No option for pre departure Climate operation on Euro models
Discussion in 'Prime Main Forum (2017-2022)' started by GT4Prius, Apr 6, 2017.
  1. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    Rather disappointed and a bit mystified to find that this option is absent from the Charging menu on my Brand new top of the range 2017 Euro Excel model.
    Can still use the key fob for remote climate control, but obviously that's not automatic.
    Will ask Toyota UK about this, but any thoughts appreciated from PCers.
    52,257
    have you read through the owners manual?
  3. Tideland Prius
    16,594
    Note that your charging schedule that you're setting has to be in the "Departure" mode and not "Start". IOW, you're setting the time you wish to depart and have the battery fully charged, rather than setting the time begin charging.
    On the 4" MID, see Step 8
  4. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    Thanks Tideland. Yes I have set Departure and not start time. Its not user error sadly. It just doesn t have this feature.
    Yes I did. It is clear that not all versions have this. It says "if equipped".
    What I don't understand is why. We have remote climate on the key fob, so all that is missing is a software option to switch it on automatically.
    Why they disable this for some markets is a mystery to me? Can't see the point.
    #4 GT4Prius, Apr 6, 2017
  5. Tideland Prius
    16,594
  6. unicorn
    unicorn Member
    48
    EU
    In EU manual: "Traction Battery Cooler (if equipped)" pp.142
    Traction Battery Cooler could be important. Is it available in your model?
    General question: What happens if a car is parked in the hot sun?
    High temperature can be dangerous for battery life span. Temperature Management?
    #6 unicorn, Apr 6, 2017
  7. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    Toyota UK blog says that UK models have a "Traction Battery Warming System":
    Introducing the new 2017 Toyota Prius Plug-in - Toyota
