Sleeping in hybrids- a/c run all night off battery?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Haraald, Mar 26, 2017.
  1. Haraald
    Haraald New Member
    25
    Seattle
    I'm considering a 2017 Highlander hybrid for camping, and I read that if you sleep in the Prius the AC will run all night, the gas engine kicking in for only a couple minutes every 30 minutes or so to charge the battery. Is the timing in the Highlander about the same as that? No dealership will let me sit in their car for 30+ minutes with the AC on lol
  2. JC91006
    JC91006 Senior Member
    16,767
    8,565
    The engine should kick on more often than once every 30 minutes
    Tim Jones and Data Daedalus like this.
  3. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Buying a hybrid car to save fuel and co2 and the planet, to then let it idle to have fresh air on a camping trip.....really?!!
    Fubar XIII and Tim Jones like this.
  4. Haraald
    Haraald New Member
    25
    Seattle
    Since I don't want this issue to distract from getting a good answer to my original question, I'll clarify- I'll be living in the vehicle roughly half-time; not just camping. I'm pretty sure the carbon footprint of living in a Highlander is far less than if I was in a house ;)
    3rd3rd, virgilius, 1prius and 7 others like this.
  5. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    As JC91006 says, the A/C takes quite a drain on the battery, so the batt will drain more quickly than half hour if A/C running. But if you are just trimming the temp a bit that would take longer. So if you are sitting in a Prius or Highlander you could probably prove that to yourself in 5 minutes.
    Tim Jones, Data Daedalus and RCO like this.
  6. Haraald
    Haraald New Member
    25
    Seattle
    I sat in a 2017 at a dealership for 5 minutes with the AC on max and the engine didn't engage; the salesman lost patience though so I couldn't test it longer
    Oddly, with the heat on max the engine didn't turn off; I guess it uses engine heat rather than battery to heat the interior?
  7. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    OK good...but are you sure you were running A/C to cool off or just the fan on high?
    RCO likes this.
  8. Haraald
    Haraald New Member
    25
    Seattle
    I'm pretty sure it was max AC, the air was really cold
    Data Daedalus likes this.
  9. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    sold one HiHy?
  10. JC91006
    16,767
    8,565
    From a full charge, it may take about 15 minutes for the engine to engage if you have the ac on high.
    After the engine engages, it'll only charge the battery a little before it stops. From that point, the ac should drain that little charge in about 5 minutes, then engine will kick on again
  11. Haraald
    Haraald New Member
    25
    Seattle
    That's the timing you've seen on your Prius for AC on max?
    RCO likes this.
  12. JC91006
    16,767
    8,565
    Yes, sometimes not even on max
    This is my experience waiting at the in n out drive through
    1prius and 'LectroFuel like this.
  13. ChapmanF
    18,133
    I just sleep through it, so I don't care what the cycle period is. :) I had an apartment with a loud air conditioner too (in fact, I think the Prius is quieter).
    Took me less than one night to acclimate to it and stop waking up.
    -Chap
  14. Robert2P1CT
    Robert2P1CT Junior Member
    Las Vegas, NV
    Good question, and two good choices of hybrids. Have you also considered the RAV4 hybrid? Still amazing but cheaper to buy and slightly better mpg than Highlander.
    I envy you, I wish I could live in my Prius part time, but my wife and kids still need me. Darn! LOL Hopefully, they won't need me in a few years so I can runoff and elope with my Prius and we will get lost in some majestic western national park. Ha ha
    BTW: There are many videos on YT of people who live full/part-time in their hybrids. There are tons about the Prius, I haven't looked for RAV4 or Highlander yet.
    Take care and Godspeed!
    1x1, Data Daedalus and RCO like this.
  15. ChapmanF
    18,133
    You can wait for the kids to launch and hang on to the wife ... a Prius'll sleep two in air conditioned comfort.
    -Chap
  16. Robert2P1CT
    Las Vegas, NV
    Good point! Thanks! I will try to work on my wife. She needs to learn to rough it in the woods with me in the Prius. :) Wish me luck!
  17. Haraald
    Haraald New Member
    25
    Seattle
    All the Prius sleepers confirm it's about 2 minutes charge every 30 min or so if temp is set at 68, but I can't find any info of how the Highlander behaves.
  18. Prodigyplace
    12,547
    11,771
    Central Virginia
    The Highlander has a larger engine. I do not know if the traction battery is larger.
    The other part affecting this could be the size of MG1 since it charges the battery. It could be larger since it starts the larger engine.
  19. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I think you're gonna want something more than luck for that, but all the best anyhow! :ROFLMAO:
    Data Daedalus and Prodigyplace like this.
  20. William Redoubt
    William Redoubt Senior Member
    1,228
    1,172
    Coronado Island, California
    In the Gen 4 Prius the ICE typically comes on at least once an hour for 2 to 3 minutes. If it is very, very hot, the frequency will increase. The frequency may be different for the Highlander.
