio and headlight load. Since I was going to get one anyway soon I thought why not now.
    Thanks,
    Simba
  3. JC91006
    JC91006 Senior Member
    16,827
    8,600
    I have found the ac delco prius battery on Amazon to be a better value and has 45ah like the oem battery
  4. Simbaboy
    134
    112
    Mid-Michigan
    Any installation issues? The ac delco was $30 cheaper.
    Thanks
    Simba
  5. Simbaboy
    134
    112
    Mid-Michigan
    Cancelled the Optoma and ordered the AC Delco. Its guranteed to fit without modifications. Thank you.
    jerrymildred likes this.
  6. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    Good to know another option for the 12 v battery.
    Simbaboy likes this.
  7. Simbaboy
    134
    112
    Mid-Michigan
    I have another SKS key fob on its way from Amazon.
    Is there a definite good 'chicken dance' that works? Also, I have Premium AAA Membership where they will pay up to $150 for programming costs to a lcoksmith. Anybody try this service?
    Thank you,
    Simba
  8. eman08
    eman08 Active Member
    360
    192
    US
    I bought my 09 Prius back in June at 160,747 miles on it. I now currently have 168,515 miles on it no signs of taction battery as you would know just by looking at the MFD if the bars drops rapidly or charges too fast and your MPG abnormally dropping. It's a mostly highway driven car. It's normal to see some fairly newer cars with stupid high mileage on them if driven on the highway a lot which in most cases it is. Highway driven cars tend to have much less wear and tear compared to one that took alot of abuse in stop and go that can wear out the transmission faster, pedals etc.
    #68 eman08, Jan 23, 2017
  9. Simbaboy
    134
    112
    Mid-Michigan
    Today, I drove the car to my oil change place and had them do the the transaxle fluid change and replace the 12 V battery for me. I took the ATF WS, washers and battery with me (all obtained from Amazon Prime). They charged me $50 and it was totally worth it to me.
    I am shopping for some All Season tires and am thinking to go with Nokian Entyre--getting all 4 for $213. That includes shipping and taxes. Walmart will charge me $50 for installation.
    Thank you,
    Simba
  10. Simbaboy
    134
    112
    Mid-Michigan
    Weird problem.
    I placed a new 12 V battery about 2 weeks ago.
    Yesterday, I installed a trailer hitch and did the trailer wiring. Everything eorked well.
    Several hours later I turned the car on and the dash is dark but I can drive the car fine. I stopped and tried to turn the car off but couldnt.
    Decided to go home and check my cables to the battery but while driving the dash suddenly cam back on and no problems since.
    Anybody with ideas other then checking the connections to make sure all cabkes are tight?
    Thank you
    Simba
  11. bisco
    52,391
    i can't see how it could be anything but the 12 volt charge, connections or trailer wiring.
  12. Simbaboy
    134
    112
    Mid-Michigan
    The Dark Dash has NOT reappeared in the last two days--but I will check the wiring for my trailer soon.
    Currently using Winter Tires but will need to order new all seasons tires soon--I prefer Walmart as they have been good with me. The tires I have on my year round wheels are 185/65/15. My needs for all season are comfort and hydroplanning protection more than FE.
    Any Walmart recommendation?
    Thank you,
    Simba
  13. Simbaboy
    134
    112
    Mid-Michigan
    So far I am very happy with my 2009 Prius that I bought with just about 229K Miles, I have now put about 1500 Miles on it.
    The following is what I have done to it:
    1. Bought a set of Winter wheels and tires (Goodyear Nordics) off Craigslist.
    2. Replaced the 12V Battery.
    3. Synthetic oil/filter change.
    4. Toyota ATF WS transaxel fluid change.
    5. Cabin filter.
    6. New tires at Walmart-- Hankook Optimo 195/65-15 H724. Compared to my Winter tires (Goodyear Nordics) these Hankook are excellent when it comes to road noise and comfort. The Winter Tires were over inflated (42/40) and felt extremely harsh and 'poor' MPG (about 45). The Hankooks are factory recommend PSI and I am already getting about 52MPG.
    7. Hitch, wiring, and a small motorcycle trailer.
    I have set aside $$ for a future hybrid battery replacement. I hope I don't have to tap into this reserve anytime soon.
    Thank You all,
    Simba
    Xterra72 and fotomoto like this.
  14. Patrick Wong
    18,210
    6,513
    Nice work. How about the engine air filter and the iridium spark plugs?
    At 230K miles you may need a new traction battery at any time. However hopefully your vehicle acquisition price reflected that eventuality. Good luck with your Prius ownership.
  15. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Get the wheel covers to match again. You're ghetto stylin' right now.
  16. Simbaboy
    134
    112
    Mid-Michigan
    Yes the acquisition price reflected new tires, $1000 allowance for hybrid battery and cost off power door latch mechanism replacement. The Seller would not budge anymore and I did not want to push it as the car was otherwise very clean.
    Engine air filter looked clean at a recent inspection (the cabin filter was very dirty). I will address the spark plugs this fall. Also, I will need to research an engine block heater before next Winter.
    The Winter wheel/tire set is off and back to oem wheels and new tires. I took the plastic 'rings' off and I am liking the look. I may put the 'rings' back on. Hey, I am an 80's kid and I like the cheap Autozone hubcaps. NOT!
    Thank you
    Simba
  17. oil_burner
    oil_burner Active Member
    249
    126
    I also just got myself a high mileage (215k) prius and I plan to drive it into the ground. I picked mine up for almost nothing and also plan to haul my dirt bike around with it. What hitch did you get, and are you using a HF trailer?
  18. Simbaboy
    134
    112
    Mid-Michigan
    I got the 42" X 48" HF trailer. Its listed for $238. I had a 20% discount that clearly states that the coupon cannot be used be a trailer or generator, etc. I cried foul and the Manager used a store 20% Customer Satisfaction Coupon that gave me 20% off the entire receipt not just one item.
    I like this trailer a lot--use real Mobil 1 synthetic bearing grease and also use Loctite for all the fasteners Make sure your rail for your bike (I used wood) goes all the way to the front of the tongue. Make sure you get a hitch tightener otherwise you will hear rattling.
    I got the hitch and wiring harness from Amazon. I saw the youtube video installation from etrailer.com for both the hitch and the wiring. I am not mechanical and I had everything done in 2 hours.
    I took it for a long 30 Miles shakedown test today. No issues at any speeds up to 72 MPH. I also took it on some dirt (farm gravel roads) and the car, trailer and bike did well.
    Simba
    I had a simple grounding issue that is why the left rear light/turn signal was dim. Make sure you have a decent ground connection. Use a drill to 'chip' off a little paint off the trailer.
  19. Simbaboy
    134
    112
    Mid-Michigan
    Here is everything one needs to pull a trailer with a Gen 2 prius:
    If planning to use a HF trailer, you will also need a 1 7/8 towing ball.
  20. oil_burner
    249
    126
    thanks for the help. By the way, nice DRZ, I've got a dr650 in the garage
