Rear brakes worn after 30,000 - caliper?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mike Kapala, Apr 12, 2017.
  1. Mike Kapala
    Mike Kapala Junior Member
    Exit 33
    Good morning all! Love my 2010 Prius which has about 163,000 miles on it. While taking winter tires off the mechanic (local shop) said the rear drivers wheel wouldn't spin until bolts taken off. Said caliper was shot and would need one new caliper and new rotors and brake pads for the rear. The same mechanic replaced them all around less than 30,000 miles ago. Odd thing is I had oil changed at Toyota a few weeks ago and they said my rear pads were measured at 6.
    I definitely can hear the drag when I back out of the driveway in the morning but that's it. I just feel like the mechanic may be trying sell me more than I need. Thoughts?
    Thank you!!!
    52,286
    the sound you hear backing out is rust on the rotors. i would get a second opinion, and have them show you what they find if anything.
    you might just need to have the slide pins lubed, which many mechanics miss, because they think everything is the same, and don't look up individual model instructions.
    or, maybe the lug nuts were overtightened on that wheel. they don't torque them either, which can deform the wheel with an impact wrench.
  3. Mendel Leisk
    41,826
    Is he a "generic" mechanic, ie: it's not a Toyota speciality shop or Toyota dealership? Even the latter may not be well versed in one of the gotchas of 3rd gen Prius rear brakes:
    When reinstalling the caliper, it's imperative that the caliper piston spoke pattern is oriented so that it "straddles" the pin on inner pad backing plate. Further, the pads need to be well seated (by brake pedal pushes), and perhaps a test drive, before any application of the parking brake, which will try to rotate the piston. A final test to ensure all is good: raise the rear of the car and try spinning the wheels (with parking brake off): they should turn fairly easily. Not completely friction-free, there's some overhead with disc brakes, but they should easily do one or two revolutions. IMHO a test drive and subsequent wheel spin test should always be done after working on the rear 3rd gen disc brakes.
    If the wheels were dragging royally, it could well be due to not following the steps in the above paragraph. Also, the inside face of rotor would likely have the inner 50% looking rusty, due to lack of contact (due to the piston bearing mainly on the pin of the inner pad, not uniform contact). And the inner pad would have highly bevelled wear, toward the outer edge. The rotor's outer face might have a lot of scoring too.
    The attachment has details on this:
    #3 Mendel Leisk, Apr 12, 2017
  4. Mike Kapala
    Exit 33
    Thank you!
  5. Mike Kapala
    Exit 33
    Gee Mendel this is GREAT! The mechanic is a "Mom and Pop" shop and has become a friend of mine. He's worked in a shop for years and just opened his own place. I told him about some of the things you mentioned and agreed it'd be great for him to look over the manual. Thank you SO much for sharing!
  6. Mendel Leisk
    41,826
    Yeah I don't much like that there's special conditions you need to meet when reassembling the rear brakes: it's just problems waiting to happen. Poor design decision. Hope you get it sorted.
  7. ChapmanF
    18,458
    Well, it might still be a design decision that simplifies things compared to their earlier way of combining rear discs and parking brakes (as on the European Gen 2s), where you had a complete set of disc brakes and drum brakes on the rear....
    -Chap
  8. Mendel Leisk
    41,826
    I kinda miss rear drums. They're maybe a step down in performance, but more reliable? Seem to last and last, with regular checkups.
  9. Former Member 68813
    3,524
    983
    US
    I have that solution in RAV4. No problems. The drum is miniature for parking brake only, so it doesn't wear out (assuming no abuse). The disk part is standard construction and wears out 2 times slower that front. I grease the pins with OEM pink grease regularly BTW.
