Prius 12V Battery went dead in 20 hours, Fob key won't unlock door
Discussion in 'Gen 4 Prius Main Forum' started by sgpriusdriver, Mar 14, 2017.
Tags:
  1. sgpriusdriver
    sgpriusdriver New Member
    22
    Singapore
    I last used my prius gen4 at around 9pm(+8 GMT) Monday. At Tuesday 5pm (+8 GMT), when I went to the prius, the 12v battery had already died, thus the keyless entry won't work. Tried to use the mechanical key located in the fob but it won't unlock the door no matter how much I twisted.
    Now had to tow the car back to the workshop.
    Anyone knows why the mechanical key won't work?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Have you used the key before? I wonder if it's the wrong key. Seems unlikely with a car I assume you bought new, but otherwise, it should work if you turn it the right way.
    alanclarkeau likes this.
  3. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    The user's manual says how you need to use the key inside the FOB to mechanically open the driver's door. Including which direction.
    Question is though: how did the 12V battery drain so fast in a brand new car?
    RCO and alanclarkeau like this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The mechanical key will only go one way round - but then I think it'll only go in one way. There is little leverage because it hasn't got a Bow, only a Shoulder to try to hold, and takes a little effort to turn, but not excessive.
    RCO likes this.
  5. jerrymildred
    11,517
    14,157
    Tampa, FL
    Interesting! I wonder if it's a generational or a market difference. Our U.S. generation 2 & 3 keys go in either way and turn either way. The wrong way simply does nothing except make a little noise (assuming the 12V battery isn't dead ;)).
  6. alanclarkeau
    7,045
    7,593
    It's pouring rain outside and 11pm - I'll double check in the morning upload_2017-3-14_23-17-57.png .
  7. bisco
    52,386
    12v on a '16 is more robust, this is unfortunate to hear.
    kithmo likes this.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Yes I agree, since the Gen 4 shuts everything off after a while (30mins ?) unless it's in ready mode. o_O
    RCO and bisco like this.
  9. Prodigyplace
    12,677
    11,830
    Central Virginia
    In Ready mode it would charger from the traction battery & start the engine as needed, wouldn't it?
    RCO and kithmo like this.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Yes, so again it shouldn't go flat. AFAIK the only thing you can leave on are the parking lights, maybe that's what the OP did ?
    RCO likes this.
  11. alanclarkeau
    7,045
    7,593
    Yes - mine turns the hatch light off after 20 mins - I was there when it did it once. Never tried the parking lights - on one of my cars, FORD or KIA?? they would turn off after 20 mins or so too.
    RCO likes this.
  12. bisco
    52,386
    what if you leave a door open, or turn on a map light with the switch?
    RCO likes this.
  13. alanclarkeau
    7,045
    7,593
    Just checked - it only goes in one way, just won't slot in the channel the other way. Turn one way to lock, other way to unlock.
    RCO, jerrymildred and bisco like this.
  14. alanclarkeau
    7,045
    7,593
    Hatch light turns off after 20 mins - as does the light over the mirror which my Mum keeps leaving on.
  15. bisco
    52,386
    this is a new feature, and a long time coming. would have saved a lot of batteries over the past 12 years.
    RCO likes this.
  16. alanclarkeau
    7,045
    7,593
    That's odd - I thought car makers have done this for more than a decade - my 2006 KIA RIO did.
    RCO likes this.
  17. bisco
    52,386
    for the last 12 years, we have been speculating that there was something special about the prius, that didn't allow toyota to use this feature.
    similar to, why does toyota allow the car to be driven without the fob in it? i suppose that will come in time.
  18. Prodigyplace
    12,677
    11,830
    Central Virginia
    Perhaps part ownership in a battery company?
  19. bisco
    52,386
    i hope so. would be crazy to build hybrids and not.
    RCO likes this.
  20. sgpriusdriver
    22
    Singapore
    I have used the manual keys before and they do unlock previously.
    According to my workshop, the 12V battery has failed. It's under Toyota warranty. So it has to be replaced.
    To note Prius will beep alarm if you lock door without turning off any of the front lights.
    Also I haven't left anything powered on when I left, I have checked before I went off.
    If you are in ready mode, toyota won't allow you to lock the car doors from outside.
