Prius Prime width
Discussion in 'Prime Main Forum (2017-2022)' started by bluzfan35, Mar 15, 2017.
  1. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    My dad used to do that with the tennis ball for years. I started doing the tape with my V, which I inherited when he passed, but the rear cam was not as good as the Prime. If Bluzfan35 uses either method, he should be fine.
  2. bluzfan35
    bluzfan35 Junior Member
    55
    missouri
    It will mostly depend on if i pull in or back in. Yours would be best with backing in and even if i pulled in yours will be helpful with backing out in the mornings. Just have to figure how to do it. Tape might not work in the driveway.
    Prius from Dad likes this.
  3. bisco
    51,840
    when i pull in straight, backing out is a cinch. i do go slowly though, watching the passenger mirror as it passes the jamb.
    bluzfan35 likes this.
