Planning Ahead for an EVSE and a Charging Question
Discussion in 'Prime Plug-in Charging' started by DavidA, Jul 2, 2016.
  1. drash
    drash Senior Member
    2,576
    1,315
    Upstate NY
    Commercial version of the Keurig. It only accepts k-cups so I'm assuming version 1.
    Unsupervised!
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
  3. drash
    drash Senior Member
    2,576
    1,315
    Upstate NY
    Clipper Creek was a big help in helping to diagnose this issue. They responded within 5 minutes from first an email inquiry then a phone call to follow up. They know their equipment well and it was rather easy to watch my wife brew a cup of coffee and I kept an eye on the EVSE. Sure enough when the Keurig brewed her coffee, the red light came on.
    Unsupervised!
    jerrymildred likes this.
  4. jerrymildred
    11,517
    14,147
    Tampa, FL
    That's great service!
  5. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
  6. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    From the link above..."
    --quote--
    Does the circuit require a GFCI?
    No, GFCI protection is not required for 240 Volt EVSE whether hard wired or cord-and-plug connected.
    • NEC Art. 210.8 requiring GFCI protection for branch circuits only applies to 125 Volt, single phase, 15- and 20- ampere receptacles
    • NEC Art. 625.22 requires a listed system of protection against electric shock of personnel. This is part of the internal components of the EVSE called the charge circuit interrupting device (CCID)
    --end quote--
    So, apparently the EVSE (charging station) includes a device equal to a GFCI. Give the National Electric Code article number 625.22 to your electrician or inspector.
    Mike Dee, how can there be 110 and 240 volt home voltage when the higher voltage is the sum of the two legs of the lower voltages? We all know that the home wiring is L1, L2, and neutral, plus a safety ground. L1 to neutral is about 120 volts, or 118 or something similar, and L2 to neutral is about the same, and L1 to L2 is about 240 or 237 or something like that.
    drash likes this.
  7. Tumo135
    Tumo135 Junior Member
    2013 Prius Plug-in
    Thanks. I am going to give the ferrite a try. Such a random issue.
  8. jerrymildred
    11,517
    14,147
    Tampa, FL
    Those voltages are nominal. Over the years, voltages have increased. My 120V outlets usually measure 130 or thereabouts. We used to call it 115 volts. So the old terms get mixed with the new ones and I don't worry about their precision.
    Is that because the L2 charger has GFCI built in? If so, that's interesting since the Toyota L1 charger also has it. Anyway, you're right that it's not in the NEC for 240V. My mistake. But I think it might be good to check local codes because they are sometimes more stringent.
  9. CharlesH
    2,796
    1,163
    Roseville, CA
    Part of the definition of an EVSE is that it has GFCI functionality. This is regardless of the voltage. With level 1 and level 2 charging, the charger is in the vehicle, and the externel thing is basically a smart power adapter. With fast DC charging (not available on the US version of the Prime), the charger is in the charging station.
    #29 CharlesH, Mar 21, 2017
  10. Tumo135
    2013 Prius Plug-in
    So far my first attempt with two ferrite cores I still had the issues. Back to the drawing board.
  11. drash
    drash Senior Member
    2,576
    1,315
    Upstate NY
    You might want to put the coffee maker on it's own line conditioner and/or UPS that has a line conditioner built in. Or, for instance, a Tripp Lite Isobar that has built in noise filters. Direct plug-in models are about $26. Typically line conditioners and surge suppressor that also have noise filters are place in front of the equipment you want to protect, but I'm assuming the noise filters work both ways.
    If you want to kill it altogether, you can also use an isolation transformer, but that is a rather radical (and ugly and expensive) solution. The biggest I've ever used could only handle 5 amps.
    Unsupervised!
  12. bisco
    51,786
    sounds like the real problem is clipper creek?
  13. Tumo135
    2013 Prius Plug-in
    Going to give it a shot. I will report my findings.
  14. DavidA
    2,344
    1,820
    Chicago western burbs
    / not actual help - humor mode ON
    Just saying, that if the Keurig was mine and I had car charging problems, I'd just unplug the Keurig when not in use. Either that, or try plugging the Keurig into the Prime while the car was charging? ;)
    / not actual help - humor mode OFF
  15. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    Maybe this will help. :)
    DavidA, drash and Tom_06 like this.
