Prius c key programming
Discussion in 'Prius c Main Forum' started by sohaibk.n, Nov 14, 2016.
  1. sohaibk.n
    sohaibk.n New Member
    Salt (Balqa)
    Hi
    Guys is there any way to program a prius c 2013 fob key
    Here in jordan cos almost 200 -250$ programming
    iPhone ?
  2. Veliksam
    Veliksam Member
    108
    61
    Orlando
    2014 Prius c
    Toyota Techstream software and MVCI cable, $24 for both. You'll also need to buy some "G" keys.
    I programmed 2 extra master keys last month because my car only came with one key.
    Danny13pruisc3 and sohaibk.n like this.
  3. sohaibk.n
    Salt (Balqa)
    I want a Tutorial about how to do it !
    iPhone ?
  4. Roxas125
    Roxas125 Junior Member
    46
    US
  5. Veliksam
    Veliksam Member
    108
    61
    Orlando
    2014 Prius c
    You guys need to search on Google " Toyota techstream TIS how to install". You will find all the information you need.
  6. everdave
    everdave New Member
    Earth
    2015 Prius c
    Wow great! So I can buy eBay keys and program an extra for my 15 C with Techstream?
  7. Veliksam
    Veliksam Member
    108
    61
    Orlando
    2014 Prius c
    Yes, can be done easily.
  8. 08PriusXSJ
    08PriusXSJ Junior Member
    42
    Connecticut
    Just bought a 2012 Prius C two with less than 20K miles (Rebuilt Tittle) but the car came only with one key. I badly need to make a spare key for this car as soon as possible. I need some help on the following:
    1. Where to buy the key fob that will work with reasonable price?
    2. How to program the key?
    3. Should the key be cut first then program it or reversed?
    4. Where to have the key cut?
    Thanks.
  9. Roxas125
    46
    US
    EBay has the spares for around 20 to 25, you'll need a pc running Windows 7 32 bit, the Toyota software and pc to Toyota usb cable, the cable and software come in a bundle that costs around 20 or you can search for Toyota techstream latest version on Google and buy the cable by itself which should cost around 15
  10. 08PriusXSJ
    42
    Connecticut
    Finally, my son successfully programmed the key I bought from Ebay costing $22. The really challenge is to install the software in a 64 bit operation system because we don't have a computer that is under 32 bit OS anymore. The total cost is 22 + 25 (paid for the Techstream + Cable). Thank you all for the information.
  11. Prius Sí
    Prius Sí Junior Member
    SoCal
    2015 Prius c
    For anyone who doesn't have (nor want) a 32 bit Windows computer, this little device works great. Just successfully programmed a replacement key with transponder I bought on eBay. No issues whatsoever. All you need is to do is have your local locksmith cut the blank and then follow the (somewhat odd) directions printed on device's case. You'll need to toggle the switch shown in the photo accordingly to program the chip and/or the remote. I programmed the chip first and then did the remote.
    ICARSCAN for Toyota G and Toyota H Chip Programmer Vehicle OBD Remote Key Programmer G Device Smart Keymaker for Toyota G Chip Programming Via Obd2 Port
