Custom startup screen prius prime
Discussion in 'Prime Audio, Electronics, and Infotainment' started by yoyoman, Dec 6, 2016.
  1. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    I wanted to transfer a new jpg into entune. So that when I fire up my car, a new pict will show on my display monitor.
    There is a quick YouTube video showing 2 folders to generate and save my jpg into the folders. After insert my USB drive into my USB port, I'm getting an error message below.. is this a bug that Toyota will need to fix??
    #1 yoyoman, Dec 6, 2016
  2. ttait
    ttait Active Member
    273
    163
    Southern California
    Don't break it before it's paid for ;)
    priuscatprimeguy likes this.
  3. yoyoman
    342
    117
    San Jose California
    Agree
    iPhone ?
  4. yoyoman
    342
    117
    San Jose California
    I have found the issue in my old USB drive. After replacing with another USB drive, my prius prime read it immediately..
    iPhone ?
  5. Christiann.v
    Christiann.v New Member
    Downey
    Did you get your prime to show the image at startup? Also, is yours the big screen model?
  6. Full Frontal
    Full Frontal New Member
    Orange County, CA
    Bump.
    Has anyone figured out how to update the Prius Prime's (Premium/Advanced models) startup image and display off image?
  7. DavidA
    2,349
    1,824
    Chicago western burbs
    What do you mean by "update?" Update to what?
    Also, you can turn the startup screen and music off. It is in the settings.
  8. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    Someone said they used a flash drive to get the startup image changed. If the flash drive doesn't work, you may need to format it and try again or use another one.
  9. Pdog808
    Pdog808 Active Member
    434
    290
    Los Angeles
    2018 Prius Prime
    This may be the video that is being referred to on how to change the startup and shutdown image:
    Has anyone tried this on their Prime successfully?
    Also, if they have, does anyone know the aspect ratio of the startup/shutdown screen image ?
    Thanks!
    Riversong and SaraBBrown94 like this.
  10. yoyoman
    342
    117
    San Jose California
    There are YouTube videos showing the procedure but I think it was for the Tacoma truck. Anyway, same process I followed and worked.
    iPhone ? View attachment 128722
    #10 yoyoman, May 5, 2017
  11. Pdog808
    434
    290
    Los Angeles
    2018 Prius Prime
    @yoyoman - thanks, you wouldn't happen to know what the aspect ratio of the picture was ? How well did your pic fit in the startup screen?
  12. yoyoman
    342
    117
    San Jose California
    I didnot change the aspect ratio. Everything seem to be right on the screen.
    iPhone ?
  13. Pdog808
    434
    290
    Los Angeles
    2018 Prius Prime
    Thanks I'll give it a shot!
  14. yoyoman
    342
    117
    San Jose California
    Here is my screen shot..
    iPhone ?
    pjksr02 likes this.
  15. Pdog808
    434
    290
    Los Angeles
    2018 Prius Prime
    Nice! That's a Prime Plus, correct?
  16. JimE2017
    JimE2017 Junior Member
    29
    43
    Maynard, MA
    Has anyone got the start and stop images to work with the 11.6 inch screen in the advanced package to work. the software for the small screen is totally different and has a different manual. The tall screen has the online manual of OM47B68U.PDF. It looks like Toyota has taken functionality out of the top of the line screen software. Or the are behind schedule. Not the best way to showplace a new product. Are we looking for a new update???
  17. Tideland Prius
    16,632
    Not available for 11.6" screen.
    TonyPSchaefer likes this.
  18. stevepea
    stevepea Senior Member
    535
    581
    Though I haven't done it yet myself, I was thinking it might be neat to have this.
    Hey... you never know...
    eric4214, Vacaboca, talker2 and 5 others like this.
  19. JimE2017
    29
    43
    Maynard, MA
    I understand that the option is not there at the present time, does anyone know why? Typically when a software package is extended for a new top of the line option, you do not loose existing functionality. The 2017 Tacoma Limited we also have has similar software with those functions and does not have the video playback. The 11.6 "s software has had other limitations in the number of files, folders and file within a folder expanded, but lost the statrup and shutdown custom imaging capability, will it be in a later release?
  20. stevepea
    535
    581
    One of the nice (unexpected) things about getting the 7" Plus trim (though you're right, it does seem strange that they didn't include that functionality in the 11.6 software)..
