Rear Windshield Wiper/Washer Must...
Discussion in 'Prime Main Forum (2017-2022)' started by Susan4ET, Apr 14, 2017.
  1. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    After going through this winter in Central Oregon I'm hoping Toyota will get their act together and include a rear windshield wiper/washer on the next Prime?
    Also the "keep on driving flat tires" so the spare can stay missing.
    Don't care so much about a 5th seat though.
    What are the chances?
    Thank you for the insight.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Implementing a rear window wiper and the dual-wave rear glass at the same time would be challenging, technically.
    priuscatprimeguy likes this.
  3. bisco
    52,263
    maybe they'll go back to flat glass, add a wiper and fix the front end so the cd doesn't increase.
    Prius Maximus and Mendel Leisk like this.
  4. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Don't miss it in SoCal.
  5. Sandollars
    Sandollars Prius Maven
    134
    157
    SoCal
    Dual outside mirrors are much better than the central rear view mirror. There really isn't much to look through back there even if it did have a wiper which I also don't miss in the least.
    sonomac likes this.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The wiper and the spare (and fifth seat) were omitted to save weight. I would not expected them back.
    Run flat tires could be installed by you, expect a 10 MPG drop in economy.
    #6 JimboPalmer, Apr 14, 2017
  7. Mendel Leisk
    41,808
    Lose the concave rear window, reinstate a rear wiper, maybe one that actually sweeps more than a token arc, and provide a truck-style drop-down, underslung spare. nothing' to it.
    bisco and Prius Maximus like this.
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Toyota makes a car JUST like that, it is called the Gen 4 Prius Liftback.
  9. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    At least based upon my Gen-2 I suspect it'll be OK as long as the lower window is sufficiently shielded from the rain, and it is on my Gen-2 touring, but there's a lot less overhang on the Prime. I suspect it'll be fine for me though.
    In addition to being tricky with the "dual-wave" rear glass, I suspect the a wiper also causes not-insignificant drag.
    iPhone ? Pro
  10. RJ Primw
    RJ Primw Member
    65
    87
    South Jersey
    The wiper and the lack of spare are about my only two criticisms of this car....having just had a flat that took a day and a half to deal with since the tire was ruined and the dealer didn't have one in stock. In terms of the rear window, I miss the wiper a lot, hate the muck that always gathers on the glass, but I do appreciate the increased visibility over my gen 2.
  11. bisco
    52,263
    have you tried rain x or the like?
  12. Lee Jay
    5,850
    4,036
    To me, the problem with the lack of a wiper isn't rain, it's snow. Even if I completely clear the window before driving, snow from the roof will blow onto the rear window and totally obscure the rear view, at least on my 2004. When the side mirrors are also iced up because the defroster hasn't had a chance to melt them clear yet, this is a major problem. RainX has no impact on this problem.
  13. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I'm sold on the "0000" Steel-Wool, followed by Rain-X treatment, but I think I may have found something even better, check out youtube and search for "clean windshield clay-bar wax", the result is astounding!!!
  14. mr88cet
    2,313
    1,335
    Austin, TX
    I at least found RainX to work on surfaces where there's lots of wind constantly blowing on it, but not useful otherwise. It seemed to make things worse on my windshield using the wipers i.e., when the wind was not high enough (e.g., stopped at a light).
    iPhone ? Pro
  15. Zed Ruhlen
    Zed Ruhlen Active Member
    247
    138
    Hood River, OR
    2018 Prius Prime
    Now that it is starting to rain again I have to say the lack of a rear wiper is almost criminal in a car of this cost/features. I call one big giant BS to any weight savings and the freeway economy savings has to be so minimal as to be non existent. If it really mattered the regular prius wouldn't have one either. It probably mostly has to do with the pointless rear window.
    This is what I call a marketing stupidity. It was probably only done to make it look unique. Toyota should be slapped upside the head because you can't see out of the back of the car in the rain.
    Hopefully whoever designed this spends eternity in hell having to drive the car in Seattle winters.
  16. Mendel Leisk
    41,808
    If it's any consolation: our rear wiper (3rd gen and I'm guessing very similar) sweeps a very small area, not very effective. I use it about as much as the fog lights...
  17. Salamander_King
    Salamander_King Senior Member
    11,023
    8,958
    New England
    Maybe Northwest weather is different from New England one. For last 20+ years I lived in NE, I can't remember ever using rear window wiper even when equipped with it. Certainly I don't miss not having one on my current PRIME when I moved from Gen3 with rear wiper.
  18. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    The rear wiper is one of my most used items in the winter here. Literally 100% of the last 10 cars I have owned have had a rear wiper. From a Sienna to a Rogue to a Leaf to a Previa...
    All of the cars I have owned back to the mid 90s have had a rear wiper and I have owned a LOT of cars. Plus every other version of the Prius from the C to the V has a rear wiper.
  19. Salamander_King
    11,023
    8,958
    New England
    Just curious, if rear wiper is so important for your driving condition, why did you buy PRIME? I am sure you knew it did not come with it???
    Prius Two Eco model does not have rear wiper. None of sedans I owned in the past had rear wiper and I never needed it. Many sedans today still do not have rear wiper, I think.
    #19 Salamander_King, Oct 6, 2018
  20. mr88cet
    2,313
    1,335
    Austin, TX
    What is this “snow” you refer to...?
