Frequent oil changes
Discussion in 'Gen 3 Prius Main Forum' started by griffibaby, Apr 14, 2017.
  1. griffibaby
    griffibaby Junior Member
    31
    US
    My oil maintenance indicator comes on about every 2-3,000 miles. I have a 2010 Prius and was recently told 5-10,000 miles is the norm. Any thoughts?
    Thanks for your help.
    Also, is it possible to DIY a leak in the intake manifold (change the gasket) or is this best done by a dealer?
    51,486
    10,000 is the norm. it's in your maintenance manual. synthetic oil.
    not sure why your reminder comes on every 2-3,000 miles, it's usually 5k for tires, or when you get to 15k, cabin filter and etc.
    but either way, it's just maintenance, not 'oil' specifically.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,513
    Bay Area, California
    2019 Prius Prime
    Changing the gasket on the intake manifold can be done. It takes about 1.5 hours to do as you remove some parts and pieces for access.
    How many miles on your Prius? Why do you feel you have an intake leak? Is there a dash light illuminated?
    If removing the intake manifold, there are other preventative maintenance items that are made easier by its removal;).
  4. ETC(SS)
    7,045
    I'd keep whatever oil change interval that you've been using.
    I'd also want to know why it is that you think that you have an intake manifold leak.
    Question?
    Do you DIY your oil changes or have them done?
    If you have them done, you don't per chance have them done at the dealer, do you?
    If so it might be time to re-examine your relationship with the dealer, since they're supposed to reset the maintenance reminder to the current OCI (10,000 miles in the US.)
    Good Luck!!
    #4 ETC(SS), Apr 14, 2017
  5. griffibaby
    31
    US
    Hi Ray!
    My check engine light came on and I had a code reading done at Pep Boys. They said most likely the spark plugs needed changing (never been done). I took my car to a dealer for a recall and they said it was the spark plugs AND the intake manifold. I admit the car was running a bit rough (vibration in the gas peddle, floor and now the whole front floor and seats). The repair costs over $500.00 plus the spark plugs at over $200.00.
    I also received a notice from Toyota (not a recall) that the code that came up might also indicate a problem with an internal gas regulator that would make the car run rough. When the dealer checked this (supposedly) the tech said that wasn't it. That would have been repaired at Toyota's expence and covered under an extended warranty.
    I'm not quite comfortable with the dealership. I took my car in once before for a recall and had to have $600.00 work done for an oil leak that wasn't there before I took the car in. It leaked badly when I brought my car home (never a previous indication) so I took it to another shop and had the work done.
    Thanks for your advice. All is appreciated!
    Cathy
    Raytheeagle likes this.
  6. Raytheeagle
    11,263
    15,513
    2019 Prius Prime
    Sounds like the dealer you have been using leaves something to be desired:(.
    What part of the country do you reside? If you give us some idea of where you're located, we might be able to help with pointing you toward a reputable shop;).
    What codes did Pep Boys read? If you give us the codes, we'll be able to help with next steps.
    Keep us posted (y).
  7. bisco
    51,486
    how many miles on her?
  8. Mendel Leisk
    40,920
    If you look in the (US) Warranty and Maintenance Booklet, you'll see there's something happening every 5,000 miles or 6 months, whichever comes first. Oil changes are at alternate intervals, ie: every 10,000 miles or 12 months.
    Depends a lot on your situation, but if for example, you're putting on the miles slowly and it's months that governs, the maintenance indicator becomes little more than a confusing hindrance. I would just get very adept at resetting it yourself, read up what's required and when, per the Maintenance Booklet, and last but not least:
    Decide whether you want to follow the oil change interval to the letter, or "improve" on it. FWIW, in Canada, 3rd gen oil change interval is 6 months or 8000 km's (5000 miles)
    Regarding the intake manifold issue: are you sure there's a leak, at the gasket? Per bisco, how many miles on it? If I recall correctly, spraying something like WD40 around the intake manifold mating surface with engine, if there was a leak you would hear some fluctuation in engine as the fluid is sucked in. Personally I'd be averse to oiling up the engine like that, would consider alternatives first.
    Unless you've got definitive diagnosis, I'm sceptical. Is there more back story on this? Anyway, I'll attach something on intake manifold removal/install.
  9. griffibaby
    31
    US
    Hi!
    157,000
    The first four years were used for work.
  10. griffibaby
    31
    US
    Sorry for the delay in responding - tax time.
    The codes that came up are:
    P0301 and P0401.
    The notice I received from Toyota said the latter code might be an indication of a sticking exhaust recirculation valve.
    The notice said there would be a rough idle or rattle noise from the transaxle upon a cold start. Whenever I accelerate on the road, the car will shake but there isn't a noticeable rattle - maybe a slight one. There is vibration in the pedal and floor, but not the steering wheel.
    I live in Hagerstown, MD
    Thanks for your help!
  11. Mendel Leisk
    40,920
    I love their euphemism: "sticking". More likely "royally clogged with tar" would be the case, harumph, harumph.
    Your mileage sounds about right: a lot of 3rd gen owners are reporting clogged EGR system around 150K: effects the intake mainifold, the connecting pipe, the EGR valve, and the EGR cooler. The latter likely being the motherlode for clogging, and of course the most "fun" to deal with.
  12. Raytheeagle
    11,263
    15,513
    2019 Prius Prime
    Those codes together are usually indicative of an air flow restriction :(.
    Are you a DIY type? If so, the intake manifold will probably be deposited up and may only have one or two inlet ports open.
