Plastidip fun
Discussion in 'Gen 4 Prius Accessories and Modifications' started by lohikaarme, Apr 2, 2017.
  1. lohikaarme
    lohikaarme Active Member
    337
    338
    NY
    2023 Prius
    Limited AWD-e
    Lets see how it holds up. Something more permanent (vinyl) was quoted at $650 plus tax.
    I did this with 3 cans of plasti dip, a few plastic drop cloths and a roll of painters tape. I did swap out the shark fin with a color keyed oem fin.
    fin: $30
    plasti dip: $15
    painters tape: $3
    drop cloth: $5
    total: $53
  2. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    I hope you park in shade are ....hot days and park in the open will elevate temperature inside
    RCO and alanclarkeau like this.
  3. Peter the pickle
    Peter the pickle New Member
    San Francisco Bay Area
    Three Touring
    That looks fantastic! How did you peel off the tape without compromising the edges on the dipped surface?
    MattStevenson likes this.
  4. PosauneGuy
    PosauneGuy Member
    123
    91
    California, here I come...
    2025 Prius
    Love it! Nice job!
  5. lohikaarme
    337
    338
    NY
    2023 Prius
    Limited AWD-e
    well when I am at home its in a garage
    I took a vinyl flat edge and pressed it on the plastidip on the car where the tape met and then pulled the tape. The tape and plastidip broke on the pressure point. I slowly moved along the length of the line
    RCO, Spaysship24, sttkailua and 3 others like this.
  6. sttkailua
    sttkailua Active Member
    190
    151
    Hawaii
    Cool,
    I did another car in plastidip.
    You can always remove, and return back to to original later.
    stt
    RCO, Spaysship24 and ajpn like this.
  7. Prodigyplace
    12,625
    11,807
    Central Virginia
    This would fit in with @krmcg and his black and white color scheme.
    RCO and krmcg like this.
  8. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
  9. Andyprius1
    2,327
    859
    Cool CA
    And cheap.
  10. OldNo7
    OldNo7 Member
    72
    26
    CT
    2014 Prius c
    Pinstriping the edges can take care of any compromised spots.
    Spaysship24 likes this.
  11. vince22
    vince22 Active Member
    205
    249
    califorinia
    very impressive.....
  12. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    All I can say is "Hell yeah!!"
  13. Mike Moon
    Mike Moon Member
    31
    48
    Marietta, GA
    Four Touring
    Who gives a shit? I have a black prius in Georgia and I'm so over hearing people lecture me about how black cars get hot in the sun. that's why windows roll down and air conditioning exists. Live a little! After all, white cars look like rental cars next to a sweet, black beauty.
    Andyprius1 and RCO like this.
  14. lohikaarme
    337
    338
    NY
    2023 Prius
    Limited AWD-e
    The only thing i can think of is that because it is flat black it might heat up a bit more than reflective black? I dont know. Its on the hood and roof anyway. The hood is going to get much higher temperatures coming from the engine, the roof is somewhat insulated from the cabin.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    In my past schoolboy physics lessons, we learned that dull black surfaces absorb and radiate heat more efficiently than white shiny surfaces. I remember we used to measure it with boiling water in tin cans, one of which was painted matt black. It involved some juggling numbers around on a blackboard with chalk to get a definitive answer...... Zzzzz
  16. lohikaarme
    337
    338
    NY
    2023 Prius
    Limited AWD-e
    I decided to do a little more and I perfected the way to get a clean line.
    The best way to do it is to mask everything off in such a way to allow for a disposable edge line layer of tape. This layer should:
    1. only sit on the car surface or another layer of tape because you do not want to be yanking plastic cover with it.
    2. is the layer that defines the edge you want to create
    Now the way it works is that immediately after you spray, you pull this layer off the car. Wait for the plastidip to dry and then you reapply this layer following the plastidip line and set up for the next application. You would repeat this for as many layers as you intend to spray.
    m.wynn, RCO and Mendel Leisk like this.
  17. lohikaarme
    337
    338
    NY
    2023 Prius
    Limited AWD-e
    good enough for government work
    IMG_20170416_184730.jpg IMG_20170416_184737.jpg IMG_20170416_184748.jpg IMG_20170416_184801.jpg
  18. Montgomery
    2,254
    2,241
    Orange County, CA
    Definitely not for the amateur!! Great job.
    RCO likes this.
  19. Mendel Leisk
    41,808
    You're on your way, to being "send nudes" mark II. :)
    m.wynn, RCO and grape808 like this.
  20. businessph
    businessph New Member
    mountain view, ca
    how did you get the lines so smooth
