2016 Touring Tire Reliability Master Thread for 17" OEM tires
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by ETP, Jul 10, 2016.
What PSI do you run your tires
This poll will close on Nov 10, 2074 at 5:30 AM.
  1. 34
    6.7%
  2. 35
    20.0%
  3. 36
    13.3%
  4. 37
    3.3%
  5. 38
    20.0%
  6. 39
    6.7%
  7. 40
    10.0%
  8. 41
    0 vote(s)
    0.0%
  9. 42
    20.0%
  10. 43
    6.7%
Multiple votes are allowed.
  1. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    Same tires here.
    After 12 months and 37k miles tread wear is even and at 6/32".
    I run at Toyota (door jam and owner's manual) recommended 33# front and 32# rear.
    I rotated every 5k for first 20k and then decided not to bother.
    ETP, Frederickdawg and RCO like this.
  2. Mendel Leisk
    41,744
    A little off-topic, but for anyone: how are those plastic inserts on the 17" rims doing? Are they recessed, less vulnerable to curb-rash. Is it the alloy rim that contacts a curb first?
    ETP likes this.
  3. ATHiker
    644
    560
    Massachusetts
    Four Touring
    My plastic inserts are in perfect shape, but I did get about 5" of curb rash on the rim itself immediately adjacent to the outside edge of the plastic.
    I have no idea how this happen -- it strikes me as virtually impossible to have scraped the rim without gouging the plastic too. The plastic is virtually flush with the rim.
    A black sharpie came to the rescue. The sharpie also worked well on the impact wrench chips left as a rememberance of my tire rotations.
    RCO and Mendel Leisk like this.
  4. Mendel Leisk
    41,744
    Thanks for the info. So your's came through unscathed, but the plastic does look to be flush with the rim. Maybe it can deflect inward a little easier, who knows. Just looking on Toyota Online Parts: the discounted price for one of those inserts is $24 and change.
    I would spring for a gloss-black (or satin?) touch-up lacquer , gotta provide more protection than a sharpie.
    RCO likes this.
  5. Notquiterite
    Notquiterite Junior Member
    34
    Burbank, CA
    Three Touring
    I run 38 all around and I'm at 30k miles. It's a pretty comfortable ride and I get decent mpg. I may bump it up to 40 all around sometime to see how that feels.
  6. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Remember to keep us posted when you do! :)
  7. ATHiker
    644
    560
    Massachusetts
    Four Touring
    Maybe in the spring. For now the scrape blends in with winter salt and road grime, after the Sharpie in wears off. Still can figure how the plastic insert didn't get roached.
    ETP, RCO and Mendel Leisk like this.
  8. ETP
    2,802
    1,170
    Auburdale FL
    OK, 15K update at 42 PSI. No notable wear.
    Met a fellow Prius driver in the commissary parking lot and he runs 49PSI. Warned him that on a road with potholes he may be in trouble. Actually lost control (on a very bumpy road) at 51 PSI on my Honda Civic hybrid and immediately lowered the pressure to 44PSI. I consider 42 the ultimate answer to everything in the universe. We just don't know the question yet.
    Not sure why they paint a beautiful rim. Strange.
    #28 ETP, Apr 27, 2017
  9. ETP
    2,802
    1,170
    Auburdale FL
    Sorry folks but no way to edit the poll. Still running 42 PSI with no issues. I noticed some folks were running 32 PSI but it is too late to change it. Just hit the 34 PSI button.
  10. ETP
    2,802
    1,170
    Auburdale FL
    Update/my tires still look new at 30K and 30 months. Seems the EP20s on the 2011 starting showing bad wear at 50K so we will see.
    42 is the answer to everything just wish I was 42.
    Starship16 and Mendel Leisk like this.
  11. ETP
    2,802
    1,170
    Auburdale FL
    Update on the EP20's. Low pressure kills tires folks, deader than a doornail. Check your tires every morning like the truckers do. Once a week get on your knees and check the pressure.
    If you are too busy to check you tires ride with someone else.
    Dealers love to sell you new tires and will let the air out of your tires every time.
    My 2011 was delivered, new, with 24PSI in the tires. My wife accused me of being drunk on the way home driving at 70MPH.
    Starship16 likes this.
  12. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Yikes! Another conspiracy theory. :eek:
    krmcg likes this.
  13. RRxing
    RRxing Senior Member
    2,552
    1,825
    NEPA
    I also have a bit of curb rash around the edge of the rim on both passenger side tires. I bought a small bottle of high gloss black enamel at a local hobby shop, but have yet to do the touch up - waiting for it stop raining... :(
  14. ETP
    2,802
    1,170
    Auburdale FL
    Question of the decade. So anyone try a 50 or 55 profile instead of a 45 for this tire as a replacement?
    Cannot believe how much these cost as compared to the standard Prius tire.
  15. Mendel Leisk
    41,744
    Someone here was advocating 205/50R17. That size is actually closer to 198/65R15 in Outside Diamter, every so slightly bigger. Fills the wheel well a bit better, the appearance.
    Only issue: they always seem to come in "Extra Load" rating, ride a little firm? The other issue: some places, Costco for example, will refuse to install anything but the spec'd tire sizes.
    Trying to think of his user name: ftl, f8l, something like that. Or was it @ATHiker , I'm a little fuzzy. He was the tire guru a few years back
    RCO likes this.
  16. ATHiker
    644
    560
    Massachusetts
    Four Touring
    Not me Mendel, but tires have been on my mind this past week.
    First, I got a bulge in the sidewall of one tire just before a long family trip. I ended up getting 4 new tires, even though they still had about 50% of their treadlife remaining. Probably caused by scraping my tire on the curb.
    I kept two of the old tires to be ready for my next flat, but just noticed one had a nail in it (never lost pressure though). Oh well.
    My challenge was that one of the new tires leaked air at a rate of about 3PSI a day. I took it back to the shop and they remounted it and sent me on my way this morning. I only half listened to the service writer babble about what they did.
    When checking the air just now I noticed they applied seven self-adhesive 1/4 ounce wheel weights inside the rim, right by the valve stem. Seemed odd.
    Anything unusual about my tale of woe?
  17. krmcg
    2,592
    2,392
    Whittier, CA
    When I worked at a tire store in my youth, if a tire needed a large amount of lead to balance it I would break it loose and spin it on the wheel 180 degrees. Because sometimes the imbalance in the the wheel and in the tire combine to make a problem. Most don't bother to do this and just apply the weights as directed by the machine. If you don't notice a "wobble" or "shake" it is probably OK.
    RCO, ETP and Mendel Leisk like this.
  18. ETP
    2,802
    1,170
    Auburdale FL
    That's what I did.
    krmcg likes this.
  19. yeldogt
    yeldogt Active Member
    810
    313
    NE
    We run them in the 34 range ...... played around with it a little bit on the Gen 3's --------- less on the 4's. We could get 60mpg on the 3's and its even easier on the 4's. The cars run too hard with anything over 34 IMO ..maybe you get used to it if you only drive the one car. It's also noticeable in the rain
    The plastic inserts are designed to make an already ugly wheel even more so ... I wish Toyota would hire away a designer from Porsche. Or ... just flat out copy them. Boy, are the Toyota wheels ugly .... some of the Lexus are a bit better .. only because they copy.
    I have owned many Toyota and Lexus vehicles -- but I wish they had better styling. one wonders how they can keep making these bland boring designs.
  20. Mendel Leisk
    41,744
    3rd gen 17" rims looked good, and 3rd gen 15" PIP rims. The rest of 'em, with the plastic dreck, not so much. :(
