HELP
Discussion in 'Gen 2 Prius Main Forum' started by Prakash, Jun 20, 2006.
  1. Prakash
    Prakash New Member
    76
    What seems to have happened is that my Hybrid Vehicle Battery became discharged, therefore not allowing the Prius
    to go into ready mode. Any suggestions on this problem? I am contacting Toyota first thing in the morning, so that they can
    inspect the vehicle.
  2. Prakash
    Prakash New Member
    76
    Any ideas will help.
    Thank You in advance. Toyota WILL be picking up this vehicle in the morning.
    Have a nice day everyone.
  3. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    How did your battery completely discharge? Are you sure it's your hybrid battery and not your 12v? I left the dome light on once and drained my battery. When that happened, the car honked and beeped before it died. Sort of a cry for help.
  4. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    <div class='quotetop'>QUOTE(Prakash @ Jun 20 2006, 03:54 AM) [snapback]273979[/snapback]</div>
    It is the 12V aux battery that boots up the computers and puts the car in Ready, not the hybrid battery. You might have drained your 12V battery, like Tony said.
  5. ghostofjk
    ghostofjk New Member
    979
    I think Scotty's right. You can just start it with jumper cables, Prakash, as per the owner's manual (the connection's under the hood, inside a plastic cover on the right side.)
    I'll take you to lunch if you depleted the HSD battery pack. You might need a drink or two.
