Tire woes. Two flats in 4500 miles.
Discussion in 'Prime Main Forum (2017-2022)' started by Michael Nielsen, Mar 1, 2017.
  1. Michael Nielsen
    67
    88
    Dover, DE
    We're on a mighty road trip (Delaware to Tucson thus far) and I just had my second flat tire. The car only has 4,300 miles in it and I have had to pump goo into two tires. The two Toyota dealers that I have visited (Santa Fe and Tucson) have not had the official goo tank in stock. ("We'll have to order that."). Wth? I had to buy a third party pump and third party goo in Santa Fe and thank goodness I did because the passenger side rear started going flat between Phoenix and Tucson. One flat can happen, but two flats before 5,000 miles? My strong impression is that these Bridgestone tires are crap. With no spare and not having run-flat tires, the Prime is not a comforting car to drive on the wide open spaces of western America.
    I reckon that when we get back to Dover, I am going to order three or four bottles of the Toyota goo but in the meantime, Toyota, mail a few bottles of the stuff to all your dealers. Get real.
  2. Mendel Leisk
    41,826
    Maybe give up on the goo?
    My remedy:
    Temp spare
    Plug repair kit
    Air pump
  3. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    Sorry about the bad luck...what caused the flats? what states?
    For a long road trip need to consider taking a spare as some do with PiP and Prime.
    Others say they never had a flat in their whole life, so it's just bad luck.
    Also some get good at plugging small nail holes with a kit.
    PS- Nice Harp! We have one a little like that but does not get played anymore.
    #3 wjtracy, Mar 1, 2017
    charmingboogie likes this.
  4. Mendel Leisk
    41,826
    What are they charging for the goop bottle?
  5. Michael Nielsen
    67
    88
    Dover, DE
    First flat was in Elk City OK. Second flat on I-10 between Phoenix and Tucson.
    I called Toyota customer service while waiting here in Tucson for the tire repair. The very nice rep on the phone agreed that not being able to get the Toyota goo at any dealer was a problem. She is trying to get some here before we leave tomorrow morning.
    I wish I had Michelins on the car. I drove the hell out of the ones I put on my 2005 Honda CRV and never had a flat. Are low resistance tires more vulnerable to flats than mud and snow radials?
    Toyota4Life and bisco like this.
  6. Michael Nielsen
    67
    88
    Dover, DE
    I don't know.
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    I hope you do know that the goop is ONLY a temporary fix......right ??
    You can't blame the tires until you get them inspected for punctures, etc.
    You absolutely need to get the failed tires replaced or properly fixed......NOW.
    When the goop fails, more than the tire might be damaged.
  8. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    I'm the other Prime driver in Delaware. My car came with Dunlop tires that I replaced with Michelins (Grand Touring) after about two weeks. Couldn't stand the Dunlops for how the car handled and lack of traction on wet days. On Tire Rack they are the worst rated in class for available LRR tires that would fit the car. I just threw the Dunlops away and bought the Michelins so I wouldn't have to drive on crap tires for the first couple of years with the car.
    Toyota4Life, thatoneraccoon and bisco like this.
  9. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Wow.
    I have Bridgestone Ecopias on my Prius (third set - now on the Pluses) and in my entire life of driving (over 30 years), I've never had a flat tire.
  10. bisco
    52,286
    sorry to hear it, no fun on a road trip. i agree on the tires, get a good set of michelins. i just put on energy savers, and they're fabulous.
  11. Michael Nielsen
    67
    88
    Dover, DE
    Of course. The first one got fixed after having to drive 100 miles to the the nearest open tire shop. The second one is damaged from running on low pressure and has to be replaced. (Why doesn't the navigator lady announce a tire pressure problem?)
  12. bisco
    52,286
    no tpms warning?
  13. Michael Nielsen
    67
    88
    Dover, DE
    A light among a jungle of indicators and beeps.
    PT Guy and bisco like this.
  14. bisco
    52,286
    i know, right? same as low gas.:rolleyes:
    kenoarto and thatoneraccoon like this.
  15. Mendel Leisk
    41,826
    Any tire can pick up a nail: both our stock tires and snows are Michelin, and both have had flats. In both cases I did a plug repair, no further problems.
    Did your TPMS sensors survive the goop? Still to be determined?
  16. ETC(SS)
    7,313
    I believe that if I were traveling that much I'd just pack along a spare tire, small jack and a suitable lug wrench.
    I just did some quick checking and Toyota compact spares and OEM jacks are available on flebay for < $100.
    LRR tires are harder than regular tires, so they're theoretically more susceptible to FOD damage.....right?
    Naaah. Not right.
    All tires can and will be punctured by nails (especially roofing nails) screws, rebar, bricks, angle iron, small children (just seeing if you were paying attention) or anything else in the road that's fairly hard and sharp.
    We've had technicians shred tires to the point where you can put the can of spray-and-pray goop into the hole because they were on a mental coffee break while driving and "didn't see that cinder block in the road."
    Since even drivers who are paying attention to the driving task and not drafting cannot be expected to avoid nails and screws.......flats are GOING to happen if you drive enough.
    Fortunately......most tire punctures can be repaired by the goop but I would IN NO WAY call this more than a very temporary fix that will get you to the nearest tire shop for a patch or a new tire, and NOT to a stealership for another can of goop.
    UNfortunately, the goop will not repair all tire damage, and in my (minority, these days) opinion only fools venture far from home without a proper spare - where "proper" does not even mean the little doughnut rim that used to be popular as a cost savings measure before they decided to just give you a $5 can of fix-a-flat as a further cost savings measure cleverly disguised as a "weight saving" measure for people that complain about cars that do not have a large enough cargo bay.
    ---can't make this stuff up. :D
    Many people who live in the frozen north and experience (for now) snow and ice buy Corolla rims to mount snow tires on.
    I'm thinking that one of these rims with an inexpensive tire would find its way into my cargo bay if I were to buy a Prime, and I would stick the goop into a saddle bag on a motorcycle.
    AS ALWAYS.......
    YMMV
    Mark57 and Toyota4Life like this.
  17. Lee Jay
    5,850
    4,036
    The Prime comes with a jack and a lug wrench.
  18. ETC(SS)
    7,313
    GREAT!
    2 less things to buy if I ever get one..... :)
  19. Lee Jay
    5,850
    4,036
    I'll replace the goop and its special compressor with a regular small compressor and a plug kit. Between proper tire maintenance, the plug kit and a cell phone, I shouldn't ever need a spare tire.
  20. Michael Nielsen
    67
    88
    Dover, DE
    I'm giving it serious
    Yes, TPMS work fine after goo. I guess I just had bad luck with the Bridgestone tires but there is an old saying, "Fool me once, shame on you; fool me twice, shame on me." I will probably blow the money and buy Michelins before I take the Prime to Cape Breton this summer.
    I do appreciate the kind advice about tire patch kits and buying a temp spare. However, I am a Prime driver because of climate change but I am not a car geek. Like most of the car drivers out there, I don't change my oil and I don't patch tires. For the Prime to be a reasonable choice for the average bozo driving a typical sedan, Toyota has to balance the high MPG goal with the typical driver's expectations about safety. Patching a flat in the dead of night in the high desert in Arizona is not in the playbook. I know this is a bit contrarian on the forum, but after you have used up the only solution to a flat tire and still have 100 miles to drive to the nearest professional tire repair, and the manual says you should only drive 60 miles on a goo loaded tire, folks, that's not so good. Just sayin'.
    breakfast and Mendel Leisk like this.
