My DCC got a little nervous today
Discussion in 'Gen 4 Prius Main Forum' started by Gen 2 Tom, Mar 29, 2017.
  1. Prodigyplace
    12,660
    11,827
    Central Virginia
    One word. Freeway.
    Is downtown Oakland a freeway? If not, DRCC was not designed for that situation.
    #21 Prodigyplace, Apr 2, 2017
    kithmo and RCO like this.
  2. krmcg
    2,592
    2,392
    Whittier, CA
    Yes
    RCO likes this.
  3. Tideland Prius
    16,611
    The day is sort of here. Just like how DRCC has been offered in Japan since the early-mid 2000s (on other Toyotas, not the Prius), the Prius is one of the first (if not the first) car offered with V2I and "connecting DRCC". The "connecting DRCC" works in conjunction with another car that has connecting DRCC (e.g. another Prius with that option). If two Prii come along with connecting DRCC in use, the two cars will essentially work as one entity. The trailing car will accelerate at the same time as the leading car. Currently, the car behind will accelerate only when there's sufficient space between the two cars. With connecting DRCC, the leading car will send info to the trailing car so that they can both accelerate at the same time, maintaining the same gap.
    This also works with braking. With regular DRCC, the trailing car won't brake until the gap starts to shrink. Connecting DRCC will allow the leading car to send info to the trailing car so that the two cars will slow down simultaneously.
    Future Toyota Integrated Safety Systems (2015 Edition) | PriusChat
    To be fair, he did mention it "failed" for his particular situation.
    If traffic happens to come to a complete stop (like in California) or if traffic slows to a crawl (where traditional cruise control will cut out)
    If it is braking, yes. It'll work as if you were controlling the car - if you lift off the accelerator for light reduction in speed, that won't engage the brake lights but if you brake to slow the car down, the brake lights will come on.
    RCO likes this.
  4. roadwarrior28
    roadwarrior28 Member
    68
    69
    Portland, OR
    Three Touring
    I never use DRCC in heavy traffic conditions, particularly urban interstates like in the Bay Area, it's just wholly inadequate to account for the type of driving and the density of cars.
  5. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    Thanks, Tideland, for the Toyota CRCC video and the Prius chat link. Very interesting... I met the owner of a Tesla model X (license plate Solar X) and the owner showed me around the features of the car. Already has self driving capacity. And gull wing doors with three rows of seating. that thing is a monster of a car!
    I want to go back to the DRCC and brake lights in urban traffic. So every time the car slows as cars ahead slow or another vehicle moves in front of me my brake lights will activate.. I can't see my brake lights, but I had surmised this is indeed the situation. In urban traffic with lots of slow and go and stop and go the DRCC brake lights may be confusing to other drivers. I've noticed brake lights flickering on Lexus / Toyota vehicles for several years. Could not figure out why the driver keep tapping their brakes.. now I know why.
    I usually change lanes and go around them.
    #25 tucatz, Apr 4, 2017
  6. tucatz
    501
    417
    Manzanita, Oregon
    Four Touring
    "The MacArthur Maze" is a confluence of 5 major highway arteries, built over a densely populated urban area, at the foot of the main bridge into San Francisco. Probably the worse traffic jams in the country. Thank your stars if you don't have to navigate this nightmare on a daily basis.
    RCO likes this.
  7. neopunk1
    neopunk1 Junior Member
    32
    SoCal
    My commute is through Los Angeles which is pretty bad and DRCC has been great especially in HOV lane. I am still kicking myself for not waiting on the Prime to take advantage of the HOV sticker. I find disengaging DRCC by pulling in the cruise control stalk is smoother comparing to stepping on the gas pedal. If you can anticipate what is going on in front of you (mostly the idiots that try to change lane to gain an extra 5 ft), DRCC could be pretty smooth.
    tucatz likes this.
  8. djasonw
    djasonw Active Member
    962
    123
    Coconut Creek, FL
    I have a similar system on my 16 Civic. It is called Low Speed Follow and works pretty much like the Toyota system. The disclaimer in the owner's manual states that it is meant for use on the freeway. I have used it in suburban driving and it works very well. In areas where there is heavy congestion, I drive myself. One day in the not too distant future we will laugh at these posts. I envision a time when all cars will be self driven and us drivers will just be there for the ride (no fun!).
    RCO likes this.
  9. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    Quite. Using the brake solely as a way to disengage DRCC is unnecessary and a bad idea.
    Also the manual clearly states that the DRCC should not be used in heavy traffic.
    DRCC is a very useful tool but it is driver assist not autopilot. If used properly I find it is a huge improvement on non adaptive Cruise.
    No fail of the car or DRCC is described in this thread in my opinion. A tool is only as good as the person using it. Use DRCC well and it works very well indeed in my experience.
  10. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    What neopunk1 said is the way to use DRCC. I use a finger on the stick to disengage it when you see it's going to harshly apply the brakes. The system is nice, but far from perfect.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I've found that auto braking feels much smoother at the 3 bar maximum range setting.
    Tyfly and kithmo like this.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    And less spare underpants you need when approaching standing traffic.
    RCO and Tideland Prius like this.
  13. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    I would ideally like the car to see ahead further than the 3 bar setting and I too have learned to cancel DRCC and slow the car myself when I see cars slowing down a lot some distance ahead, to avoid the car braking more harshly than I would when it gets closer.
    Once I am closer and matching their approximate speed I then push the control up to resume and let DRCC take over again.
    RCO likes this.
  14. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Just another occasion when less certainly doesn't mean more.
    kithmo likes this.
