Replaced Dash panel, now climate control doesn't work
Discussion in 'Generation 1 Prius Discussion' started by Brian in Tucson, Mar 25, 2017.
  1. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    For the past week (!!!) I've been working on the dash of my 03. Got the brand new plastic from Camelback in Phoenix.
    Got it all back together and the climate control (all of it) that's below the radio now doesn't work. Only thing I can think of is the ribbon harness that connects the two printed circuit boards. It came loose when I pulled them off the remnants of the old dash. I've had it out twice now and checked the ribbon, still no luck. I even put the nuts on the two little bolts, thinking that that might be the grounding path.
    BTW, I can attest to the fact that the new center dash is NOT brittle!
    Any thoughts? I'm headed out to work on it some more. As in pull it out for the 4th time.
    Driving my Dakota, missin' my Prius!
  2. ChapmanF
    18,029
    From the way you wrote that, I can't tell whether you released the ZIF connector and let the ribbon loose, or it just got yanked out. I also don't know if that would make your difference, but it might be something I'd check.
    -Chap
    Brian in Tucson likes this.
  3. vaughnstark777
    183
    33
    Roy, WA
    2001 Prius
    I
    Can you send the website for Camelback in Phoenix?
  4. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    https://parts.camelbacktoyota.com/parts /index.cfm?action=selectCatalogYearMakeModel&siteid=214329
    Remove the space just after /parts in the url If you search for camelback promotional code, you can get an addition 3% off. Camelback didn't charge me for shipping, either.
    #4 Brian in Tucson, Mar 25, 2017
  5. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    It's been a week so my memory is hazy. I think I released the zif, but putting the cable back in, it doesn't seem to want to stay. Beginning to think I need to trace the leads with an ohmmeter and see if there's continuity between the two IC's. Kinda behind on some work (been working on a Prius) so it may be tomorrow before I can get the panel back out. I'm kinda surprised none of the roto switches work---the button switches don't even light up when you push them.
  6. vaughnstark777
    183
    33
    Roy, WA
    2001 Prius
    I
    Thanks
  7. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    I got it all back together, still no indicator lites on the climate control and rear window grid indicators. But the A/C is now working, I think Max is working, too. And I know the vent control switch is working. There are 2 gen 2 prii in Phoenix. If I can get an afternoon I may go see if they'll sell me a couple of IC's. Looks to me like the ZIF connector on the main climate control board is broken--doesn't suck down and hold the tape harness to the sub board where all the rotating switches are located. Mea Culpa, if I can get those two boards, my problem should resolve itself. I have a new skill set, I can get the dash disconnected and out of the car in about 15 minutes. Getting acquainted with the way the wiring connectors unlock helps a lot.
    For now, I'm gonna quit while it's working--if not good, at least okay. It all looks quite nice, tho.
    Upshot, I think, is that that ribbon wiring doesn't need to be unzif'd. It can all be transferred to a new dash wired together. Ya learn and pass it on
  8. Med Journalist
    Med Journalist Junior Member
    Philadelphia area
    I replaced the touch screen on the NAV unit in my 2011 Prius in 2017, and most things worked. Now my radio tuning knob does not change the stations, and the lights in the buttons do not work. Also, I may have lost the connection to the antenna since the radio does not pick up some stations. I suspect the ZIF cable to the NAV screen has come loose. It was a pain to seat it in the rest of the unit when I had replaced the screen -- very little play to work with in a very tight space. I am considering buying a ZIF extension cable. Does anyone know the number of pins (wires in the ribbon cable)? I think it may be 51 but I could use some confirmation before ordering an extension and unplugging the cable lest I disrupt what remaining features it does provide.
  9. ChapmanF
    18,029
    This latest post is about a Gen 3, but is tagged on to a Gen 1 thread. It would probably get more helpful answers in the Gen 3 forum.
  10. ronlewis
    ronlewis Active Member
    982
    196
    texas
    2001 Prius
    Hey Brian, I need to swap in a dash from my parts car to one of my running units. Looking at it briefly, I can't tell where to start. Looks like the climate control knobs have to come off, but I pulled and they don't move. Did you find a YouTube? Being lazy, I haven't even looked; just saw your thread.
  11. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    It's been over two years and I don't remember. Don't have a Prius anymore, either. Chap did a writeup about removing the very fragile surround, and I think there's a Youtube vid available, too. The toughest thing is to get the surround out without shattering it. They do break, getting very brittle after a minimum of 16 years in a car. Replacement Center Dash Panel | PriusChat
    IF I remember correctly, the knobs do pull off, the pushbutton plastic things come in from behind.
  12. ChapmanF
    18,029
    How 'bout a Dailymotion?
  13. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    That's why I posted the link to that thread.
  14. ChapmanF
    18,029
    the links go to different threads
  15. ronlewis
    982
    196
    texas
    2001 Prius
    Great! Thank you, sir. Sorry for being lazy. This heat is killing me, now I gotta go walk the dog, grrrr.
