Lubricating Your Prius
Discussion in 'Gen 2 Prius Main Forum' started by TwelveInchPrius, Jun 23, 2006.
  1. TwelveInchPrius
    TwelveInchPrius New Member
    39
    How often is it necessary to lubricate your Prius? What parts should be lubricated? Any recommendations for products to us? :)
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    As you previously said "A well-lubricated Prius is a "happy" Prius!!"
  3. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    i guess you could put some grease on the door hinges... but there aren't any chassis lubrication points if that's what you're referring to.
  4. Thomas Brock
    Thomas Brock New Member
    87
    I like to liberally coat the outside with vegetable oil...Helps with aerodynamics...:D
    juuuuuuuuuuuuuuuust kidding.
  5. larkinmj
    larkinmj New Member
    1,996
    <div class='quotetop'>QUOTE(galaxee @ Jun 24 2006, 11:16 AM) [snapback]276305[/snapback]</div>
    Isn't that true of all modern cars? I remember when you would take your car in for an oil change and a "lube job", but isn't chassis lubrication a thing of the past?
    <div class='quotetop'>QUOTE(Thomas Brock @ Jun 24 2006, 01:46 PM) [snapback]276361[/snapback]</div>
    Seriously, I wonder if the auto industry is researching new paint formulations to make cars more aerodynamically efficient? The Navy has done a lot of that type of research for submarine hulls (although that is to reduce noise, not increase fuel efficency) and the marine industry has come up with new types of hull coatings to reduse drag. I wonder if they can make a car more "slippery"?
  6. fshagan
    fshagan Senior Member
    1,766
    Noneofyourbusiness, CA
    <div class='quotetop'>QUOTE(larkinmj @ Jun 24 2006, 11:00 AM) [snapback]276368[/snapback]</div>
    I know in boat racing they found the slickest paint was not actually the fastest. There was less drag with a slightly less slick surface. The way I heard it explained was that the water actually forms eddies at the surface of the paint to water interface, and the eddies act like ball bearings. Take away the eddy-producing roughness, and the friction actually increased.
  7. galaxee
    9,810
    469
    MD
    <div class='quotetop'>QUOTE(larkinmj @ Jun 24 2006, 02:00 PM) [snapback]276368[/snapback]</div>
    not all, but it's getting more and more common.
  8. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    Yeah it is similiar to the aerodynamics of golf balls, but I am not sure anyone would want to buy a dimply car. o_O
  9. Brian K
    Brian K New Member
    152
    Actually there are dimpled cars. The dimples are on the underbody panels. Somehow I thought Prius was one of those cars. The other one was a german make, don't know which maker.
  10. 200Volts
    200Volts Member
    439
    46
    Northern CA
    Mercedes dimples the under panels on some cars. Remember their wind tunnel comercial with the car on a rotisery and the roll it to show you smooth the air flow was under the car?
  11. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(TwelveInchPrius @ Jun 23 2006, 07:12 PM) [snapback]276072[/snapback]</div>
    To keep warranty, an oil and filter change is necessary every 8,000km / 5,000 miles or 6 months.
    You may or may not elect to change the CVT fluid. Some of us have, and noted a degraded fluid condition. Canadian market cars require a CVT fluid service every 85,000km or so, U.S. market Prius cars do not.
    The tie rod ends and ball joints are sealed. It's not possible to grease them, as there are no zerk fittings - "lubed for life"
  12. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(TwelveInchPrius @ Jun 23 2006, 05:12 PM) [snapback]276072[/snapback]</div>
    Having in mind your user name, I could not help but think of Kentucky Jelly (yes, I know it is not the postal abbreviation for Kentucky).
  13. larkinmj
    larkinmj New Member
    1,996
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Jun 25 2006, 08:07 PM) [snapback]276671[/snapback]</div>
    I always assumed it was called that because it came from Kentucky!
  14. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    So which would be best for the Prius, the regular KY or the warming stuff? :D
  15. larkinmj
    larkinmj New Member
    1,996
    <div class='quotetop'>QUOTE(Tadashi @ Jun 26 2006, 05:16 PM) [snapback]276992[/snapback]</div>
    If you're in Texas, go with the non-warming variety- you don't want to get your Prius overheated. In New England, definitely the warming stuff.
  16. koa
    koa Active Member
    980
    45
    Hawaii
