Upgrade / Replace Prius Seats? Desperate!!
Discussion in 'Gen 3 Prius Main Forum' started by tart_green, Feb 25, 2017.
  1. BZzap!
    BZzap! Senior Member
    1,607
    877
    BTW, I live in SoCal.
    Unproductive1 likes this.
  2. dmeans2anend
    dmeans2anend Junior Member
    usa
    I
    Thanks. But, wow expensive! $630 / pair..... Hhhmmm..... A bit steep for my humble pragmatic budget....
    I'm the sheeps would say otherwise. :0)
  3. BZzap!
    1,607
    877
    I guess you didn't really mean what you said in your original post... [I will pay any price to keep this car and have a better seat.] I believe that price is negotiable. I would agree that it's too high. I paid about 1/2 the price. I would, at least, give Mike a call and tell him that you you got a recommendation from Jim. I believe he will know who you are talking about. See what happens. Can't hurt.
  4. dmeans2anend
    usa
    I
    BZzap!, in reply to your comment:
    "I guess you didn't really mean what you said in your original post... "
    I think you have me confused with tart_green who initiated the posting.
    I was simply offering suggestions to tart_green on a modification that I made that has really helped me with my back issues on Prius bucket seating.... and it cost me only $23 and a bag of popcorn kernels ;) but nothing as fancy or nice as a sheep skin seat. It does sound wonderful!
    Even at 1/2 price, $300 is still too rich for my humble budget. I'll stick with my cheapo mod instead and save up for the next vehicle. I do appreciate your suggestion though. I'm sure for those that can afford it, it would be a great idea.
  5. BZzap!
    1,607
    877
    Oops! So sorry!
  6. fatdawg
    fatdawg Member
    131
    55
    Bay Area, CA
    2014 Prius Plug-in
    I have the base cloth seats in the Prius, I hated it, my leg would always feel numb after just about 20 mins. My 2nd gen felt better in my opinion. However, after adding the Clazzios leather seat covers, my uncomfortableness went away. I can sit in the car for hours with no issues. There's a memory foam lining in the seat cover that makes it very comfortable.
    Not sure if this will help your back pain, but it's worth trying out. It has helped me out a lot.
    Btw, I'll be selling my covers soon, lease is coming to an end.
  7. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Wondering in the Clazzios, about how thick is the foam padding? And would there be enough loose space to add a widge cushion for more lumber support? Lastly, did you have to remove original covers or put on Clazzios? Thanks.
    For now I flipped backward on the headrest and added a neck cushion, so my head doesn't need to bent forward.
  8. mjoo
    mjoo Senior Member
    1,107
    1,311
    Michigan
    I bought a couple of generic sheepskin covers - $50/seat at Costco. My wife loves them
  9. Mendel Leisk
    38,239
    I've got a chronic weak spot somewhere in my back, a connection between muscle and cartilage that occasionally tears. Normally I find the Prius seats fine, but when I've got a back problem it'll take me 3~4 minutes to climb out of the car. But here's the thing: you could throw sheepskin in there, you could pull everything out and replace it with space shuttle seats, it's still gonna take me 3-4 minutes to climb out of the car. And hurt like heck.
    OP is spending 8 hours a day in a car, day in day out, and has hit the wall. Likely has a repetitive stress injury.
  10. MilkyWay
    MilkyWay Active Member
    819
    357
    MI
    After about 3 hours driving for Uber in my Prius (which is what I assume you are doing) I'd feel really claustrophobic, needing to stretch legs, and tailbone pain from sitting.
    I bought a coccyx cushion which helped a little...So my suggestion is cushion or find a Volvo seat out of an S40 and take to a mechanic...I am sure they can make it work and they are very comfortable. You'll just have a mismatched drivers seat (but you'll be more comfortable).
  11. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    I've heard that the power seats found only in the Prius 5 trim levels are more comfortable. I'm pretty sure that someone here did at least one switch. I can't remember if the seat airbags still worked, though. I don't think it should be all that hard to find one.
    I'm a big fan of the Recaro seat systems, but they're really pricey, and may need a custom install:
    Own something special - Overview aftermarket - RECARO Automotive
    (one day, I hope to be able to afford these again)
    Personally, I've found that the Obus Forme backrest and seat cushion work well for me when my back starts hurting, primarily because they have a rigid support that doesn't depend on the somewhat-mushy car seat in the Prius.
    Lastly, I strongly suspect that the best bang-for-the-buck would be to get the seats re-cushioned at an auto re-upholstery shop. I remember reading that Toyota chose low weight over driver comfort when designing the OEM seats, so higher quality (but heavier) foam might fix the problem permanently.
  12. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    Get the Clazzio Custom Fit Synthetic Leather Seat cover which allows for foam insert.
    Temporary fix would be to buy 2" polyurethane foam from Home Depot for $6 and make your own seat cushion.
  13. Madjik_Man
    Madjik_Man Junior Member
    Boulder, CO
    I
    You can always get Wet Okole seat covers and add all the bells and whistles, e.g. lumbar support, etc
  14. RyanM
    RyanM Member
    68
    40
    Wisconsin
    This guy finds the seats he put in his ct200h very comfortable. Sparco seats. $3,000 per seat ish
    RightOnTime likes this.
  15. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    :p:p I would love to have 2 of those seats! But 3200 bucks each... Gotta find myself a rich sugar mommy :whistle:
  16. RightOnTime
    RightOnTime Senior Member
    745
    1,614
    183
    Kidnapped in OC, CA
    There are other options out there that could make life much easier!
    Are you located in So-Cal?
  17. tart_green
    tart_green Junior Member
    34
    In the interwebs
    FOLLOW UP
    Thanks for all the suggestions!
    I appreciate all your time and assistance! :)
    I believe that I have been incorrect regarding the cause of the pain I have been experiencing. My IGNORANCE has caused my suffering!
    Im 6.1" and every car I've had in the past my head had been very close to the ceiling. Thinking that was the appropriate height I was suppose to be at, I jacked up my Prius seat to the top position. Also, I did not know that the steering wheel could move closer.
    So I have been sitting up too high AND pitched forward to reach the steering wheel. This poor ergonomic position has caused my back pain. Now I have the steering wheel closer and the seat lowered to almost the the bottom position.
    I drove yesterday for 8+ hours with no pain and no pain the day after!
    I am thankful for your help, this is a WONDERFUL community! :D
    CR94, RMB, Raytheeagle and 2 others like this.
  18. tonycd
    tonycd Member
    Glad to hear this story had a happy ending. Enjoy your Prius!
  19. Madjik_Man
    Boulder, CO
    I
    edit nvm.
    Holy crapezoids... never knew my car had this:
    MilkyWay and bisco like this.
