Buy 05 w 200k miles for 4.5k?
Discussion in 'Gen 2 Prius Main Forum' started by linterzz, Apr 16, 2017.
  1. linterzz
    linterzz Junior Member
    ca
    For the past few months, I've been driving a borrowed (thank you, friend!) 2005 Prius that now has 202,000 miles on it. I've had no problems whatsoever, although the maint req light just did come on. My buddy now has to sell the car and wants $4.5k for it. What do you all think -- deal or no deal? And, if deal, should I take it to get inspected by a mechanic and, if so, I guess it'd have to be at the T dealer, right?
  2. Noobprius
    Noobprius Junior Member
    43
    US
    Sounds a bit steep to me, I paid 2100 for mine with 200k (major problems with it, but it runs). My craigslist has one on it with same miles with all the fancy stuff for 3700. But we have prii a plenty around here, so
    Merkey likes this.
  3. bisco
    52,388
    wow, that sounds expensive! my 2012 w/ 50,000 miles is only worth 10k. have you looked around?
    Merkey likes this.
  4. konawayne
    konawayne Junior Member
    I got a 06 with a new battery with 300k and 40k/1 year on battery.
  5. biglew8
    biglew8 Active Member
    170
    114
    Seattle
    Yeah the price is high for that many miles for 2005. I recently bought a 2005 with about 170K miles for $3000. No issues either.
  6. linterzz
    ca
    Thanks, guys. I'm in San Diego, which seems to be Prius central, so I'll look around. I'll probably have to buy from a dealer, since I don't have much shopping-around time on hand. Should I go certified pre owned if I can?
  7. bisco
    52,388
    if that is a good price in your market, then go for it, i guess. you won't get a cpo near that price, likely.
  8. uart
    uart Senior Member
    4,220
    1,211
    Australia
    If you've been driving it for a few months and are happy with it then it's definitely worth considering. It's due for an oil change so check it now and see how much it's using (you probably should have checked it already by now).
    If the price is a bit steep then make your friend an offer, say 3.8k for example. I'll bet he already knows that if he advertises it for 4.5k that he is probably going to get a lot of tire kickers and time wasters and a ton of low ball offers before he finally settles for a somewhat lower price anyway. Anyone who has ever had to sell a car before is going to know that.
  9. timmyjane
    timmyjane Junior Member
    87
    SC
    How old is the HV battery? 12V? Tires? No matter 4.5k seems expensive.
  10. ETC(SS)
    7,350
    No deal.
    Plus......
    If you buy a 12-year old car with 200,000 miles on it you need to either BE a mechanic, or PAY a mechanic.
    Are you?
    Can you?
    edthefox5 likes this.
  11. linterzz
    ca
    okay okay got it. thanks!
  12. ETC(SS)
    7,350
    No.
    Under certain circumstances, a FACTORY CPO program can be worth the additional money, but not the cheesy 'not-a-factory' CPO plans.
    Most of these are just schemes intended to separate a buyer from more of their money.
    Factory CPO programs require fairly rigorous checks and offer non-trivial addition FACTORY warranties.
    Generally speaking with Yotas, vehicles that are young enough to qualify for the CPO program will easily pass their alleged multi-thousand point inspection because.........they're relative new vehicles.
    Like OEM extended warranties, the juice usually isn't worth the squeeze....BUT at least you have the limited value of it being a FACTORY warranty and not some third party coverage.
    These days, many "Certified Pre-Owned" programs will only certify that the car has been previously owned.
    If you're shopping for a daily driver in the $5,000 range, you may be better served by getting a non-hybrid, for reasons that are easy to discover with a little searching in the forum, as it is a very popular topic with so many G2 Priuses on the road with lunar mileage.
    Good Luck!!!
  13. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    Considering KBB is $3300 very good condition, I wouldn't pay more than that. You could just jump up to 2006+ model that has more features. Buy code reader and check out the check engine light.
  14. oil_burner
    oil_burner Active Member
    249
    126
    i paid $1500 for my 2006 with 218k on it. No issues at all.
    timmyjane likes this.
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Buying a Prius with 200k miles you better have a lot of money set aside for the hybrid battery because your in end of life there for a lot of things on that car, there's not many other cars on the road that require that expensive of a part at that mileage. And the car will not run without a good hybrid battery.
    There's hundreds of posts here now about failed hybrid battery's all at the mileage or more.
    Like Etc said hope you have a good set of tools.
  16. Mendel Leisk
    41,900
    I'd agree with @uart : a big plus is the extended try-before-you-buy you've had. Buying a higher mileage second gen is risky, but having driven it a month or two, you've seen it's reliable.
    Yeah, get a competent mechanical check, offer a little less, see how it goes. (y)
  17. priuslover408
    priuslover408 New Member
    San Jose, CA
    Bought my 05 for $800 ;) needed a hyrbid battery, here in the bay area a little far from San Diego there are people that install refurbished one got one installed for 500 bux with warranty, and detailed the car you can pick up one here in the bay area from 3000-4000 with about 180k clean title
  18. timmyjane
    87
    SC
    I think a lot has to do with location. In my area I looked for a while for my Prius. Almost all were listed way higher than blue book. The ones that were near BB went super fast or had issues. I got mine pretty cheap but it was ragged. Took a lot of trips to LKQ.