    The TSB for P0401 will only get you a new egr valve, but that doesn't solve the problem as the deposits are still there.
    As @Mendel Leisk said, deposits are there and will need to be dealt with.
    Keep us posted (y).
  13. griffibaby
    31
    US
    HI!
    I'm new with the chat room so unsure if everyone can read my posts.
    When I took my baby in for the air bag recall, I asked the dealer to check if the EGR was the problem with the code and rattle. Unknowingly, the EGR notice said The problem could be repaired by 3/31/17. I took my baby in ON the 31st. The dealer said it wasn't the EGR but the intake manifold. Question - would the intake manifold cause the vibration I'm feeling? The dealer also said if this wasn't repaired it would destroy my catalytic converter. Does a hybrid even have a catalytic converter?
    Would old spark plugs cause the vibration?
    If this needs to be repaired, I'd like to do it myself if possible. I work in social services as a grief counselor and am on a tight budget.
    Thanks for all your help everyone. I want my car to last a few more years
  14. Mendel Leisk
    40,920
    A little overview:
    EGR stands for Exhaust Gas Recirculation. The object of the system is to return exhaust gases to the intake manifold, under certain load conditions, run them through the combustion chambers a second time, to lower emissions. Looking at the picture, the exhaust gasses enter the EGR system at the right end of the EGR cooler (it bolts to the exhaust manifold there, not shown), indicated by arrow.
    The cooler is appropriately named because it has multiple coolant lines connected, and an internal radiator. The object being to cool the hot exhaust gases as they enter the system. Next in line is the EGR valve, controlled by the car's computers to open/close under certain load conditions. Then the pipe, and feeds into the the side of intake manifold, and then into the engine's combustion chambers.
    Anywhere along that path there can (and will) be clogging, due to carbon/sludge airborne in the exhaust gases. Pretty much the whole thing needs inspection/cleaning, stem-to-stern. The "low hanging fruit" is the connectin pipe, between the EGR valve and intake manifold. By removing that you can get some idea of the degree of clogging. @NutzAboutBolts has a video on removal, inspection/cleaning of that pipe, here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    (video #16)
    Just to rant a little: this I believe is the first EGR implementation on a Prius, 2nd gen did not have it AFAIK. And it it not a good design, is failing due to clogging, regularly and predictably, relatively early in the cars' "life spans", and cleaning it is not an easy task: especially the cooler.
    So far Toyota has "acknowledged" the issue, but their fix appears to be case-by-case, and typically skirts dealing with the cooler, the toughest component to access, and the most difficult to clean.
    #14 Mendel Leisk, Apr 18, 2017
    m.wynn, griffibaby and Raytheeagle like this.
  15. ETC(SS)
    7,045
    In a fair and just world, grief counselors would make what mechanics make and vice versa.....but you already know that the world is neither fair nor just.
    Thanks.
    Yeah.....it sounds like the EGR might need looking into.
    Fortunately, it's fairly easy and you have some documentation above.
    This may serve as a guide as well.
    I want to close the loop on your plugs.
    Have they been done or not?
    IIRC they usually get changed around 120,000 miles.
    If so, then it's too late to fuss and cuss about the price, but if not it's one of those jobs that you can do much more cheaply than paying for labor.
    One last thing, and forum regulars will have to excuse my always harping on this, but I drive a 2010 (and it's not even my car!) and they have an undeserved rep as oil burners.
    Please check your oil every month or 1000 miles and keep it topped off.
    There's NO REASON that this car cannot continue to serve you faithfully for another 100,000 miles, especially if you squirrel some money away in a repair fund.
    MUCH cheaper than making monthly car payments!!
    Good Luck!
    EDIT:
    I see Mendel is as efficient as ever.
    The @NutzAboutBolts videos serve as an excellent resource for any Prius driver wanting to do the DIY thing!!!
    +1 on his comments about the EGR valve.
    #15 ETC(SS), Apr 18, 2017
    m.wynn, SAronian and Raytheeagle like this.
  16. griffibaby
    31
    US
    Thank you for your great response. I will give all your info serious thought, view the video and determine if addressing this issue falls within my DIY skill set. Thanks again!
  17. Mendel Leisk
    40,920
    @Raytheeagle has done the stem-to-stern cleaning, my "experience" is all just from reading and listening to him and others with higher mileage 3rd gens, who've hit the wall on this. Ours has got 67K kilometers right now, which amounts to erm, next-to-zero miles. :oops:
  18. Raytheeagle
    11,263
    15,513
    2019 Prius Prime
    @m.wynn will be doing this exact activity at the end of April with at least another member in attendance :whistle:.
    Maybe we could do a video of the activities to help the forum out;).
    But that assumes us novices at videoing can handle it.
    We'll give it the old grade school try though (y).
    m.wynn, ETC(SS), kc410 and 3 others like this.
  19. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    Great post, Mendel. This needs to somehow become an auto-reply to anyone who says they cleaned or are going to clean their EGR pipe...
    With regard to Gen 2, it uses "internal EGR," where the ECU dictates valve overlap to the variable valve timing system at typical EGR required engine loads. This allows back-flow of exhaust gas into the combustion chamber in a maintenance free package. Of course Toyota went external, cooled EGR for Gen 3 and did a marginal job with it. I understand the never ending quest for higher thermal efficiency, but gladly would have given up a few tenths of an mpg for Gen 3 to have kept internal EGR.
    Mendel Leisk and Raytheeagle like this.
