  1. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    There's gonna be a pretty good turnout this year. :)
    sfv41901 and Dylan Doxey like this.
  2. 2ZR JDM
    2ZR JDM Active Member
    106
    142
    Redondo Beach
    It's an electric brushless motor driven capable of 4000 watts.
    Honestly idk if it's fuel cut or throttle closing. But from reading Julian article ( AutoSpeed - The Story of Turbo'ing a Hybrid Prius, Part 4 ) it seems like I'm having the throttle closing cause the ECU recognizes some preset parameter set by Toyota..
    I tried doing a boost leak test and the only thing I suspect leaking is the brake booster line. I'm going to try installing a one way check valve on that line.
    If that doesn't work I'll also try disconnecting the MAP sensor.
    SM-N900A ?
    Tracksyde and Justdidit like this.
  3. Enzo Batkhuu
    Enzo Batkhuu Member
    31
    254
    Ulanbator Mongolia
    Four Touring
  4. SubCode
    SubCode Senior Member
    739
    1,341
    "pimp..."
    sfv41901 likes this.
  5. JoshM
    JoshM Member
    37
    Mid TN
  6. Imaginex20
    Imaginex20 Active Member
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    IMG_3775.JPG IMG_3774.JPG Got my trunk garnish color matched and debadged. Also made the emblem backing color matched.
  7. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    What in the world?
    2ZR JDM likes this.
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Dylan Doxey, apt5020 and Imaginex20 like this.
  9. Imaginex20
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    I agree. I couldn't really stand that silver panel, threw off the look
  10. SubCode
    739
    1,341
    I got in a conversation with SFV41901 about debadging..I have a persona...only has 1 badge I wont remove..my preference...but mr Imaginex20...yours look clean!:cool:
    sfv41901, Dylan Doxey and Imaginex20 like this.
  11. MPGRaja
    MPGRaja Senior Member
    469
    1,679
    Corona
    Got a question. I have 17x7.5 45 offset PF01. I want to add 25mm spacers in the rear. Will that poke out too much or will it be flush with the body?
    Thanks
  12. andino
    andino Senior Member
    746
    551
    San Jose, CA
    It'll be tight I think. I ran 18x9 +35mm for flush in the rears. You can base your wheel offset calcs on that if you're curious. I had to stretch to make it work as well if you're going meaty, you may want to be a few millimeters conservative.
    MPGRaja likes this.
  13. SubCode
    739
    1,341
    I thought you were flush already?
  14. MPGRaja
    469
    1,679
    Corona
    The front is but the rear isn't from what I see. I want to get it as close as I can and lower it a tad bit more.
  15. MPGRaja
    469
    1,679
    Corona
    I had test fitted my 17x9.5 38 offset rpf1 but they poked out just a little bit but still looked really good. I'm trying to get somewhat the same effect.
    Montgomery, andino, 2ZR JDM and 2 others like this.
  16. saulbassfan
    979
    3,108
    Southern California
    Met up with @sfv41901 to discuss some plans for Toyotoafest.
    sfv41901, Johnsk93 and Dylan Doxey like this.
  17. SubCode
    739
    1,341
    My inner voice wa$ talking to me "I dont wanna $top modding but...then you bought another part?"
  18. 2ZR JDM
    106
    142
    Redondo Beach
    Today I installed an APEXi Grounding Kit. I doubt it will make any difference in MPG or engine smoothness but it was laying around in my garage, free, and the red glowing logo looks cool.
  19. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    It might be flush but you might rub. It all depends on your tire setup and fender setup. Stretch tires and shaved fenders might work.
    MPGRaja likes this.
  20. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Cheap mod for your passenger
    saulbassfan, sfv41901, Jk818 and 4 others like this.
