Cutting in a sun roof?
Discussion in 'Prime Accessories and Modifications' started by ChachabahPrime, Mar 21, 2017.
  1. ChachabahPrime
    74
    Island Park, NY
    How about it? Anybody ready to put their Prime under the knife?
  2. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    Go to a specialist! There are specialist firms, look for the name Webasto (I don't know if that type if roof is still available), but back when I live in the UK there were firms specialized in fitting sun roofs, converting to convertibles (Crayford?) The big problem is compromising the integrity of the monocoque construction when cutting holes or removing large chunks!
    HPrimeAdvanced likes this.
  3. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Roof structure is not designed for that.....you will make big danger in case of side accident
  4. bwilson4web
    15,512
    No.
    If you want a moonroof, look at a new, 2017 Prius Level three which has a small MPG penalty compared to the Level Two ECO. That MPG penalty led to buying a BMW i3-REx and later, a Prius Prime Plus.
    Chaughten likes this.
  5. TinyTim
    TinyTim Active Member
    366
    224
    Seattle
    Waste of time and money.
    Chaughten and HPrimeAdvanced like this.
  6. bisco
    49,386
    someone had one done on a gen 3 and was very happy with the results.
  7. Trollbait
    11,509
    As stated, check with a specialist, but it likely won't be a good idea. Chances are high that a sun roof would require cutting through structural beams necessary for crash safety. The less risky aspect is that an openable moon roof will leak; factory options have rain gutters to keep the water out of the cabin.
  8. ChachabahPrime
    74
    Island Park, NY
    Is this just for the Prime? Others have done this other Prius without compromising the integrity of the car.
  9. Since2002
    Since2002 Senior Lurker
    936
    1,097
    Duluth, GA
    How do you know it didn't compromise the integrity of the car?
  10. ChachabahPrime
    74
    Island Park, NY
    Good point. In other words, many others have been enjoying without problems.
  11. bisco
    49,386
    just don't flip it, you'll be fine.
    ChachabahPrime likes this.
  12. Since2002
    936
    1,097
    Duluth, GA
    I could cut out a new window in my dining room wall, after deciding that the stud that was there isn't really needed, so no need to install a header. Even though I may be enjoying my new view for say three years without any problems, that isn't proof that I haven't compromised the structural integrity of my house.
  13. WilDavis
    2,492
    2,153
    49
    Just be careful when cornering in a rather aggressive manner! or when stopping suddenly! (you know it makes sense!)
  14. bisco
    49,386
    if you drove like me, you could cut the whole roof off. but it's hard to drive with an umbrella.
  15. WilDavis
    2,492
    2,153
    49
    I remember shoving my sister's umbrella out of window of school bus many years ago! (Still have the scars! )
  16. bisco
    49,386
    ah, siblings.:cool:
  17. ChachabahPrime
    74
    Island Park, NY
  18. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    Do you tend to corner & stop aggressively with your house or did you reply to the wrong posting? :LOL:
  19. Mendel Leisk
    38,651
    Wait what? Pictures!
    Personally, I would never do something like this, just too many negative ramifications. But the deed is done, so lessee. :)
  20. WilDavis
    2,492
    2,153
    49
    If you care to check, you will find that I said nothing about houses in my post!
